29268 Discussions
Intel Fortran 2013 slow compilation with Openmpi
htg20
I have a Fortran 2003 based code with MPI. I have compiled Openmpi 1.6.1 from souce with Intel 2013 and try to compile my code. Without using MPI (using fake mpi subroutines) everything works fine. However, when I use MPI commands, for the last files the ifort freezes or it compiles very very slow.
Any hint what might be the problem?
Cheers
Hossein
TimP
It will be very difficult for anyone to comment, if you can't tell us a few things, such as what OS and which ifort are you using, and your compile and link options. For example, excessive use of IPO with limited RAM or 32-bit mode compilation might be a cause of slow linking.
htg20
Hi all,
I looked into the problem more..
I use Openmpi 1.6.3 , intel Fortran 13.1.0.146 (the latest) on Ubuntu 12.1-x64.  The flags to compile are:
ifort  -I/opt/openmpi/1.6.3_intel/include -I/opt/openmpi/1.6.3_intel/lib -L/opt/openmpi/1.6.3_intel/lib   -cpp     -O0 -debug -traceback   -check all,noarg_temp_created  -ftrapuv -openmp  -m64    -w -fpp   -lmpi_f90 -lmpi_f77 -lmpi -ldl -lm -Wl,--export-dynamic -lrt -lnsl -luti
It seems ifort does not like such a thing (subroutine below).:
     use compute_homogen_val_class ,gugu1 =>computes_add
Gfortran does not compile this if I remove ( ,gugu1 =>computes_add ) since it is ambigious. However, if I remove this mpif90(ifort) compiles with no complains, which I think is not compatible with the standard. When  add this, then intel hangs for compiling that file.
subroutine computes_add(keyword,num_kwl,computes,ncomputes,compute_id,parts)
use compute_jintegral_class ,gugu2 =>computes_add
use compute_mcouplerr_class ,gugu3 =>computes_add
use compute_testc_class ,gugu4 =>computes_add
use compute_nodalhvar_class , gugu5=>computes_add
! include "compute_style2.h" ! run the perl script (perl makestyle.pl) to generate this file
use style_create_mod
implicit none
!------------------- INOUT variables------------------
character(*) :: keyword(:) !the keyword
integer :: num_kwl !number of keyword lines
type(ptr_ty_compute_base) :: computes(:)
integer :: ncomputes, compute_id
type(ty_part) :: parts
!--------------------LOCAL variables------------------
end subroutine computes_add
Steven_L_Intel1
Please provide a complete compilable source we can try.
htg20
Dear Steve,
It is a big project and it is not open source yet. Please provide an email so I can share the source files with you.
Steven_L_Intel1
Use Intel Premier Support - https://premier.intel.com/ ; Include a link to this thread.
htg20
I have uploaded the sourve files to Google project, please download from here:
http://code.google.com/p/permix/source/checkout
You can compile with:   make intel_ompi_min
To get minimum dependancies and intel compiler.
htg20
After sometime I tried to look into the problem in more detail. So, I tried to limit the namespace of the modules by the 'only' keyword. So, eventually the compilation time drastically reduced and also this problem is solved now.
Though, I still not sure if there is no problem with the compiler.
Steven_L_Intel1
There may still be a problem - we'll see if we can reproduce it from your source.
