Linking .dll files to a FORTRAN 90 program in Microsoft VS community 2015
Vahid_H_
Einsteiger
4.018Aufrufe
I have difficulty to Link .dll files to FORTRAN 90 program in Microsoft VS community 2015. Any help would be appreciated. Thank you.
11 Antworten
Steve_Lionel
Geehrter Beitragender III
4.018Aufrufe
Please explain in more detail what you are trying to do (attaching a ZIP of the buildlog.htm from the failed build would be helpful.)
I hope that you are aware that one does not link to DLLs - instead you link to the export library (.LIB) created when the DLL was built. If you don't have that, you will need to use dynamic loading - a worked example is provided in the Intel Fortran samples as DLL\DynamicLoad.
Vahid_H_
Einsteiger
4.018Aufrufe
a
Vahid_H_
Einsteiger
4.018Aufrufe
Thank you for your response, Steve.
The code is linked to export library as shown in the attached pictures; however, it is not working since the .dd files are missed. My problem is that how can I define the path to .dll files in Fortran. I was successful to run this code by pasting all the required .dll files in the code folder but it is a messy way to do this.  Attached, there is a copy of the code.
Steve_Lionel
4.018Aufrufe
Windows has rules for how it locates DLLs at run-time - this isn't something you do in Fortran. The order is (if I have this right):
  1. The current directory
  2. The directory containing the EXE
  3. Directories named in the PATH environment variable
  4. The Windows directory
  5. The Windows\System32 directory
Typically people copy DLLs into the same folder as the exe for use when the exe is run.
Vahid_H_
Einsteiger
4.018Aufrufe
even If the PATH is set to the folder of .dll files, the code gives the same error.
Steve_Lionel
4.018Aufrufe
So where is libmat.dll? And is it a 32-bit or 64-bit DLL?
Download Dependency Walker . Run it from the command line while in the directory with the EXE and have it open your EXE. Does it show any missing DLLs? (Ignore "delay-load" messages.)
mecej4
4.018Aufrufe
You need to add the Matlab bin\<arch> directory to PATH before attempting to run the EXE that is produced by linking with libmx.lib and libmat.lib.
Vahid_H_
Einsteiger
4.018Aufrufe
There are two versions(32&64) of Matlab installed on this computer(64). Dlls are located here "C:\MATLAB_32bits\bin\win32". The result of using Dependency Walker is attached.
Vahid_H_
Einsteiger
4.018Aufrufe
C:\MATLAB_32bits\bin\; is in the PATH but still doesn't work.
mecej4
4.018Aufrufe
That path component is incomplete; it should be C:\MATLAB_32bits\bin\win32 .
Vahid_H_
Einsteiger
4.018Aufrufe
Sorry, the address is set to C:\MATLAB_32bits\bin\win32 in my system. The address was not written correctly before.
mecej4 wrote:
Antworten
