Ifort error after updating intel compiler 17.0 to 18.0
sungho_l_
 I have compiler(ifort) errors after updating Intel compiler 17.0 to 18.0
The compiler command window shows
"Severe: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error. ifort: error #10014: problem during multi-file optimization compilation (code 3)"
Before version updates, my code was successfully compiled.
Any ideas?
mecej4
As is usual for any internal compiler error, provide a sample source code, information regarding the compiler and OS versions, and provide instructions for reproducing the error.
Lorri_M_Intel
An "internal compiler error" is always a compiler problem.
I agree with mecej4, we cannot diagnose/fix the problem without a reproducer.
In the meantime, please try disabling the link-time optimizations by adding /Qipo-  to the list of commands.
               Thank you -
                              --Lorri
