29297 Discussions
Linker: error: incompatible calling convention declarations for routine ?
MikeWinsteps
Folks, compiling with IFORT 2021.9 under Windows with VS 17.5.
I have about 50 "DialogBoxParam" call-back functions, all with the same interface, etc. They compile correctly, but the Linker complains about two:
"": error: incompatible calling convention declarations for routine mrwe_arrows
the Linker puts this message in the Error List 3 times, though the routine is called about 50 times.
"": error: incompatible calling convention declarations for routine mrwe_pifile
the Linker puts this message in the Error List 6 times, though the routine is called 2 times.
Any suggestions about what is going on?
andrew_4619
Yes the callbacks need to be stdcall convention. The interface I use look like:
    INTERFACE
       FUNCTION DialogBoxParam( hInstance, lpTemplateName, hWndParent, lpDialogFunc, dwInitParam) BIND(C,NAME="DialogBoxParamA")
          import
          integer(INT_PTR) :: DialogBoxParam ! INT_PTR
          !DIR$ ATTRIBUTES STDCALL :: DialogBoxParam
          !GCC$ ATTRIBUTES STDCALL :: DialogBoxParam
          integer(HANDLE), value :: hInstance ! HINSTANCE hInstance
          integer(LPVOID), value :: lpTemplateName ! LPCSTR lpTemplateName
          integer(HANDLE), value :: hWndParent ! HWND hWndParent
          integer(LPVOID), value :: lpDialogFunc ! DLGPROC lpDialogFunc
          integer(LONG_PTR), value :: dwInitParam ! LPARAM dwInitParam
       END FUNCTION
    END INTERFACE
 The !GCC$ line is for gfortran..... If you are using module IFWIN the implementation may look a little different I did not check.
MikeWinsteps
Thanks, Andrew. The solution was simple: rewrite the code so that each of those two functions was only called from one place. It seems that the Linker detected differences between the multiple calls to each function that were invisible to me.
andrew_4619
bizarre, maybe I should open a new thread. Today I get exactly the same error (3 times),  the error is not given with a debug build but is with a release build.  The call back is in a module, it has an explicit interface. It has worked OK yesterday (and for a long time before that also).  And it seems to create a functional exe despite the error message. Any ideas? I am suspecting a problem in the compiler making duff input for the linker.
jimdempseyatthecove
You may have a build dependency order issue. Try a Rebuild Build All
A related issue is when the configuration is missing a Build check box check in the Configuration Manager for the specific Configuration and Platform.
Also, what happens when you change the last argument type to LPVOID?
Jim Dempsey
andrew_4619
I get the error in Ifort in release  but all other ifort/ifc/release/debug combination do not get the error.
Linking...
"": error: incompatible calling convention declarations for routine ViewsDlgProc
Embedding manifest...
Further I have other stdcall callbacks with exactly the same usage case that work just fine.
andrew_4619
Did anyone at Intel look at this , note that the error message is malformed with "" as the start suggesting something is missing.
Barbara_P_Intel
@andrew_4619, do you have a reproducer? You knew I'd ask, didn't you?
JohnNichols
Valued Contributor III
@Barbara_P_Intel ,
Thank you for the smile in my mind in the morning,  there are three great statements in life:
1. Let there be light ------------ and Fortran was born
2. What is the meaning of life, the number after the 13th prime, although 1 is a prime, I will talk to God about this mistake in the end.  Of course, @mecej4 , can explain why I am wrong.  I read part of Wiles proof of the Fermat's Last Theorem, Wiles is not a normal human bean.
3. Do you have a reproducer ---    I will not comment as it is just two beautiful for words.  (Two is not a mistake)
4. Dad you are a loser --- from my last daughter on being angry with something I said.
You may all decide the incorrect answer.
andrew_4619
I can't submit the whole project as a reproducer, I will attempt to create one however I have a concern that is may be difficult as there are other call back routines in the code with the same interface/attributes that cause no issues.
