- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
I just downloaded the new Intel Fortran compiler.
I installed it on a RH 9 box and i tested it with the code reported at the end of this post.
Previously, ifc 7.1 did not have any problem on the same box with "unformatted" writes and reads. "binary" format, on the other hand, gave a strange problem.
I had no write/read problem with files less than the disk cache but it crashed at the first read from a (I suppose) correctly written file larger than the disk cache. I suppose it's something related to actual disk access. I never cared about it and I used unformatted files, which worked well.
Now, with ifort I always get a "maximum file size exceeded" with both uformatted and binary i/o when the size of the file being written exceeds 2GB. The message is in Italian (my native language), so I suppose it is cast by a localized library, not by ifc library routines.
Can anyone test my code and check if it works with Intel Fortran 8, with both "unformatted" and "binary" I/O?
Arturo di Gioia
program testcode
implicit none
real(8),dimension(10000) :: vector=1.d0
integer :: i,j
do j=1,5
write(*,*) 10000*10**j/1024./1024.*8,'MB'
open(unit=10,file="testfile.bin",form="unformatted",action="write")
do i=1,10**j
write(10) vector
end do
close(10)
open(unit=10,file="testfile.bin",form="unformatted",action="read")
do i=1,10**j
read(10) vector
end do
close(10)
end do
end program testcode
Arturo di Gioia
program testcode
implicit none
integer :: i,j
do j=1,5
do i=1,10**j
write(10) vector
end do
close(10)
do i=1,10**j
read(10) vector
end do
close(10)
end do
- Marcas:
- Intel® Fortran Compiler
Link copiado
12 Respostas
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Arturo,
Using your test program I encountered the same behavior.
Something is broken as this worked perfectly in ifc 7.1.
Please submit a bug report to intel.
Bernie
The Boeing Company
Bernie
The Boeing Company
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
This problem will be fixed for an update, probably the second one.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
sblionel wrote:This problem will be fixed for an update, probably the second one.
I am having a similar problem (using ifort version 8.0.034) trying to read from a 7.6GB file. OPEN fails on this file and INQUIRE returns EXIST as FALSE. A C program using open64 works properly.
Is this a problem in version 8.0.0.34 and if so can you give me a time table on when it will be fixed?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I'm not sure if your problem is the same one. 8.0.038 is available now from your Premier Support account - why not try it?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
sblionel wrote:I'm not sure if your problem is the same one. 8.0.038 is available now from your Premier Support account - why not try it?
I downloaded and installed version 8.0.0.39 and tried it, but got the same result.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I just learned that, while the problem is fixed in our internal sources, it has not yet made it to a released update.I don't know how long it will take.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
ok, thanks. I guess for now I will avoid large files. Do you know if this fix will be in the next patch release?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I really don't know. The process of collecting fixes and putting together the updates is complex. I do know the developer has submitted the fix, and I'd assume that it will be picked up for the next update that is packaged. The best I can suggest is to get the updates and keep trying. If you report the problem to support, (and you are eligible for full support), the support engineers would let you know when an update with the fix was available.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I reported it as an "Issue" at the Premier Support site, if thats what you mean. You are faster than them. =)
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I guess I'll have to slow down, then... :smileyhappy:
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I guess I'll have to slow down, then... :-)
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
For anyone interested, it looks like the new patch (l_fc_p_8.0.039_pe040 for IA32 or l_fc_p_8.0.039_pl040 for Itanium) has fixed the large file issue.
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
