All,
Been working for a while having 'fun' trying to port the General Polygon Clipper (GPC) Library from C to Fortran but decided it may be easier to just to call the 2-3 GPC 'C' routines I need from my Fortran code. All the polygon info is contained in 'typedef struct's in the C code which are as follows:
typedef enum /* Set operation type */
GPC_DIFF, /* Difference */
GPC_INT, /* Intersection */
GPC_XOR, /* Exclusive or */
GPC_UNION /* Union */
} gpc_op;
typedef struct /* Polygon vertex structure */
double x; /* Vertex x component */
double y; /* vertex y component */
} gpc_vertex;
typedef struct /* Vertex list structure */
int num_vertices; /* Number of vertices in list */
gpc_vertex *vertex; /* Vertex array pointer */
} gpc_vertex_list;
typedef struct /* Polygon set structure */
int num_contours; /* Number of contours in polygon */
int *hole; /* Hole / external contour flags */
gpc_vertex_list *contour; /* Contour array pointer */
} gpc_polygon;
The prototypes of the 3 GPC routines I need to communicate with are:
void gpc_add_contour (gpc_polygon *polygon,
gpc_vertex_list *contour,
int hole);
void gpc_polygon_clip (gpc_op set_operation,
gpc_polygon *subject_polygon,
gpc_polygon *clip_polygon,
gpc_polygon *result_polygon);
void gpc_free_tristrip (gpc_tristrip *tristrip);
On the Fortran side, my equivalent Derived Types are:
TYPE :: gpc_op ! /* Set operation type */
INTEGER :: GPC_DIFF=0 ! /* Difference */
INTEGER :: GPC_INT=1 ! /* Intersection */
INTEGER :: GPC_XOR=2 !***not used ! /* Exclusive or */
INTEGER :: GPC_UNION=3 ! /* Union */
END TYPE
TYPE :: GPC_VERTEX ! /* Polygon vertex structure */
REAL(8) :: x ! /* Vertex x component */
REAL(8) :: y ! /* vertex y component */
END TYPE
TYPE :: GPC_VERTEX_LIST ! /* Vertex list structure */
INTEGER :: num_vertices ! /* Number of vertices in list */
TYPE (GPC_VERTEX),ALLOCATABLE :: vertex(:) ! /* Vertex array pointer */
END TYPE
TYPE :: GPC_POLYGON ! /* Polygon set structure */
INTEGER :: num_contours ! /* Number of contours in polygon */
INTEGER :: hole ! added ! /* Hole / external contour flags */
INTEGER,ALLOCATABLE :: holea(:) ! changed ! /* Hole / external contour flags */
TYPE (GPC_VERTEX_LIST),ALLOCATABLE :: contour(:) ! /* Contour array pointer */
END TYPE
Now, I have ZERO experience (and have found no references or examples) as to how the INTERFACE would be constructed to exchange data between Fortran & C structures. For example...the Fortran subroutine cgr_polydiff calls gpc_polygon_clip in the following way:
SUBROUTINE cgr_polydiff(npin0,xin0,yin0,npin1,xin1,yin1,maxnpo,npo,xo,yo,iret)
! * cgr_polydiff *
! * This function computes the difference of two polygons using the *
! * difference clipping option in the GPC (General Polygon Clipper) *
! * library. The area that is in polygon 0 but not in polygon 1 is *
! * returned. *
! * Input parameters: *
! * *npin0 int Number of points in polygon 0 *
! * *xin0 float X coordinates of polygon 0 *
! * *yin0 float Y coordinates of polygon 0 *
! * *npin1 int Number of points in polygon 1 *
! * *xin1 float X coordinates of polygon 1 *
! * *yin1 float Y coordinates of polygon 1 *
! * *maxnpo int Maximum number of output points *
! * Output parameters: *
! * *npo int Number of points in output polygon *
! * *xo float X coordinates of output polygon *
! * *yo float Y coordinates of output polygon *
! * *iret int Return code *
! * = 1 - no area in 0 that isn't in 1 *
! * = -1 - insufficient maxnpo *
! * = -2 - polygons have insufficient # of pts *
USE GPC
! - - - arg types - - -
INTEGER :: npin0,npin1,iret
INTEGER :: maxnpo,npo
REAL(4) :: xin0,yin0
REAL(4) :: xin1,yin1
REAL(4) :: xo,yo
! - - - local declarations - - -
INTEGER :: ii,hole,ier
TYPE(GPC_POLYGON) :: gpc_poly_0
TYPE(GPC_POLYGON) :: gpc_poly_1
TYPE(GPC_POLYGON) :: gpc_diff_poly
TYPE(GPC_VERTEX_LIST) :: verts
! - - - begin - - -
< - snip - >
CALL gpc_polygon_clip( GPC_DIFF, gpc_poly_0, gpc_poly_1, gpc_diff_poly )
Using Intel® Parallel Studio XE 2015 Composer Edition for Fortran Windows, how would the INTERFACE be constructed to handle this example?
Thanks in advance,
Jeff
I can tell you that you do NOT want to use ALLOCATABLE or DIMENSION(:) in your Fortran derived types. These do not correspond to what's on the C side. Most likely you want TYPE(C_PTR) there and assign the values using C_LOC. Also note where the C struct definition has a "*" - this indicates it wants a pointer not the actual value. For example "hole" in gpc_polygon. So again you would declare the Fortran type with TYPE(C_PTR).
