Linker Tools Error LNK1104
hiskiyas
I have a multi language software system Ada, fortran, and C++ the software compiled fine with previous compiler I had which is CVF 6.0, Visual c++, Ada. all in MS Development studio 6.0 environment. We added Intel fortran 7.0. After few changes in the fortran code the software compiled with Intel Fortran compiler, but gave me linker error "Linker Tools Error LNK1104" can not open file libIEPCF90.lib. I checked the environment variable to see when the Intel fortran installed the library path put correctly. And the path is showing the correct path.
Why is it giving me this error?
Do I need to enter the path in the studio or look at some place else to check the path?
gfthomas8
Within VS
Tools/Options/Directories
From MyComputer, rgtclk, System Properties
Advanced/Environmental Variables
HTH,
Gerry T.
