29274 Discussions
Internal compiler error with lock/unlock
Arjen_Markus
I have run into an ICE with the program below. The compiler version I use is: Intel Fortran 12.0.3 under Linux. The program may not be correct, but the compiler does not give any message, except for the ICE.
Arjen
! primes_coarrays.f90 --
! Determine the first 1000 primes - using coarrays
program primes_coarrays
use, intrinsic :: iso_fortran_env, only: lock_type
implicit none
type(lock_type), codimension
  • :: primes_lock
  • integer, dimension(2), codimension
  • :: range
  • integer, dimension(1000), codimension
  • :: prime
  • integer, codimension
  • :: number_primes
  • logical, codimension
  • :: new_results
  • :: new_task
  • :: ready
  • ready = .false.
    new_results = .false.
    new_task = .false.
    number_primes = 0
    range(2) = 0
    ! Create tasks in image 1 and handle them in all images
    do while ( .not. ready )
    if ( this_image() == 1 ) then
    call add_task
    endif
    call get_task
    enddo
    write(*,'(10i5)') prime
    contains
    ! Subroutine to post a new task (consisting of a
    ! range of integers in which to look for primes)
    ! Loop over the images to see which one wants a
    ! new task
    subroutine add_task
    integer :: i
    do i = 1,num_images()
    if ( .not. new_task ) then
    range(1) = range(2) + 1
    range(2) = range(2) + 100
    range = range[1]
    new_task = .true.
    endif
    enddo
    end subroutine add_task
    ! Subroutine to get a task and search for
    ! primes inside the new range
    subroutine get_task
    integer, dimension(100) :: new_prime
    integer :: lower
    integer :: upper
    logical :: isprime
    logical :: got_task
    integer :: np
    integer :: i
    integer :: j
    integer :: residue
    integer :: maxindex
    got_task = .false.
    np = 0
    if ( new_task ) then
    lower = range(1)
    upper = range(2)
    new_task = .false.
    got_task = .true.
    endif
    if ( got_task ) then
    write(*,*) 'Range: ',lower, upper, this_image()
    do i = lower,upper
    isprime = .true.
    do j = 2,int(sqrt(real(i)))
    residue = mod(i,j)
    if ( residue == 0 ) then
    isprime = .false.
    exit
    endif
    enddo
    if ( isprime ) then
    np = np + 1
    new_prime(np) = i
    endif
    enddo
    endif
    ! Now put the results in image 1
    lock( primes_lock )
    maxindex = min( size(prime) - number_primes[1], np )
    prime(number_primes+1:number_primes+maxindex)[1] = &
    new_prime(1:maxindex)
    number_primes[1] = number_primes[1] + maxindex
    ready[1] = number_primes[1] >= size(prime)
    unlock( primes_lock )
    endif
    end subroutine get_task
    end program primes_coarrays
    Arjen_Markus
    Jim,
    no luck: the same result.
    Arjen
    jimdempseyatthecove
    Arjen,
    What happens with
    program HelloCoarrays
    write(*,*) "Hello world from ", this_image()
    end program HelloCoarrays
    (compile for co-arrays)
    Does the above hang on exit too?
    Jim
    Arjen_Markus
    Hi Jim,
    no, that works okay. Hm, maybe I should reduce my program to the point
    where it does correctly finish (at the expense of doing even less useful things)
    I will let yyou know how I fare with that.
    Arjen
    Arjen_Markus
    I have experimented with a reduced version of the program, but nothing definite transpires.
    The preliminary conclusion I think I can formulate is that it is the number of updates to the
    prime array that is causing this. When I limited that (losing lots of information), it did finish
    when all threads finished.
    For the time being I can investigate an alternative solution - have thread 1 do all the updating.
    Arjen
    jimdempseyatthecove
    Try this: at the very end of the program insert
    if(this_image() == 1) then
    read(*,'(A)') line ! wait for user input
    endif
    end program yourProgramNameHere
    add/reuse some character variable for line
    then run the program but do not enter the text. i.e. let the program hang waiting for input.
    In a seperate window run your favorite utility to see what is running on the system, in particular do you see one image running or multiple images running. The seperate images should have exited. If they have exited, then go back to the waiting image and press Return. See if this exits the program.
    What I am asking you to check for is if there is a exit sequencing problem. If this seems to work then consider replacing the read with a call sleepqq(100) or some time interval long enough for the other images to exit.
    Hopefully this will provide you with a work around until Intel can fix the problem.
    If it doesn't work and the time difference is significant, the I suggest adding code at the end to get your process ID then issue a KILL process of that ID. A rather nasty way of working around the problem.
    Jim Dempsey
    Arjen_Markus
    Hi Jim,
    what I see is that even though the threads reach the STOP statement, except for thread 1 that is
    waiting for the input, all remain active.
    As this is an example, not a critical thing, I will leave this version for the moment and see if my alternative
    has more of a chance to work.
    Arjen
    The internal compiler error has been fixed in our sources. I expect the fix to appear in a compiler later this year.
