29254 Discussions
Installation of Intel Fortran for OS X 10.8.2 / XCode 4.6
Ryan_S_1
Hi, folks -
I'm attempting a new installation of Intel Fortran 2013.2.146 .  I'm using OS X 10.8.2 and XCode 4.6 (w/command line tools).  Unfortunately, I'm stuck right out of the gate, and all instructions that I can find are either for older versions or jump past my current sticking point.
I downloaded l_fcompxe_2013.2.146.tgz and extracted the archive.  I cd'ed into the l_fcompxe_2013.2.146 directory.  I then ran
./install.sh
...and I immediately hit problems.  The output of the above command is
> ./install.sh
./install.sh: line 338: /sbin/ldconfig: No such file or directory
grep: /proc/cpuinfo: No such file or directory
./install.sh: line 61: [: -lt: unary operator expected
./install.sh: line 64: [: -eq: unary operator expected
./install.sh: line 398: /Users/ryan/Downloads/l_fcompxe_2013.2.146/./pset/32e/install.32e: cannot execute binary file
./install.sh: line 399: /var/folders/gz/vhyhbgy56sv2z2fpm6wnhv280000gn/T//intel.pset.strings.ryan.ryanlaptop.local: No such file or directory
So, it looks like the installation script is not set up for 10.8 .  I'm quickly learning that OS X is anything but a "standard" linux installation. :)
Any ideas???
Thanks -
Ryan
mecej4
You cannot use the Linux distributions of Intel compilers on OSX. Download and install the distribution matched to your OS, as described in the release notes.
Ryan_S_1
Hi, mecej4.  Thanks for the response.  (I love your avatar, by the way. :))
Unfortunately, when I am prompted to download, the Linux option is the only one displayed (aside from Windows).
One factor that may be relevant... I have tried downloading both the non-commercial version, as well as the demo version of the full suite.  Is it possible that these are not offered for OSX?
Steven_L_Intel1
We offer the non-commercial version for Linux only. You're right that the evaluation version for OS X doesn't seem to be there - this puzzles me and I will find out why.
Steven_L_Intel1
It seems we unintentionally removed a path to find the OS X eval download.  You can find it at http://software.intel.com/en-us/intel-fortran-composer-xe-evaluation-options ; I have asked the web folks to fix this.
Supantha_P_
Hi Steve, mee too stuck with the same problem, is there any update on availability of  non-commercial version of the intel compilers on OSX(Mavericks, I am using 10.9.3), wanna check that on my macbook pro.
Steven_L_Intel1
The eval version is there - that got fixed more than a year ago. We're not doing non-commercial on OS X. Are you having a problem getting it?
