Ankündigungen
ListView Not Working in Intel Paralles Studio 2018
salim__karen
Einsteiger
3.716Aufrufe
Hello, and thanks in advance, is there a compatibility compilation propertie that should be added to ensure the gui funcionalities on a ivf 2011 program?
thanks,
1 Lösung
Steve_Lionel
Geehrter Beitragender III
3.716Aufrufe
I spent the past couple of days converting an ancient (1994!) MSDN ListView C sample to Intel Fortran. It mostly works - in that the ListView displays properly. Some other aspects of the program don't work for reasons I haven't yet figured out, and it doesn't help that the C version doesn't work at all. But it works enough to tell me that display of the listview is ok.
There is allegedly a simpler Listview sample in the current Windows SDK, but it won't install for me and I can't figure out why.
I may continue playing with this when I have the time. It's an interesting example. Here's a screenshot.
Lösung in ursprünglichem Beitrag anzeigen
13 Antworten
Steve_Lionel
3.716Aufrufe
You're going to have to provide a lot more information - ideally a small but complete sample program (a ZIP of a complete project would be best) and an explanation of the behavior you find incorrect. There is no compiler option related to Windows GUI support. Typically a Windows GUI program would be built as a "Windowing Application" project type with a WinMain entry point.
I'm also a bit confused by your referring to "ivf 2011" and "Parallel Studio 2018". Which are you using?
salim__karen
Einsteiger
3.716Aufrufe
Hi Steve! Thanks for the reply,
I have a program compiled with Visual Studio 2010 and Fortran 2011.  When upgrading to Visual Studio 2017 and Fortran compiler 2018, the program runs ok but the listview functionality is not displaying its columns like it used to show. Is there a Run-time configuration or is a code difference that we should address?
I am attaching the before/after images.
Steve_Lionel
3.716Aufrufe
Can you show us a small but complete example? I'm not aware of anything you should have needed to change. I've never tried the ListView control, though.
salim__karen
Einsteiger
3.716Aufrufe
Hey, thanks again for the reply and help
Here is where the report is updated:
Subroutine Update
! INit code
   lret = InitLVColumns ()
!some code
   i = SendMessage (hwndLV, LVM_SETITEMCOUNT, ipar, LVSICF_NOINVALIDATEALL)
   If (RepDef.szRep * RepDef.NCol < 3000) Then
      Call WndRep_ColumnsWidth (.true.)
   EndIf
   End Subroutine Update
And here is where de columns are created:
   Logical Function InitLVColumns ()
! Init Code
   ! Initialize the LVCOLUMN structure.
   col.mask = ior(LVCF_FMT, ior(LVCF_SUBITEM, ior(LVCF_TEXT, LVCF_WIDTH)))
   col.fmt = LVCFMT_LEFT
   col.cx = 80
   !col.cx = (rcList.right - rcList.left)/7
   Do i = 1, RepDef.NCol
      col.PSZTEXT = loc(RepDef.ColName(i))
      col.iSubItem = i-1
      ipar = i-1
      ret = SendMessage (hwndLV, LVM_INSERTCOLUMNA, ipar, loc(col))
      ret = SendMessage (hwndLV, LVM_SETCOLUMNA, ipar, loc(col))
      If (ret == -1) Then
         WndRep_InitLVColumns = .false.
         Return
      EndIf
   EndDo
   WndRep_InitLVColumns = .true.
   End Function InitLVColumns
The listview is a virtual list that displays with
 Case (LVN_GETDISPINFO)
            p2 = lparam
            If (IAnd(LVDispInfo.item.mask, LVIF_TEXT)) Then
               iSb = LVDispInfo.item.iSubItem
               iIt= RepIdx(LVDispInfo.item.iItem + 1)
               If (iSb == 0) Then
               ElseIf (iSb > 0) Then
               EndIf
            EndIf
the LVColumn it doesn't return true
and the
but LVDispInfo.Item.iSubitem also is always zero with the new compiler 2018. Can´t figure it out why is not working.
thanks,
ZlamalJakub
Neuer Beitragender III
3.716Aufrufe
I had problems with ListView and 2018 compiler too. Problem was caused by wrong integer type of callback functions I have used to cubclass window procedures. My code was 15 years old and I did not care about correct data types.
Correct type is integer(LRESULT)
I hope it helps.
Are you compiling 64bit or 32bit application?
Steve_Lionel
3.716Aufrufe
Please attach a ZIP of a small but complete example that shows the problem. We can't do much with snippets of code.
Steve_Lionel
3.717Aufrufe
salim__karen
Einsteiger
3.716Aufrufe
hi Steve
Thanks again !! And I’m glad that works in C that’s indicates that should work for me too. I’m still investigating.As the code is large and we intend to turn it 64b, I am hopping that the integer  handle as Zlamal mentioned could be a good start. I should try a small example to see if all turns ok. As for now nothing is reallying working.
I’ll post here if I can get this right for the small case. Thanks again and let me know if you have some other issue that I should address.
Steve_Lionel
3.716Aufrufe
The version I have mostly working is Fortran. The C version throws many errors from the C compiler, and while the Listview displays, the contents are all random characters. Initially the C code would not build at all, but I managed to bypass the severe errors. I am not all that good in C and I didn’t feel like trying to track down all the complaints.
The parts that don’t work are the column sorting (I can see my compare routine being called, but nothing gets sorted), and the two alternate view modes for the list. If you think it will be helpful I’ll upload a zip of the project.
Steve_Lionel
3.716Aufrufe
I've attached my Fortran version of the ListView sample. Now everything works except the sorting. I can see that the sort happens, but the items continue to be displayed in their original order. The only other ListView samples I can find, including the one at Github where Microsoft moved all the samples, use a different API that has no bearing on the message-based one.
I also attached the C version. I don't trust all the comments in the C code, as I found some of them are inaccurate.
salim__karen
Einsteiger
3.716Aufrufe
Hi Steve,
Thanks for  the archive! I`ll let you now if i figure it out my problem here. As I said it is a large code and we intend to migrate.
Steve_Lionel
3.716Aufrufe
Doing this conversion was an interesting learning experience for me, as it often has been when translating MSDN samples over the years.
Paul_Curtis
Geschätzter Beitragender I
3.716Aufrufe
Here is a set of ListView wrapper functions.  This is 32-bit code with 4-byte default integers, may have to be modified for 64-bits.
! List view functions
! Adds a new column to a list view. The columnIndex is both the
! column position in the list view and the index of the associated
! subitem. The title is displayed for the column in the list view
! header, and the width is the column width in pixels.
SUBROUTINE ListViewAddColumn (hwnd, controlId, columnIndex, title, width, extraFormat)
    IMPLICIT NONE
    INTEGER(HANDLE), INTENT(IN)    :: hwnd
    INTEGER, INTENT(IN)            :: controlId
    INTEGER, INTENT(IN)            :: columnIndex
    CHARACTER(LEN=*), INTENT(IN)   :: title
    INTEGER, INTENT(IN)            :: width
	INTEGER, INTENT(IN),OPTIONAL   :: extraFormat
    TYPE(T_LV_COLUMN)              :: column
    INTEGER                        :: rval
    column%iSubItem = columnIndex
    column%pszText  = LOC(title)
    column%cx       = width
    column%mask     = IOR(LVCF_SUBITEM, LVCF_WIDTH)
	! extraFormat denotes text_is_centered or item_is_an_image
	IF (PRESENT(extraFormat)) THEN
		column%fmt = extraFormat
		column%mask = IOR(LVCF_FMT, column%mask)
		IF (extraFormat /= LVCFMT_IMAGE) column%mask = IOR(column%mask, LVCF_TEXT)
	!	if there is no extra argument, text content is assumed
	ELSE
	END IF
	rval = SendControlMessage(hwnd, controlId, LVM_INSERTCOLUMN, columnIndex, LOC(column))
    IF(rval == -1) THEN
        CALL ControlError("ListViewAddColumn", controlId, "failed")
    END IF
END SUBROUTINE ListViewAddColumn
! Returns the number of items in a list view.
INTEGER FUNCTION ListViewGetNumItems(hwnd, controlId)
    IMPLICIT NONE
    INTEGER                        :: rval
    rval = SendControlMessage(hwnd, controlId, LVM_GETITEMCOUNT, 0, 0)
    IF(rval >= 0) THEN
        ListViewGetNumItems = rval
    ELSE
        CALL ControlError("ListViewGetNumItems", controlId, &
            "LVM_GETITEMCOUNT")
        ListViewGetNumItems = 0
    END IF
END FUNCTION ListViewGetNumItems
SUBROUTINE ListViewWideHighlight (hwnd, controlId)
    IMPLICIT NONE
    INTEGER                        :: rval
    rval = SendControlMessage (hwnd, controlId,					&
							   LVM_SETEXTENDEDLISTVIEWSTYLE,	&
							   LVS_EX_FULLROWSELECT,			&
							   LVS_EX_FULLROWSELECT)
END SUBROUTINE ListViewWideHighlight
!	enable hover-detection for a listview control; hover information
!	is returned via LVN_HOTTRACK messages within WM_NOTIFY, and in this
!	program HandleListViewClick is used to resolve the selected item
SUBROUTINE ListViewHoverEnable (hwnd, controlId)
    IMPLICIT NONE
    INTEGER                        :: rval
							   LVS_EX_TRACKSELECT,				&
							   LVS_EX_TRACKSELECT)
END SUBROUTINE ListViewHoverEnable
! Removes all the items in a list view.
SUBROUTINE ListViewDeleteAllItems (hwnd, controlId)
    IMPLICIT NONE
    INTEGER                        :: rval
    rval = SendControlMessage(hwnd, controlId, LVM_DELETEALLITEMS, 0, 0)
    IF (rval == 0) THEN
        CALL ControlError("ListViewDeleteAllItems", controlId, &
            "LVM_DELETEALLITEMS")
    END IF
    rval = SendControlMessage(hwnd, controlId, LVM_UPDATE, 0, 0)
    IF( rval == 0) THEN
            "LVM_UPDATE")
    END IF
END SUBROUTINE ListViewDeleteAllItems
! Adds an item to a list view. Returns the 1-based item index,
! or -1 if the operation fails.
INTEGER FUNCTION ListViewAddItem (hwnd, controlId, name)
    IMPLICIT NONE
    CHARACTER(LEN=*), INTENT(IN)   :: name
    INTEGER                        :: rval
    INTEGER                        :: nItems
    TYPE(T_LV_ITEM)                :: item
    CHARACTER(LEN=200)             :: buffer
    buffer = name
    CALL NullTerminateString (buffer)
    nItems        = ListViewGetNumItems (hwnd, controlId)
    item%mask     = LVIF_TEXT
    item%iItem    = nItems
    item%iSubitem = 0
    item%pszText  = LOC(buffer)
    rval = SendControlMessage(hwnd, controlId, LVM_INSERTITEM, 0, LOC(item))
    IF(rval /= -1) THEN
        ListViewAddItem = rval + 1
    ELSE
        CALL ControlError("ListViewAddItem", controlId, "LVM_INSERTITEM")
        ListViewAddItem = -1
    END IF
END FUNCTION ListViewAddItem
! Sets the text in a column for a single item in a list view control.
!                                             itemindex = row
SUBROUTINE ListViewSetColumn (hwnd, controlId, row, column, text, color)
    IMPLICIT NONE
    INTEGER, INTENT(IN)            :: row
    CHARACTER(LEN=*), INTENT(IN)   :: text
	INTEGER, INTENT(IN), OPTIONAL  :: color
    INTEGER                        :: rval
	IF (PRESENT(color)) then
		rval = SendControlMessage (hwnd, controlId, LVM_SETTEXTCOLOR, 0, color)
	END IF
    buffer = text
    CALL NullTerminateString(buffer)
    item%iItem    = row - 1		! row    is 1-based
    item%iSubitem = column		! column is 0-based
    rval = SendControlMessage (hwnd, controlId, LVM_SETITEM, 0, LOC(item))
    IF (rval == -1) THEN
        CALL ControlError("ListViewSetColumn", controlId, "LVM_SETITEM")
    END IF
END SUBROUTINE ListViewSetColumn
SUBROUTINE ListViewSetImage (hwnd, controlId, row, column, image)
    IMPLICIT NONE
    INTEGER, INTENT(IN)            :: image
    INTEGER                        :: rval
    item%mask     = LVIF_IMAGE
    item%iImage   = image
        CALL ControlError("ListViewSetImage", controlId, "LVM_SETITEM")
    END IF
END SUBROUTINE ListViewSetImage
SUBROUTINE ListViewSetColumnHeader (hwnd, controlId, zb_colpos, text)
    IMPLICIT NONE
    INTEGER, INTENT(IN)            :: zb_colpos		! zero-based column position
    INTEGER                        :: rval
    TYPE(T_LVCOLUMN)               :: lvcolumn
    CHARACTER(LEN=100)             :: buffer
    buffer = text
    lvcolumn%mask		= LVCF_TEXT
    lvcolumn%pszText	= LOC(buffer)
    lvcolumn%cchTextMax	= INDEX(buffer,CHAR(0))
	rval = SendControlMessage (hwnd, controlId, LVM_SETCOLUMN, zb_colpos, LOC(lvcolumn))
        CALL ControlError("ListViewSetColumnHeader", controlId, "LVM_SETCOLUMN")
    END IF
END SUBROUTINE ListViewSetColumnHeader
! Sets the specified item in a list view control to selected. The
! index argument is 1-based.
SUBROUTINE ListViewSetSelectedIndex(hwnd, controlId, index)
    IMPLICIT NONE
    INTEGER, INTENT(IN)            :: index
    INTEGER                        :: rval
    item%iItem     = index - 1
    item%iSubitem  = 0
    item%mask      = LVIF_STATE
    item%state     = LVIS_SELECTED
    item%stateMask = LVIS_SELECTED
        CALL ControlError("ListViewSetSelectedIndex", controlId, &
            "LVM_SETITEM")
    END IF
END SUBROUTINE ListViewSetSelectedIndex
SUBROUTINE ListViewDeselect (hwnd, controlId)
    IMPLICIT NONE
    INTEGER				           :: index
    INTEGER                        :: rval
	index = ListViewGetSelectedIndex (hwnd, controlId)
	IF (index /= -1) THEN
		item%iSubitem  = 0
		item%state     = 0
				"LVM_SETITEM")
        END IF
	END IF
END SUBROUTINE ListViewDeselect
! Returns the 1-based index of the currently selected item in a list view,
! or -1 if nothing is selected.
INTEGER FUNCTION ListViewGetSelectedIndex (hwnd, controlId, top) RESULT(index)
    IMPLICIT NONE
	INTEGER, INTENT(INOUT),OPTIONAL:: top
    INTEGER                        :: rval
    INTEGER                        :: nItems
    TYPE(T_LV_ITEM)                :: lvitem
	TYPE(T_RECT)				   :: rect
    INTEGER                        :: i
    DO i = 0, nItems - 1
        lvitem%mask		 = LVIF_STATE
        lvitem%iItem	 = i
        lvitem%iSubitem	 = 0
        lvitem%stateMask = LVIS_SELECTED
        rval = SendControlMessage (hwnd, controlId, LVM_GETITEM, 0, LOC(lvitem))
        IF(rval /= 0) THEN
            IF (lvitem%state == LVIS_SELECTED) THEN
                IF (PRESENT(top)) THEN
					rval = SendControlMessage (hwnd, controlId, LVM_GETITEMRECT, i, LOC(re
					top = rect%top
				END IF
				index = i + 1
                RETURN
            END IF
        ELSE
            CALL ControlError("ListViewGetSelectedItem", controlId, "LVM_GETITEM")
        END IF
    END DO
    index = -1
END FUNCTION ListViewGetSelectedIndex
! Associates an integer value with a list view item, which can later
! be retrieved with ListViewGetItemData.
!  If the data is being stored for later use with NM_CUSTOMDRAW, such as
!  for setting a custom color for each element in the LV, this associated
!  integer vaue is returned within the NM_CUSTOMDRAW data structure as
!                nmlvcd%nmcd%lItemlParam
SUBROUTINE ListViewSetItemData (hwnd, controlId, index, valu)
    IMPLICIT NONE
    INTEGER, INTENT(IN)            :: valu
    INTEGER                        :: rval
    item%iSubitem = 0
    item%mask     = LVIF_PARAM
    item%lparam   = valu
    rval = SendControlMessage(hwnd, controlId, LVM_SETITEM, 0, LOC(item))
    IF(rval == -1) THEN
        CALL ControlError("ListViewSetItemData", controlId, "LVM_SETITEM")
    END IF
END SUBROUTINE ListViewSetItemData
! Retrieves an integer data value associated with a list view item.
! If the operation fails, -1 is returned.
INTEGER FUNCTION ListViewGetItemData(hwnd, controlId, index) RESULT(valu)
    IMPLICIT NONE
    INTEGER                        :: rval
    item%iSubitem = 0
    rval = SendControlMessage(hwnd, controlId, LVM_GETITEM, 0, LOC(item))
    IF(rval /= -1) THEN
        valu = item%lparam
    ELSE
        CALL ControlError("ListViewGetItemData", controlId, "LVM_GETITEM")
        valu = -1
    END IF
END FUNCTION ListViewGetItemData
! Retrieves the integer data value associated with the currently
! selected item in the list view, or -1 if no item is currently
! selected.
INTEGER FUNCTION ListViewGetSelectedData(hwnd, controlId) RESULT(valu)
    IMPLICIT NONE
    INTEGER                        :: sel
    sel = ListViewGetSelectedIndex(hwnd, controlId)
    IF(sel /= -1) THEN
        valu = ListViewGetItemData(hwnd, controlId, sel)
    ELSE
        valu = -1
    END IF
END FUNCTION ListViewGetSelectedData
! Call this function in response to the NM_CLICK message.  It
! causes a row to be selected if it is clicked on anywhere, not
! just in the first column.
SUBROUTINE HandleListViewClick (hwnd, controlId, got_one)
    IMPLICIT NONE
	LOGICAL, INTENT(OUT),OPTIONAL  :: got_one
    INTEGER                        :: rval
    INTEGER                        :: nItems
    INTEGER(HANDLE)                :: hwndControl
    INTEGER                        :: i
    TYPE(T_POINT)                  :: position
	IF (PRESENT(got_one)) got_one = .FALSE.
	IF (n_enterwindows /= 0) RETURN
	! Probably should be GetMessagePos, but that's broken in DVF's
    ! headers, and this fills the bill OK.
    rval        = GetCursorPos (position)
    hwndControl = DialogGetControlWindow (hwnd, controlId)
    rval        = ScreenToClient (hwndControl, position)
    nItems = SendControlMessage (hwnd, controlId, LVM_GETITEMCOUNT, 0, 0)
        rect%left = LVIR_BOUNDS
        rval = SendControlMessage(hwnd, controlId, LVM_GETITEMRECT, i, LOC(rect))
        IF (PtInRect(rect, position)) THEN
            item%state		= IOR(LVIS_SELECTED, LVIS_FOCUSED)
            item%stateMask	= IOR(LVIS_SELECTED, LVIS_FOCUSED)
            rval = SendControlMessage (hwnd, controlId, LVM_SETITEMSTATE, i, LOC(item))
			IF (PRESENT(got_one)) got_one = .TRUE.
			EXIT
        END IF
    END DO
END SUBROUTINE HandleListViewClick
!	resolve a listview NM_HOVER message into the 1-based
!	index of the listview item which is being hovered over;
SUBROUTINE ListViewHover (hwnd, controlId, item)
    IMPLICIT NONE
    INTEGER, INTENT(OUT)           :: item
    INTEGER                        :: rval, i
    INTEGER                        :: nItems
			item = i + 1
			RETURN
		END IF
    END DO
	item = 0
Antworten
