IOSTAT 43 on OPEN
Tamiris_Crepalde
i'm with an IOSTAT 43 on OPEN a .txt file containing the numbers 4.0 -9.0 2.0 2.0 -4.0 4.0 -1.0 2.0 2.0. Someone can help me?
      program LU
      implicit none
      character*300 :: filename
      integer       :: ul,erro,dim,i,j,k
      real*8,dimension(:,:),allocatable :: a,l,u
      real*8,dimension(:),allocatable   :: x,y,b
      filename    = ''
      ul          = 3
      erro        = 0
      dim         = 0
      !matriz A
      write(*,'(A)') 'Informe o nome do arquivo que contém a matriz A:'
      read(*,'(A)') filename
      write(*,'(A)') 'Informe a dimensão da matriz:'
      read(*,'(I)') dim
      allocate(A(dim,dim))
      allocate(l(dim,dim))
      allocate(u(dim,dim))
      a = 0.0
      l = 0.0
      u = 0.0
      open(ul,file=filename,status='old',action='read',iostat=erro,
     +form='formatted')
      if(erro.gt.0) write(*,10)erro
      read(ul,'(F)') a
Steve_Lionel
43 is "File name specification error". The variable filename may not have a valid filespec in it. I'll also comment that Windows generally has a 256-byte limit on filespecs, though trailing blanks would be ignored. If the user entered Unicode characters that could cause a problem - Intel Fortran does not yet support non-ASCII characters in file specifications.
FortranFan
Look into the facilities the language provides with OPEN statement:
https://software.intel.com/en-us/fortran-compiler-18.0-developer-guide-and-reference-open
and try using IOMSG and look into what the processor tells you about IOSTAT error 43:
https://software.intel.com/en-us/fortran-compiler-18.0-developer-guide-and-reference-i/o-message-specifier-iomsg#BCD33692-DE37-4EC2-AAC3-68849E2EF08D
 character(len=XX) :: imsg  !<-- some suitable length, say XX=256
+form='formatted', iomsg=imsg)
 if (erro > 0) then
    write(*,10) erro
    write(*,10) imsg
Steve_Lionel
Or remove the IOSTAT= and look at the name in the full error message. Or print the contents of "filename" after it is read.
Tamiris_Crepalde
I was using a folder with a name containing space on it and don't realized that this is a problem on fortran! I put the iomsg= to, very useful and i didn't know about.
Thank you very much!!
Steve_Lionel
Fortran doesn't have problems with spaces in folder names.
D:\Projects>type t.f90
character(50) :: fnam,fspec
fnam = "C:\Test Folder\test.txt"
open (unit=1,file=fnam)
inquire (1,name=fspec)
print *, fspec
end
D:\Projects>ifort t.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64,
Version 17.0.4.210 Build 20170411
Copyright (C) 1985-2017 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 14.00.24210.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:t.exe
-subsystem:console
t.obj
D:\Projects>t.exe
D:\Projects>
Tamiris_Crepalde
I will try it! Thak you very much Steve!
