29267 Discussions
Intel Parallel Studio XE 2016 is now available!
Steven_L_Intel1
Intel Parallel Studio XE 2016, including Intel Fortran Compiler 16.0, is now available. If your support license is current you can download and install this at no additional charge from the Intel Registration Center
Licensing Changes
With the 2016 version of our products, we are enforcing a limit of three installs per named-user license. If you have been a user of earlier versions, you'll need to upgrade the license file on your system in order to use the 2016 versions. (Earlier product versions will work with the new license.) The simplest way to do this is to reenter your serial number when prompted during install, but there are other options. Please refer to the following articles for more information:
If you need help with licensing, please ask in our Licensing, Registration and Downloads forum or Intel Premier Support
Z_Zhao
This comment has been moved to its own thread
