Installer says another instance of the installer is running
Sourish_B_
This is my first time posting to this forum, not sure if this is the right forum for this question. Apologies if that is not the case.
Some time back I had installed Intel Parallel Studio XE on my 64-bit Ubuntu 12.04 machine, at which time I had only installed a few selected components. Recently, I realized that I needed to install Vtune amplifier to profile my code. So I downloaded a file called "parallel_studio_xe_2015_update3.tgz", un-tar-gzed it, ran the installer and chose to modify my installation. At this point, I got a message saying that there was another instance of the installer running (there wasn't). The full screen looks as follows:
This product is already installed
Installation program has detected that at least one component of the product is
already installed. Select one of the following options to continue:
1. Modify the installation [default]
2. Repair the installation
3. Uninstall the product
h. Help
q. Quit
Please type a selection or press "Enter" to accept default choice [1]: 1
Another instance of the installation program has been detected. Please quit the
other instance and try again.
Press "Enter" key to quit:
I've even tried rebooting the machine, to kill off any processes which might be causing this. But this is a perfectly reproducible problem. Has anyone seen something like this before? How do I get the installer to run?
Sourish
TimP
Among the peculiarities of VTune is that it can't coexist with other versions of VTune.  So you must search out and uninstall all versions of VTune before installing a new one.
Kevin_D_Intel
What you described occurring is not expected. We expect the Modify to proceed and suggest components that can be installed.
I will open a private communication with you to see if we can gather some logs from you to help us investigate the apparent second installer instance.
ashish5679
Why private conversation, please post reult in forum.
Sourish_B_
@Tim: I don't have any other version of VTune installed. What the installer is finding is another installer process running, not another VTune installed.
@Kevin: Thanks! I look forward to the debugging process.
Kevin_D_Intel
Sourish - Thank you again for the details you provided. I forwarded those to our Installation Development team (see internal tracking id below) for their analysis and will keep you posted on what they find.
(Internal tracking id: DPD200375186)
(Resolution Update on 11/20/2015): This defect is fixed in the Intel® Parallel Studio XE 2016 Update 1 Release (PSXE 2016.1.056 - Linux)
Kevin_D_Intel
Sourish - I know you have the work around for this for PSXE 2015. I just received confirmation from Development that the underlying defect is also now fixed in our upcoming PSXE 2016 Update 1 release due out shortly.
Thank you for making us aware of this defect.
Saibal_A_
Sourish/Kevin - Can you please let us know the work around? I am facing the exact same issue.
Kevin_D_Intel
@Saibal - I sent you a private communication.
Cesar_M_1
Maybe someone could make the solution public, since I am having the same problem.
Kevin_D_Intel
The "solution" is to use the PSXE 2016 Update 1 or later which contain the officially supported fix. The work around I do not want to make public.
Are you unable to use our latest PSXE 2016 Update 3 release?
Michael_G_2
I have the same issue as described in this thread.  Could you kindly send me the workaround? I'm on a linux machine.
