Information hiding in derived type
Blane_J_
Please take a look at the two simple module pairs as follows:
module test1
    implicit none
    private
    public :: tp1
    type, abstract :: tp1
        private
        ! <Nothing.>
    contains
        private
        procedure(isub), nopass, deferred :: sub
    end type tp1
    abstract interface
        subroutine isub(var)
            integer :: var
        end subroutine isub
    end interface
end module test1
module test2
    use test1, only: tp1
    implicit none
    private
    public :: tp2
    type, extends(tp1) :: tp2
        private
        integer :: t
    contains
        private
        procedure, nopass :: sub => mysub
    end type tp2
    contains
        subroutine mysub(var)
            integer :: var
            print*, var
        end subroutine mysub
end module test2
module test3
    implicit none
    private
    public :: tp3
    type, abstract :: tp3
        private
        ! <Nothing.>
    contains
        private
        procedure(ifunc), nopass, deferred :: ifunc
    end type tp3
    abstract interface
        function ifunc(var)
            integer :: ifunc
            integer :: var
        end function ifunc
    end interface
end module test3
module test4
    use test3, only: tp3
    implicit none
    private
    public :: tp4
    type, extends(tp3) :: tp4
        private
        integer :: t
    contains
        private
        procedure, nopass :: func => myfunc
    end type tp4
    contains
        function myfunc(var)
            integer :: myfunc
            integer :: var
            myfunc = var
        end function myfunc
end module test4
The only difference between the upper pair(test1 & test2) and the lower(test3 & test4) is the type-bound procedure: tp1 & tp2 has the subroutine while tp3 & tp4 has the function. The problem is the upper pair can be compiled without any warning or error but the lower cannot, the compiler says for the lower:
error #8322: A deferred binding is inherited by non-abstract type; It must be overridden.   [IFUNC]
Notice that PRIVATE statement is set for all the CONTAINS block of the derived types(tp1& tp2 & tp3 & tp4), so why subroutine can override while function cannot ?
Blane_J_
FortranFan wrote:
Quote:
Blane J. wrote:
..The listdirected and DT-formed input and output (indicate by comment line 2,3,4,5 and 7.8.9.10) still generate the same error message I presented previously, but comment line 1 and 6 are just OK.
It looks to me like a bug in the Intel Fortran compiler, your code is alright.
Yes, I think so. I've reported this failure to OSC and wait for replies.
Arjen_Markus
I have not tried it, but in tp4 you define a function func, not ifunc. So the ifunc entry inherited from tp3 is not satisfied.
IanH
Note also, that in the subroutine case (where the binding names are the same) an error should also be reported - a private binding effectively cannot be overridden outside of the module that defines the type with the private binding.  This behaviour has been discussed on the forums in the last year or two - the specified behaviour resulted in-part from a language interp, and it is possible compiler may not have caught up with the results of that interp and subsequent bug reports yet.
Blane_J_
The procedure name in tp3 is a mistake, it should be func, thanks Arjen Markus. correct it but the problem still exist...
Blane_J_
Yes, lanH, there's something more I would wonder. In the subroutine case, if the PRIVATE keyword in tp1 is an attribute as:
        procedure(isub), private, nopass, deferred :: sub
rather than a statement, the compiler can recognize the error and report:
further more, If the PRIVATE statement in tp1 remains, but the PRIVATE in tp2 is omitted(which means all the type-bound procedures in tp2 is PUBLIC), the subroutine case can be compiled as well. Private bindings in abstract type would never be override, so I wonder if the DEFERRED attribute impilies PUBLIC attribute for the specified procedure regradless of PRIVATE statement ?
IanH
If you are seeing a difference based on whether PRIVATE for a bindings is explicitly specified for the binding or based on the default accessibility for bindings of the type, then that would be a compiler bug.
Private bindings can be overridden within the module (or its submodule descendants) that defines the type, they just cannot be overridden outside of the defining module.
Blane_J_
I think so, may someone from Intel can see this.
FortranFan
@Blane  J.,
I think there are one or more issues with Intel Fortran compiler for which you can submit incidents at the Intel's Online Service Center (OSC): https://supporttickets.intel.com/?lang=en-US in addition to a possible typo in one line of your code:
  • On line 12 of your second example involving a FUNCTION scenario, did you mean a DEFERRED PROCEDURE of 'func' instead of 'func' i.e., "procedure(ifunc), nopass, deferred :: func"?
  • See this thread: https://software.intel.com/en-us/forums/intel-fortran-compiler-for-linux-and-mac-os-x/topic/681705.
Perhaps Intel Fortran team can update readers here on the status of the implementation of the findings from interp F08/0052
Blane_J_
FortranFan wrote:
@Blane  J.,
For the first issue, yes, it is a mistake as I mentioned in Quote #4.
For the second, I have read about the thread and it has the question and discuession I'm just confusing. Unfortunately it seems the problem has not been fixed yet, thanks FortranFan.
Blane_J_
In addition, I'd like to ask if the generic binding which bind user-defined I/O procedures cannot be inherited ?
module test1
    implicit none
    private
    public :: tp1
        private
        ! <Nothing.>
    contains
        private
        generic,                      public                 :: write(unformatted) => unformattedwrite
        procedure(iunformattedwrite), public, pass, deferred ::                       unformattedwrite
    end type tp1
    abstract interface
        subroutine iunformattedwrite (var,unit,iostat,iomsg)
            import tp1
            class(tp1),  intent(in)    :: var
            integer,     intent(in)    :: unit
            integer,     intent(out)   :: iostat
            character(*),intent(inout) :: iomsg
        end subroutine iunformattedwrite
    end interface
end module test1
module test2
    implicit none
    private
    public :: tp2
        private
        integer :: t
    contains
        private
        procedure, public, pass :: unformattedwrite => output
    end type tp2
    contains
        subroutine output (var,unit,iostat,iomsg)
            implicit none
            class(tp2),  intent(in)    :: var
            write(unit, IOSTAT=iostat, IOMSG=iomsg) var % t
        end subroutine output
end module test2
program main
    use test2, only: tp2
    implicit none
    type(tp2) :: s
    write(*,*) s
end program main
tp1 has a generic unformatted output binding( write(unformatted) ), it refers to the public binding procedure(unformattedwrite) which is deferred and implemented concreate in the extended type tp2. Note tp1 and tp2 both have the unforamttedwrite procedure PUBLIC. If this is correct, tp2 should have inherited the generic binding from tp1 and output an instance of tp2 should be OK. but the compile time error message says:
error #5521: A derived-type object in an input/output list cannot have inaccessible components unless a suitable user-defined input/output procedure is available.
Is the generic binding not inherited or something else ?
IanH
The list directed write statement in the main program is a formatted write statement.  The provided binding is only for unformatted writes.
("Formatted" means "formatted so humans can read it".  The format specification for the list directed write statement is `*`.  An unformatted write statement has no format specification, and produces "binary stuff" in the file that is generally not considered human readable.)
jimdempseyatthecove
Try:
write(*,'(DT)') s
Jim Dempsey
FortranFan
jimdempseyatthecove wrote:
Try:
write(*,'(DT)') s
Jim Dempsey
Jim,
What IanH in his own inimitable, cryptic style was informing the OP was to include a defined output procedure binding for WRITE(FORMATTED) that is missing in the derived type shown in Quote #10 and which will be needed whether it is "write(*,*) s" or "write(*,'(dt)') s" statements.
Blane_J_
Thanks lanH, Jim and FortranFan. I see the clerical mistake. I then implemented all the input/output procedures in case of failure, show as below:
module test1
    implicit none
    private
    public :: tp1
        private
        ! <nothing.>
    contains
        private
        generic,                      public                 :: read(formatted)    => formattedread
        procedure(iformattedread),    public, pass, deferred ::                       formattedread
        generic,                      public                 :: read(unformatted)  => unformattedread
        procedure(iunformattedread),  public, pass, deferred ::                       unformattedread
        generic,                      public                 :: write(formatted)   => formattedwrite
        procedure(iformattedwrite),   public, pass, deferred ::                       formattedwrite
    end type tp1
    abstract interface
        subroutine iformattedread(var, unit, iotype, list, iostat, iomsg)
            import tp1
            class(tp1),                 intent(inout) :: var
            character(*),               intent(in)    :: iotype
            integer,      dimension(:), intent(in)    :: list
            character(*),               intent(inout) :: iomsg
        end subroutine iformattedread
        subroutine iunformattedread(var, unit, iostat, iomsg)
            import tp1
        end subroutine iunformattedread
        subroutine iformattedwrite(var, unit, iotype, list, iostat, iomsg)
            import tp1
        end subroutine iformattedwrite
        subroutine iunformattedwrite(var,unit,iostat,iomsg)
            import tp1
    end interface
end module test1
module test2
    implicit none
    private
    public :: tp2
        private
        integer :: t
    contains
        private
        procedure, public, pass ::   formattedread  =>   formattedreadsub
        procedure, public, pass :: unformattedread  => unformattedreadsub
        procedure, public, pass ::   formattedwrite =>   formattedwritesub
        procedure, public, pass :: unformattedwrite => unformattedwritesub
    end type tp2
    contains
        subroutine formattedreadsub(var, unit, iotype, list, iostat, iomsg)
            implicit none
            class(tp2),                 intent(inout) :: var
            if(iotype == 'listdirected' .or. iotype == 'dt')then
                read(unit, *, IOSTAT=iostat, IOMSG=iomsg) var % t
            end if
        end subroutine formattedreadsub
        subroutine unformattedreadsub(var, unit, iostat, iomsg)
            implicit none
            read(unit, IOSTAT=iostat, IOMSG=iomsg) var % t
        end subroutine unformattedreadsub
        subroutine formattedwritesub(var, unit, iotype, list, iostat, iomsg)
            implicit none
                write(unit, *, IOSTAT=iostat, IOMSG=iomsg) var % t
            end if
        end subroutine formattedwritesub
        subroutine unformattedwritesub(var,unit,iostat,iomsg)
            implicit none
        end subroutine unformattedwritesub
end module test2
program main
    implicit none
    type(tp2) :: s
    open(unit=100, file="100.txt", form="unformatted", status = "replace")
    open(unit=101, file="101.txt", form="formatted",   status = "replace")
    write(100)        s ! <-- 1.
    write(*,*)        s ! <-- 2.
    write(*,"(DT)")   s ! <-- 3.
    write(101,*)      s ! <-- 4.
    write(101,"(DT)") s ! <-- 5.
    close(100)
    close(101)
    open(unit=100, file="100.txt", form="unformatted", status = "old")
    open(unit=101, file="101.txt", form="formatted",   status = "old")
    read(100)         s ! <-- 6.
    read(*,*)         s ! <-- 7.
    read(*,"(DT)")    s ! <-- 8.
    read(101,*)       s ! <-- 9.
    read(101,"(DT)")  s ! <-- 10.
    close(100)
    close(101)
end program main
Point me out if I'm wrong. The listdirected and DT-formed input and output (indicate by comment line 2,3,4,5 and 7.8.9.10) still generate the same error message I presented previously, but comment line 1 and 6 are just OK.
FortranFan
Blane_J_
