IPO optimization failure at run with generic type-bound procedures ??
Frederic_C_
Dear everyone,
I found a possible big bug in ipo optimzation using "sophisticated" derived type with generic-type bound procedures
Find the codes here,
MODULE m_vec2d
   USE, intrinsic :: iso_fortran_env
   implicit none
   integer, parameter :: ip = INT32
   integer, parameter :: rp = REAL64
   TYPE vec2d
      real(rp) :: x = 0._rp
      real(rp) :: y = 0._rp
   CONTAINS
      procedure, pass( self ) :: equal_vec2d
      procedure               :: rot_vec2d
      procedure               :: invrot_vec2d
      generic :: assignment(=) => equal_vec2d
      generic :: operator(.rot.)     => rot_vec2d
      generic :: operator(.invrot.)  => invrot_vec2d
   END TYPE vec2d
CONTAINS
   ELEMENTAL SUBROUTINE equal_vec2d( self , from )
      class(vec2d), intent(inout) :: self
      type(vec2d), intent(in) :: from
      self%x = from%x
      self%y = from%y
   END SUBROUTINE equal_vec2d
   ELEMENTAL FUNCTION rot_vec2d( self , n ) RESULT( this )
      class(vec2d), intent(in) :: self , n
      type(vec2d) :: this
      this%x = self%x * n%x + self%y * n%y
      this%y = self%y * n%x - self%x * n%y
   END FUNCTION rot_vec2d
   ELEMENTAL FUNCTION invrot_vec2d( self , n ) RESULT( this )
      type(vec2d) :: this
      this%x = self%x * n%x - self%y * n%y
      this%y = self%y * n%x + self%x * n%y
   END FUNCTION invrot_vec2d
END MODULE m_vec2d
MODULE m_model
   USE m_vec2d
   implicit none
   TYPE primvar
      real(rp) :: h
      type(vec2d) :: u
   CONTAINS
      procedure, pass( self ) :: equal_primvar
      procedure, pass( self ) :: rot_primvar
      procedure, pass( self ) :: invrot_primvar
      generic :: assignment(=) => equal_primvar
      generic :: operator(.rot.)     => rot_primvar
      generic :: operator(.invrot.)  => invrot_primvar
   END TYPE primvar
   TYPE unk
      type(primvar), allocatable :: var(:)
   END TYPE unk
CONTAINS
   ELEMENTAL SUBROUTINE equal_primvar( self , from )
      class(primvar), intent(inout) :: self
      type(primvar), intent(in) :: from
      self%h   = from%h
      self%u%x = from%u%x
      self%u%y = from%u%y
   END SUBROUTINE equal_primvar
   ELEMENTAL FUNCTION rot_primvar( self , normal ) RESULT( this )
      class(primvar), intent(in) :: self
      type(vec2d), intent(in) :: normal
      type(primvar) :: this
      this%h = self%h
      this%u = self%u .rot. normal
   END FUNCTION rot_primvar
   ELEMENTAL FUNCTION invrot_primvar( self , normal ) RESULT( this )
      this%h = self%h
      this%u = self%u .invrot. normal
   END FUNCTION invrot_primvar
END MODULE m_model
PROGRAM main
   USE m_vec2d
   USE m_model
   implicit none
   integer(ip), parameter :: n = 10
   integer(ip) :: i
   type(vec2d) :: normal , flux
   type(unk) :: dof
   type(primvar) :: x
   allocate( dof%var(n) )
   normal%x = 1._rp / sqrt(2._rp)
   normal%y = 1._rp / sqrt(2._rp)
   dof%var(:)%h   = 1._rp
   dof%var(:)%u%x = 1._rp
   dof%var(:)%u%y = 2._rp
   do i = 1,n
      x = dof%var(i) .rot. normal
      x = x .invrot. normal
   end do
   do i = 1,n
      write(6,*) x%h , x%u%x , x%u%y
   end do
END PROGRAM
At execution, the vector part of my primvar structure is set to zero ! whereas normal result is produced without ipo compilation option as with gfortran with or without lfto compilation option
there seems to be something bad in interprocedural optimization with an inter dependency of two structures separated in two source files (primvar derivedtype rot and invrot operators depend on the derived type vec2d rot and invrot operators)
ifort --version
ifort (IFORT) 18.0.2 20180210
Copyright (C) 1985-2018 Intel Corporation.  All rights reserved.
Note a normal result with the version 17 ... don't know with last version 19 ...
Juergen_R_R
Valued Contributor II
Dear Frederic,
I didn't go through your code in detail, but only noticed that the code gives the results 1, 1, 2   (10 times) with ifort 19, gfortran 5.4, nagfor 6.2 and PGI fortran 18.7. With ifort 17.0.8 and 18.0.5 it gives different results. So this could possibly be an old bug in ifort that has been fixed for the 19 release series.
Cheers,
      Juergen
Frederic_C_
Juergen R. wrote:
Dear Frederic,
Cheers,
      Juergen
Thanks very much, you confirm the issue ...
I just find a way to resolve the problem reducing the = assigment for the primvar derived type to self%u = from%u
very strange optimization bug
Frederic_C_
Frederic C. wrote:
Quote:
Juergen R. wrote:
Dear Frederic,
Cheers,
      Juergen
edit: no, the bug is already here with this manipulation
not for this example, much more complex ...
I must strictly not overload operators with dependant other overload to use ipo optimization ...
