Maximum Program Size
JohnNichols
Valued Contributor III
Steve:
I can now nicely run C# programs with the MKL libraries.  Thanks for the help. The PARDISO routine is 100 times faster than the other inversion program I was using. It is a very nice addition to the FORTRAN tool kit.
Even though it is listed as a sparse matrix solver, it will actually solve dense matrices. It will do a 12500 by 12500 array in 167 seconds. But as soon as I go over the 12,500 I run into the 2GB limit for Windows. I could move to our supercomputer, but that is a pain, can I use allocate to break the 2GB limit?
JMN
andrew_4619
You need to build a 64bit application for > 2GB
JohnNichols
https://software.intel.com/en-us/articles/memory-limits-applications-windows
Found this - which explains it - Steve wrote it
JMN
John_Campbell
New Contributor II
As well as the size limitations that Steve outlined for a 64-bit application, there are other limitations that need to be recognised.
Virtual memory limit: The maximum memory that can be allocated and used is limited by the size limits of the pagefile.sys. Although you can allocate a very large array, the limit of physical or virtual memory is not applied until the allocated array is being used. This can result in an error later in the program's execution.
Installed memory limit: The amount of installed memory also applies a practical limitation, as random access of virtual memory can significantly slow down the program run time. While this is not a limit on the addressable memory, it can be a definite practical limit. Use of programming techniques to localise memory usage can mitigate this problem. The aim is to sequentially address memory, which can be readily seen when using multi-dimension arrays. Simply re-ordering multiple DO loop sequences can result in a dramatic improvement of run time, much more so than the gains from other useful approaches like vector instructions or OpenMP approaches. The preferred solution is a combination of all these.
JohnNichols
Interesting, when I first started on computing we had strict size limits, and we copied clever ways to minimize the pain, for a brief while in the 1990's and 2000's it was no longer a major issue for most programmers, but now it comes back.  How big is big enough?
I used to be able to design 4000 tonne bins with this program, I did not write it; it comes from Powell's group at UCB. I think I had the only electronic copy of the code for a while, it was on punch cards, then magnetic tape, then floppy drives and then CD's and now USB.  it took me 30 years to find the author - who works at Halliburton in Houston.
1EDGE BEAM FORCES FOR LOADING CASE NUMBER  1   - the 1 on the format line reminds me of the old punch cards at UNI -
      PROGRAM SHELL
        COMMON/ALL/NELEMS,R(100),Z(100),NODI(100),NODJ(100),NEQ,MBAND
        COMMON/MISD/NUMJTS,NUMLDS,KODE(100)
        DIMENSION TSTIFF(3000)
        CHARACTER*72 TITLE
100     CALL INPUT
!     ESTABLISH BAND WIDTH
      M=(MBAND-3)/3
      DO 110 I =1,NELEMS
      J=IABS(NODJ(I)-NODI(I))
      IF(J.GT.M)M=J
  110 CONTINUE
      MBAND=3*M+3
      NEQ=3*NUMJTS
      NA=NEQ*MBAND
      IF(NA-3000)130,130,120
  120 WRITE(*,2000)
      WRITE(4,2000)
      GOTO 100
130 CALL STIFF(TSTIFF,NEQ,MBAND)
      CALL DISPL(TSTIFF,NEQ,MBAND)
77    WRITE(*,78)
78    FORMAT(/2X,'DO YOU WISH TO CONTINUE (1=Yes/2=No) ? '\)
      READ(*,88)N
88    FORMAT(I1)
      IF(N.LT.1.OR.N.GT.2)GOTO 77
      CLOSE(3,STATUS='KEEP')
      CLOSE(4,STATUS='KEEP')
      IF(N.EQ.1)GOTO 100
      IF(N.EQ.1)GOTO 100
2000  FORMAT(1H1,'NUMBER OF NODAL POINTS AND/OR NODAL POINT','EXCEEDS MAXIMUM ALLOWABLE.')
135    END
!         Subroutine Input for Data Files
        SUBROUTINE INPUT
        COMMON/ISS/C11I(100),C12I(100),C22I(100),C33I(100),C34I(100), C44I(100),&
        C11J(100),C12J(100),C22J(100),C33J(100),C34J(100), C44J(100)
        COMMON/ISDS/STATIC(600),SPRING(300),TLOAD(300),S(10),NFORM
        COMMON/BEAM/LOCJ(10,6),LOCC(10),BSTRES(30),BMOD(10),BAREA(10),&
                 YY(10),ZZ(10),PHI(10),TDIM(10),NBEAMS
        CHARACTER*64 FILEI,FILEO
        CHARACTER*72 TITLE
        WRITE(*,76)
76      FORMAT(//2X,'------------------------------------------------'/&
       ,/'          SHELL ANALYSIS PROGRAM',//,&
         '   Program date    : 7 July 2013'/'   Code Amendments : J.M. Nichols'/'   Version        : 1.1'//2X,&
      WRITE(*,79)
79    FORMAT(2X,'Input Filename (e.g. B:file.ext) ? '\)
      READ(*,77)FILEI
77    FORMAT(A)
      WRITE(*,86)
86    FORMAT(1X,'Output Filename (e.g. B:file.ext) ? '\)
      READ(*,87)FILEO
87    FORMAT(A)
!     OPEN EXISTING ( INPUT #3 ) AND NEW ( INPUT #4 ) FILES
      OPEN(3,FILE=FILEI,STATUS='OLD')
      OPEN(4,FILE=FILEO,STATUS='UNKNOWN')
      WRITE(4,111)FILEI,FILEO
111   FORMAT(//2X,'Input File : ',A,//1X,'Output File : ',A//)
!       Wriie Out Header Data
        WRITE(4,76)
!       CONTROL CARDS
!       Read the Title Cards
        READ(3,1000)TITLE
        WRITE(4,2001)TITLE
        Write(*,213)
213     Format('Reading Joint Cards')
        !Pause
        READ(3,*)NUMJTS,NELEMS,NUMLDS,NBEAMS,NFORM
        WRITE(4,2000)NUMJTS,NELEMS,NUMLDS,NBEAMS,NFORM
        WRITE(*,2000)NUMJTS,NELEMS,NUMLDS,NBEAMS,NFORM
!       JOINT CARDS
        WRITE(4,2010)
        WRITE(*,2010)
        NJ=1
        MJ=1
        DO 100 N=1,NUMJTS
            IF(MJ-NJ.GE.1) GOTO 90
            READ(3,*, END=4000)NJ, R(NJ),Z(NJ),KODE(NJ),S1,S2,S3
            IF(NJ-MJ.LE.1) GOTO 95
            DIV=NJ-MJ
            DR=(R(NJ)-R(MJ))/DIV
            DZ=(Z(NJ)-Z(MJ))/DIV
            NNJ=MJ
            MJ=NJ
            NJ=NNJ
90          NJ=NJ+1
            R(NJ)=R(NJ-1)+DR
            Z(NJ)=Z(NJ-1)+DZ
            KODE(NJ)=KODE(MJ)
            SPRING(3*NJ-2)=R(NJ)*S1
            SPRING(3*NJ-1)=R(NJ)*S2
            SPRING(3*NJ)=R(NJ)*S3
            GOTO 1011
95          MJ=NJ
1011        WRITE(*,2020)NJ, R(NJ),Z(NJ),KODE(NJ),S1,S2,S3
            WRITE(4,2020)NJ,R(NJ),Z(NJ),KODE(NJ),S1,S2,S3
100     End Do
!       ELEMENT CARDS
        Write(*,214)
214     Format('Reading Element Cards')
        WRITE(4,2030)
        Write(*,2030)
        !Pause
        M=0
        NE=1
        ME=1
        DO 130 N=1,NELEMS
            IF(ME-NE.GE.1) GO TO 101
            Write(*,*)NE
            Read(3,*)NE
            Write(*,*)NE
            READ(3,*)NODI(N),NODJ(N),MTYPE,INC
            Write(*,*)NODI(N),NODJ(N),MTYPE,INC
            !Pause
            IF(INC.EQ.0) INC=1
            IF(NE-ME.LE.1)GOTO 105
!           GENERATE INPUT DATA
            TL=0.0
            NN=NE-ME-1
            DO 75 L=1,NN
                NODI(ME+L)=NODI(ME+L-1)+INC
                NODJ(ME+L)=NODJ(ME+L-1)+INC
                I=NODI(ME+L)
                J=NODJ(ME+L)
                DR=R(J)-R(I)
                DZ=Z(J)-Z(I)
                DL=SQRT(DR**2+DZ**2)
                TL=TL+DL
75          End Do
                IF(MTYPE.GT.1) GOTO 80
            READ(3,*)TMI,E1MI,E2MI,P12MI,TBI,E1BI,E2BI,P12BI
            Write(3,*)TMI,E1MI,E2MI,P12MI,TBI,E1BI,E2BI,P12BI
            !Pause
            D1=(TMI-TMJ)/TL
            D2=(E1MI-E1MJ)/TL
            D3=(E2MI-E2MJ)/TL
            D4=(P12MI-P12MJ)/TL
            D5=(TBI-TBJ)/TL
            D6=(E1BI-E1BJ)/TL
            D7=(E2BI-E2BJ)/TL
            D8=(P12BI-P12BJ)/TL
            GOTO 85
80          READ(3,1040)YMODI,AREA1I,AREA2I,BEND1I,BEND2I
            D1=(YMODI-YMODJ)/TL
            D2=(AREA1I-AREA1J)/TL
            D3=(AREA2I-AREA2J)/TL
            D4=(BEND1I-BEND1J)/TL
            D5=(BEND2I-BEND2J)/TL
85          NNE=ME
            ME=NE
            NE=NNE
101         NE=NE+1
            IF(NE.EQ.ME) GO TO 102
            I=NODI(NE)
            J=NODJ(NE)
            DR=R(J)-R(I)
            DZ=Z(J)-Z(I)
!           MATERIAL PROPERTIES
102         IF(MTYPE.GT.1)GOTO 103
!     MATERIAL ORTHOTROPY
      TMI=TMJ
      TMJ=TMI+D1*DL
      E1MI=E1MJ
      E1MJ=E1MI+D2*DL
      E2MI=E2MJ
      E2MJ=E2MI+D3*DL
      P12MI=P12MJ
      P12MJ=P12MI+D4*DL
      TBI=TBJ
      TBJ=TBI+D5*DL
      E1BI=E1BJ
      E1BJ=E1BI+D6*DL
      E2BI=E2BJ
      E2BJ=E2BI+D7*DL
      P12BI=P12BJ
      P12BJ=P12BI+D8*DL
      IF(NE.EQ.ME)READ(3,1030)TMJ,E1MJ,E2MJ,P12MJ,TBJ,E1BJ,E2BJ,P12BJ
      WRITE(4,2050)NE,NODI(NE),TMI,E1MI,E2MI,P12MI,TBI,E1BI,E2BI,P12BI
      WRITE(4,2060)NODJ(NE),TMJ,E1MJ,E2MJ,P12MJ,TBJ,E1BJ,E2BJ,P12BJ
      GOTO 115
!     GEOMETRIC ORTHOTROPY
  103 YMODI=YMODJ
      YMODJ=YMODI+D1*DL
      AREA1I=AREA1J
      AREA1J=AREA1I+D2*DL
      AREA2I=AREA2J
      AREA2J=AREA2I+D3*DL
      BEND1I=BEND1J
      BEND1J=BEND1I+D4*DL
      BEND2I=BEND2J
      BEND2J=BEND2I+D5*DL
      IF(NE.EQ.ME)READ(3,1040)YMODJ,AREA1J,AREA2J,BEND1J,BEND2J
      WRITE(4,2080)NE,NODI(NE),YMODI,AREA1I,AREA2I,BEND1I,BEND2I
      WRITE(4,2090)NODJ(NE),YMODJ,AREA1J,AREA2J,BEND1J,BEND2J
      GOTO 125
!     READ INPUT DATA
  105 ME=NE
      IF(MTYPE.GT.1)GOTO 120
      IF(M.EQ.1)GOTO 110
      WRITE(4,2040)
      WRITE(*,2040)
  110 READ(3,*)TMI,E1MI,E2MI,P12MI,TBI,E1BI,E2BI,P12BI
      WRITE(*,2050)NE,NODI(NE),TMI,E1MI,E2MI,P12MI,TBI,E1BI,E2BI,P12BI
      READ(3,*)TMJ,E1MJ,E2MJ,P12MJ,TBJ,E1BJ,E2BJ,P12BJ
      WRITE(*,2060)NODJ(NE),TMJ,E1MJ,E2MJ,P12MJ,TBJ,E1BJ,E2BJ,P12BJ
      M=1
!     FORM MATERIAL STIFFNESS COEFFICIENTS
  115 C11I(NE)=TMI*E1MI**2/(E1MI-E2MI*P12MI**2)
      C22I(NE)=C11I(NE)*E2MI/E1MI
      C12I(NE)=P12MI*C22I(NE)
      C33I(NE)=TBI**3*E1BI**2/(12.0*(E1BI-E2BI*P12BI**2))
      C44I(NE)=C33I(NE)*E2BI/E1BI
      C34I(NE)=-P12BI*C44I(NE)
      C11J(NE)=TMJ*E1MJ**2/(E1MJ-E2MJ*P12MJ**2)
      C22J(NE)=C11J(NE)*E2MJ/E1MJ
      C12J(NE)=P12MJ*C22J(NE)
      C33J(NE)=TBJ**3*E1BJ**2/(12.0*(E1BJ-E2BJ*P12BJ**2))
      C44J(NE)=C33J(NE)*E2BJ/E1BJ
      C34J(NE)=-P12BJ*C44J(NE)
      GOTO 130
  120 IF(M.EQ.2)GOTO 121
      WRITE(4,2070)
  121 READ(3,*)YMODI,AREA1I,AREA2I,BEND1I,BEND2I
      READ(3,*)YMODJ,AREA1J,AREA2J,BEND1J,BEND2J
      M=2
  125 C11I(NE)=YMODI*AREA1I
      C22I(NE)=YMODI*AREA2I
      C12I(NE)=0.0
      C33I(NE)=YMODI*BEND1I
      C44I(NE)=YMODI*BEND2I
      C34I(NE)=0.0
      C11J(NE)=YMODJ*AREA1J
      C22J(NE)=YMODJ*AREA2J
      C12J(NE)=0.0
      C33J(NE)=YMODJ*BEND1J
      C44J(NE)=YMODJ*BEND2J
      C34J(NE)=0.0
  130 CONTINUE
!     EDGE BEAM CARDS
      M=0
      IF(NBEAMS.EQ.0) GOTO 160
      WRITE(4,3000)
      Write(*,2140)
2140     format('Edge beams')
      !Pause
      WRITE(*,3000)
      DO 150 L=1,NBEAMS
      READ(3,*)N,LOCC(N),(LOCJ(N,I),I=1,6)
      READ(3,*)BMOD(N),BAREA(N),YY(N),ZZ(N),PHI(N),TDIM(N)
      WRITE(4,3010)N,LOCC(N),LOCJ(N,1),BMOD(N),BAREA(N),YY(N),ZZ(N),PHI(N),TDIM(N)
      WRITE(*,3010)N,LOCC(N),LOCJ(N,1),BMOD(N),BAREA(N),YY(N),ZZ(N),PHI(N),TDIM(N)
      KK=0
      DO 140 K=1,6
      IF(LOCJ(N,K).LE.0) GOTO 145
      J=IABS(LOCC(N)-LOCJ(N,K))
      IF(J.GT.M) M=J
      KK=KK+1
  140 CONTINUE
  145 WRITE(4,3020)(LOCJ(N,K),K=2,KK)
  150 CONTINUE
  160 MBAND=3*M+3
      RETURN
 1000 FORMAT( A72)
 1010 FORMAT(I3,2F10.1,I3,3F10.1)
 1020 FORMAT(5I3)
 1030 FORMAT(3F10.1,F7.4,3F10.1,F7.4)
 1040 FORMAT(5F10.1)
 1050 FORMAT(8I3)
 1060 FORMAT(6F10.1)
 2001 FORMAT( A72)
 2000 FORMAT(/////,&
      35H NUMBER OF NODAL POINTS ---------- ,I3// &
      35H NUMBER OF ELEMENTS -------------- ,I3// &
      35H NUMBER OF LOADING CONDITIONS ---- ,I3// &
      35H NUMBER OF EDGE BEAMS ------------ ,I3//&
      35H Stress Condition Output---------- ,I3)
 2010 FORMAT(11H JOINT DATA//5H NODE,5X,6HRADIUS,5X,8HORDINATE,5X,&
      4HCODE,6X,35H********** JOINT SPRINGS **********/44X, &
      35HVERTICAL    HORIZONTAL   ROTATIONAL/)
 2020 FORMAT(1H ,I3,5X,F7.2,5X,F7.2,6X,I3,6X,1PE10.3,3X,E10.3,3X,E10.3)
 2030 FORMAT('ELEMENT DATA'/)
 2040 FORMAT(14H0ELEMENT  NODE,5X,47H************* MEMBRANE PROPERTIES *&
      ************,5X,47H************** BENDING PROPERTIES *************&
      //19X,9HTHICKNESS,6X,14HYOUNGS MODULUS,4X,14HPOISSONS RATIO,5X, &
      9HTHICKNESS,6X,14HYOUNGS MODULUS,4X,14HPOISSONS RATIO/33X, &
      5H(ONE),7X,5H(TWO),5X,9H(ONE-TWO),21X,&
      5H(ONE),7X,5H(TWO),5X,9H(ONE-TWO)//)
 2050 FORMAT(2X,I3,5X,I3,7X,F7.4,3X,1PE10.3,2X,E10.3,5X,0PF6.3,10X,F7.4,&
      3X,1PE10.3,2X,E10.3,5X,0PF6.3)
 2060 FORMAT(10X,I3,7X,F7.4,3X,1PE10.3,2X,E10.3,5X,0PF6.3,10X,F7.4,3X,1PE10.3,2X,E10.3,5X,0PF6.3/)
 2070 FORMAT(14H0ELEMENT  NODE,4X,14HYOUNGS MODULUS,6X,14HEFFECTIVE AREA&
      ,6X,27HEFFECTIVE MOMENT OF INERTIA/37X,5H(ONE),7X,5H(TWO),9X, &
      5H(ONE),7X,5H(TWO)//)
 2080 FORMAT(2X,I3,5X,I3,7X,1PE10.3,4X,1PE10.3,2X,1PE10.3,4X,1PE10.3,2X,&
      1PE10.3)
 2090 FORMAT(10X,I3,7X,1PE10.3,4X,1PE10.3,2X,1PE10.3,4X,1PE10.3,2X,1PE10.3/)
 3000 FORMAT(15H EDGE BEAM DATA///10H EDGE BEAM,4X,13HJOINT INDICES,4X,&
      14HYOUNGS MODULUS,5X,4HAREA,10X,17HMOMENT OF INERTIA,5X,&
      14HPRINCIPAL AXIS,3X,17HLARGEST DIMENSION/&
      13X,15HCENTROID  NODES,36X,5H(IYY),7X,5H(IZZ)/)
 3010 FORMAT(/4X,I3,8X,I3,5X,I3,7X,1PE10.3,4X,E10.3,4X,E10.3,2X,E10.3,&
      5X,E10.3,8X,E10.3)
3020 FORMAT(23X,I3)
4000 Write(*,4001)
4001 Format('Read Error')
3021 END
      SUBROUTINE STIFF(TSTIFF,NQQ,MBND)
      COMMON/ISS/C11I(100),C12I(100),C22I(100),C33I(100),C34I(100),C44I(100),&
                 C11J(100),C12J(100),C22J(100),C33J(100),C34J(100), &
                 C44J(100)
      DIMENSION H(10),ESTIFF(7,7),F(7,7),ALAM(7,7),A(6,6),LM(6)
      DIMENSION TSTIFF(NQQ,MBND)
!     WEIGHTING COEFFICIENTS FOR NUMERICAL INTERGRATION
      S(1)=0.046910077030668
      S(2)=0.2307653449471585
      S(3)=0.5
      S(4)=1.0-S(2)
      S(5)=1.0-S(1)
      H(1)=0.236926885056189
      H(2)=0.478628670499366
      H(3)=0.568888888888889
      H(4)=H(2)
      H(5)=H(1)
!     CLEAR TOTAL STIFFNESS MATRIX
      DO 100 I =1,NEQ
      DO 100 J =1,MBAND
  100 TSTIFF(I,J)=0.0
!     FORM ELEMENT STIFFNESS
      DO 200 L =1,NELEMS
      I=NODI(L)
      J=NODJ(L)
      DR=R(J)-R(I)
      DZ=Z(J)-Z(I)
      COSA=DR/DL
      SINA=DZ/DL
      DO 110 M=1,7
      DO 110 N=M,7
  110 ESTIFF(M,N)=0.0
      DO 140 K=1,5
!     FORM MATERIAL STIFFNESS MATRIX
      X=S(K)
      C11=C11I(L)+(C11J(L)-C11I(L))*X
      C12=C12I(L)+(C12J(L)-C12I(L))*X
      C22=C22I(L)+(C22J(L)-C22I(L))*X
      C33=C33I(L)+(C33J(L)-C33I(L))*X
      C34=C34I(L)+(C34J(L)-C34I(L))*X
      C44=C44I(L)+(C44J(L)-C44I(L))*X
!     GENERALIZED DISPLACEMENT TRANSFORMATION MATRIX
      IF(R(I).EQ.0.0)R(I)=0.000001
  120 RAD=R(I)+DL*COSA*X
      B1=(-3.0+4.0*X)/DL
      B2=(-1.0+4.0*X)/DL
      B3=(1.0-3.0*X+2.0*X*X)*COSA/RAD
      B4=(1.0-(3.0-2.0*X)*X**2)*SINA/RAD
      B5=X*(1.0-2.0*X+X**2)*DL*SINA/RAD
      B6=(-X+2.0*X*X)*COSA/RAD
      B7=X**2*(3.0-2.0*X)*SINA/RAD
      B8=X**2*(-1.0+X)*DL*SINA/RAD
      B9=(-6.0+12.0*X)/DL**2
      B10=(-4.0+6.0*X)/DL
      B11=-B9
      B12=(-2.0+6.0*X)/DL
      B13=(6.0*X-6.0*X*X)*COSA/(DL*RAD)
      B14=(-1.0+4.0*X-3.0*X*X)*COSA/RAD
      B15=-B13
      B16=(2.0*X-3.0*X*X)*COSA/RAD
      B17=(4.0-8.0*X)/DL
      B18=(4.0*X-4.0*X*X)*COSA/RAD
!     EVALUATE F(X)
      F(1,1)=B1*B1*C11+2.0*B1*B3*C12+B3*B3*C22
      F(1,2)=B1*B4*C12+B3*B4*C22
      F(1,3)=B1*B5*C12+B3*B5*C22
      F(1,4)=B1*B2*C11+B2*B3*C12+B1*B6*C12+B3*B6*C22
      F(1,5)=B1*B7*C12+B3*B7*C22
      F(1,6)=B1*B8*C12+B3*B8*C22
      F(1,7)=B1*B17*C11+B3*B17*C12+B1*B18*C12+B3*B18*C22
      F(2,2)=B4*B4*C22+B9*B9*C33+2.0*B9*B13*C34+B13*B13*C44
      F(2,3)=B4*B5*C22+B9*B10*C33+(B10*B13+B9*B14)*C34+B13*B14*C44
      F(2,4)=B2*B4*C12+B4*B6*C22
      F(2,5)=B4*B7*C22+B9*B11*C33+(B11*B13+B9*B15)*C34+B13*B15*C44
      F(2,6)=B4*B8*C22+B9*B12*C33+(B12*B13+B9*B16)*C34+B13*B16*C44
      F(2,7)=B4*B17*C12+B4*B18*C22
      F(3,3)=B5*B5*C22+B10*B10*C33+2.0*B10*B14*C34+B14*B14*C44
      F(3,4)=B2*B5*C12+B5*B6*C22
      F(3,5)=B5*B7*C22+B10*B11*C33+(B11*B14+B10*B15)*C34+B14*B15*C44
      F(3,7)=B5*B17*C12+B5*B18*C22
      F(4,4)=B2*B2*C11+2.0*B2*B6*C12+B6*B6*C22
      F(4,5)=B2*B7*C12+B6*B7*C22
      F(4,6)=B2*B8*C12+B6*B8*C22
      F(4,7)=B2*B17*C11+(B6*B17+B2*B18)*C12+B6*B18*C22
      F(5,5)=B7*B7*C22+B11*B11*C33+2.0*B11*B15*C34+B15*B15*C44
      F(5,6)=B7*B8*C22+B11*B12*C33+(B12*B15+B11*B16)*C34+B15*B16*C44
      F(5,7)=B7*B17*C12+B7*B18*C22
      F(6,6)=B8*B8*C22+B12*B12*C33+2.0*B12*B16*C34+B16*B16*C44
      F(6,7)=B8*B17*C12+B8*B18*C22
      F(7,7)=B17*B17*C11+2.0*B17*B18*C12+B18*B18*C22
!     ADD PARTIAL AREA TO ELEMENT STIFFNESS MATRIX
      DO 130 M=1,7
      DO 130 N=M,7
  130 ESTIFF(M,N)=ESTIFF(M,N)+H(K)*F(M,N)*RAD*DL/2.0
  140 CONTINUE
!     COMPLETE ELEMENT STIFFNESS
      DO 150 M=1,7
      DO 150 N=M,7
  150 ESTIFF(N,M)=ESTIFF(M,N)
!     TRANSFORMATION MATRIX (GLOBAL COORDINATES)
      DO 160 M=1,6
      DO 160 N=1,6
  160 ALAM(M,N)=0.0
      ALAM(1,1)=SINA
      ALAM(1,2)=COSA
      ALAM(2,1)=-COSA
      ALAM(2,2)=SINA
      ALAM(3,3)=-1.0
      ALAM(4,4)=SINA
      ALAM(4,5)=COSA
      ALAM(5,4)=-COSA
      ALAM(5,5)=SINA
      ALAM(6,6)=-1.0
!     STATIC CONDENSATION OF ELEMENT STIFFNESS MATRIX
      DO 151 M=1,6
  151 ESTIFF(7,M)=-(1.0/ESTIFF(7,7))*ESTIFF(7,M)
      DO 152 M=1,6
      N=6*L+M-6
      STATIC(N)=0.0
      DO 152 K=1,6
  152 STATIC(N)=STATIC(N)+ESTIFF(7,K)*ALAM(K,M)
      DO 153 M=1,6
      DO 153 N=1,6
  153 A(M,N)=ESTIFF(M,7)*ESTIFF(7,N)
      DO 154 M=1,6
      DO 154 N=1,6
  154 ESTIFF(M,N)=ESTIFF(M,N)+A(M,N)
!     MULTIPLY ELEMENT STIFFNESS AND TRANSFORMATION MATRICES
      DO 170 M=1,6
      DO 170 N=1,6
      A(M,N)=0.0
      DO 170 K=1,6
  170 A(M,N)=A(M,N)+ESTIFF(M,K)*ALAM(K,N)
!     ELEMENT STIFFNESS IN GLOBAL COORDINATES
      DO 180 M=1,6
      DO 180 N=1,6
      ESTIFF(M,N)=0.0
      DO 180 K=1,6
  180 ESTIFF(M,N)=ESTIFF(M,N)+ALAM(K,M)*A(K,N)
!     ADD ELEMENT STIFFNESS TO TOTAL STIFFNESS
      LM(1)=3*I-2
      LM(2)=LM(1)+1
      LM(3)=LM(1)+2
      LM(4)=3*J-2
      LM(5)=LM(4)+1
      LM(6)=LM(4)+2
      DO 190 M=1,6
      II=LM(M)
      DO 190 N=M,6
      JJ=LM(N)-II+1
  190 TSTIFF(II,JJ)=TSTIFF(II,JJ)+ESTIFF(M,N)
  200 CONTINUE
!     ESTABLISH LINKING BEAMS FOR EDGE BEAMS
      IF(NBEAMS.EQ.0) GOTO 260
      DO 250 L=1,NBEAMS
      EI=BMOD(L)*TDIM(L)**3/12.0
      EA=BMOD(L)*TDIM(L)
      ANG=PHI(L)*0.01745329
      DO 230 K=1,6
      IF(LOCJ(L,K).LE.0) GOTO 240
      IF(LOCJ(L,K).GT.LOCC(L)) GOTO 205
      I=LOCJ(L,K)
      J=LOCC(L)
      GOTO 206
  205 I=LOCC(L)
      J=LOCJ(L,K)
  206 DR=R(J)-R(I)
      DZ=Z(J)-Z(I)
      COSA=DR/DL
      SINA=DZ/DL
      DO 210 M=1,6
      DO 210 N=M,6
  210 ESTIFF(M,N)=0.0
      ESTIFF(1,1)=12.0*EI*COSA**2/DL**3+EA*SINA**2/DL
      ESTIFF(1,2)=-12.0*EI*SINA*COSA/DL**3+EA*SINA*COSA/DL
      ESTIFF(1,3)=6.0*EI*COSA/DL**2
      ESTIFF(1,4)=-ESTIFF(1,1)
      ESTIFF(1,5)=-ESTIFF(1,2)
      ESTIFF(1,6)=ESTIFF(1,3)
      ESTIFF(2,2)=12.0*EI*SINA**2/DL**3+EA*COSA**2/DL
      ESTIFF(2,3)=-6.0*EI*SINA/DL**2
      ESTIFF(2,4)=ESTIFF(1,5)
      ESTIFF(2,5)=-ESTIFF(2,2)
      ESTIFF(2,6)=ESTIFF(2,3)
      ESTIFF(3,3)=4.0*EI/DL
      ESTIFF(3,4)=-ESTIFF(1,3)
      ESTIFF(3,5)=-ESTIFF(2,3)
      ESTIFF(3,6)=2.0*EI/DL
      ESTIFF(4,4)=ESTIFF(1,1)
      ESTIFF(4,5)=ESTIFF(1,2)
      ESTIFF(4,6)=-ESTIFF(1,3)
      ESTIFF(5,5)=ESTIFF(2,2)
      ESTIFF(5,6)=-ESTIFF(2,3)
      ESTIFF(6,6)=ESTIFF(3,3)
!     ADD LINK BEAM STIFFNESS TO TOTAL STIFFNESS
      LM(1)=3*I-2
      LM(2)=LM(1)+1
      LM(3)=LM(1)+2
      LM(4)=3*J-2
      LM(5)=LM(4)+1
      LM(6)=LM(4)+2
      DO 220 M=1,6
      II=LM(M)
      DO 220 N=M,6
      JJ=LM(N)-II+1
  220 TSTIFF(II,JJ)=TSTIFF(II,JJ)+ESTIFF(M,N)*(R(I)+R(J))/2.0
  230 CONTINUE
!     ADD EDGE BEAM STIFFNESS TO TOTAL STIFFNESS
  240 COSA=COS(ANG)
      SINA=SIN(ANG)
      I=LOCC(L)
      II=3*I-1
      TSTIFF(II,1)=TSTIFF(II,1)+BMOD(L)*BAREA(L)/R(I)
      TSTIFF(II+1,1)=TSTIFF(II+1,1)+(ZZ(L)*SINA**2+YY(L)*COSA**2)*BMOD(L)/R(I)
!     STORE EDGE BEAM STRESS MATRIX
      BSTRES(3*L-2)=BMOD(L)*BAREA(L)/R(I)
      BSTRES(3*L-1)=SINA*BMOD(L)*ZZ(L)/R(I)
  250 BSTRES(3*L)=-COSA*BMOD(L)*YY(L)/R(I)
  260 CONTINUE
!     ADD SPRING STIFFNESS TO TOTAL STIFFNESS
      DO 270 L=1,NUMJTS
      L4 = (3*L)-2
      Write(*,*)L4,NUMJTS
      TSTIFF(3*L-2,1)=TSTIFF(3*L-2,1)+SPRING(3*L-2)
      TSTIFF(3*L-1,1)=TSTIFF(3*L-1,1)+SPRING(3*L-1)
  270 TSTIFF(3*L,1)=TSTIFF(3*L,1)+SPRING(3*L)
      RETURN
    END
      SUBROUTINE DISPL(TSTIFF,NQQ,MBND)
!     MODIFY TOTAL STIFFNESS MATRIX FOR SPECIFIED JOINT DISPLACEMENTS
      DO 50 N=1,NUMJTS
      KK=KODE(N)
      KD=100
      DO 40 M=1,3
      IF(KK.LT.KD) GOTO 30
      NR=3*N-3+M
      DO 10 J=2,MBAND
      TSTIFF(NR,J)=0.0
      NNR=NR-J+1
      IF(NNR.LT.1) GOTO 10
      TSTIFF(NNR,J)=0.0
   10 CONTINUE
   20 TSTIFF(NR,1)=1.0
      KK=KK-KD
   30 KD=KD/10
   40 CONTINUE
   50 CONTINUE
      DO 60 I =1,NEQ
   60 TLOAD(I)=0.0
!     REDUCE THE MODIFIED TOTAL STIFFNESS MATRIX
      KKK=1
      CALL SYMSOL(TSTIFF,TLOAD,NEQ,MBAND,KKK)
      DO 150 L=1,NUMLDS
!     READ IN NODAL LOADS FOR ONE LOADING CASE
      DO 70 I=1,NEQ
   70 TLOAD(I)=0.0
      READ(3,*)LOAD,NUMNLD,NUMELD
      WRITE(4,2000)LOAD,TITLE
      IF(NUMNLD.LT.1) GOTO 90
      WRITE(4,2010)
      DO 80 I=1,NUMNLD
      READ(3,*)NJ,TLOAD(3*NJ-2),TLOAD(3*NJ-1),TLOAD(3*NJ)
   80 WRITE(4,2020)NJ,TLOAD(3*NJ-2),TLOAD(3*NJ-1),TLOAD(3*NJ)
!     READ ELEMENT LOADS FOR THIS CASE AND FORM EQUIVALENT NODAL LOADS
   85 IF(NUMELD.LT.1) GOTO 110
   90 IF(NUMELD.LT.1) GOTO 110
      WRITE(4,2030)
      DO 100 K=1,NUMELD
      READ(3,1020)NE,QNORM,QVERT,QHORIZ
      WRITE(4,2040)NE,QNORM,QVERT,QHORIZ
      I=NODI(NE)
      J=NODJ(NE)
      DR=R(J)-R(I)
      DZ=Z(J)-Z(I)
      COSA=DR/DL
      SINA=DZ/DL
      QU=QVERT*SINA+QHORIZ*COSA
      QW=QNORM-QVERT*COSA+QHORIZ*SINA
!     EQUIVALENT LOADS IN LOCAL COORDINATES
      R1=(R(I)*DL/2.0+DL*DL*COSA/6.0)*QU
      R2=(R(I)*DL/2.0+3.0*DL*DL*COSA/20.0)*QW
      R3=(R(I)*DL*DL/12.0+(DL**3)*COSA/30.0)*QW
      R4=(R(I)*DL/2.0+DL*DL*COSA/3.0)*QU
      R5=(R(I)*DL/2.0+7.0*DL*DL*COSA/20.0)*QW
      R6=(-R(I)*DL*DL/12.0-(DL**3)*COSA/20.0)*QW
!     TRANSFORM EQUIVALENT LOADS TO GLOBAL COORDINATES
      TLOAD(3*I-2)=TLOAD(3*I-2)+R1*SINA-R2*COSA
      TLOAD(3*I-1)=TLOAD(3*I-1)+R1*COSA+R2*SINA
      TLOAD(3*I)=TLOAD(3*I)-R3
      TLOAD(3*J-2)=TLOAD(3*J-2)+R4*SINA-R5*COSA
      TLOAD(3*J-1)=TLOAD(3*J-1)+R4*COSA+R5*SINA
  100 TLOAD(3*J)=TLOAD(3*J)-R6
!     MODIFY LOAD VECTOR FOR DISPLACEMENT BOUNDARY CONDITIONS
  110 DO 140 N=1,NUMJTS
      KK=KODE(N)
      KD=100
      DO 130 M=1,3
      IF(KK.LT.KD) GOTO 120
      NR=3*N-3+M
      TLOAD(NR)=0.0
      KK=KK-KD
  120 KD=KD/10
  130 CONTINUE
  140 CONTINUE
!     SOLVE THIS LOAD CASE FOR JOINT DISPLACEMENTS
      KKK=2
!     PRINT JOINT DISPLACEMENTS
      WRITE(4,2050)LOAD
      WRITE(4,2060)(NJ,TLOAD(3*NJ-2),TLOAD(3*NJ-1),TLOAD(3*NJ),NJ=1,NUMJTS)
!     SOLVE FOR THE ELEMENT STRESSES
      CALL STRESS(LOAD)
  150 CONTINUE
      RETURN
 1000 FORMAT(3I3)
 1010 FORMAT(I3,3F10.2)
 1020 FORMAT(I3,3F10.2)
 2000 FORMAT(19HLOADING CASE NUMBER,I3,4H FOR,/1X,12A6)
 2010 FORMAT(1H0,19HAPPLIED NODAL LOADS//5H NODE,5X,36H VERTICAL    HORIZONTAL   ROTATIONAL//)
 2020 FORMAT(1X,I3,6X,1PE10.3,3X,E10.3,3X,E10.3)
 2030 FORMAT(1H0,21HAPPLIED ELEMENT LOADS//8H ELEMENT,7X,'NORMAL','VERTICAL    HORIZONTAL'//)
 2040 FORMAT(3X,I3,7X,1PE10.3,3X,E10.3,3X,E10.3)
 2050 FORMAT(1H1,43HJOINT DISPLACEMENTS FOR LOADING CASE NUMBER,I3,//15H NODE          ,5X,' VERTICAL    HORIZONTAL   ROTATIONAL'/)
 2060 FORMAT(1X,I3,6X,1PE10.3,3X,E10.3,3X,E10.3)
      END
      SUBROUTINE SYMSOL (A,B,NN,MM,KKK)
      DIMENSION A(NN,MM),B(1)
!     A = COEFFICIENT MATRIX.
!     B = RIGHT HAND SIDE MATRIX.
!     NN = NUMBER OF EQUATIONS (MAX 800 HERE).
!     MM = HALF BAND WIDTH (MAX 20 HERE).
      GOTO (1000,2000),KKK
!     REDUCE COEFFICIENT MATRIX.
 1000 DO 280 N=1,NN
      DO 260 L=2,MM
      C=A(N,L)/A(N,1)
      I = N+L-1
      IF(NN-I) 260,240,240
  240 J=0
      DO 250 K=L,MM
      J=J+1
  250 A(I,J)=A(I,J)-C*A(N,K)
  260 A(N,L)=C
  280 CONTINUE
      GOTO 500
!     REDUCE RIGHT HAND SIDE MATRIX.
 2000 DO 290 N=1,NN
      DO 285 L=2,MM
      I=N+L-1
      IF(NN-I) 290,285,285
  285 B(I)=B(I)-A(N,L)*B(N)
  290 B(N)=B(N)/A(N,1)
!     CARRY OUT BACK SUBSTITUTION.
      N=NN
  300 N = N-1
      IF(N) 350,500,350
  350 DO 400 K=2,MM
      L = N+K-1
      IF(NN-L) 400,370,370
  370 B(N) = B(N) - A(N,K) * B(L)
  400 CONTINUE
      GOTO 300
  500 RETURN
    END
      SUBROUTINE STRESS(LOAD)
      COMMON/ISS/C11I(100),C12I(100),C22I(100),C33I(100),C34I(100),C44I(100), &
                C11J(100),C12J(100),C22J(100),C33J(100),C34J(100),C44J(100)
      DIMENSION EJDIS(7),SIGMA(6),STRES(4,7)
      WRITE(4,2000)LOAD
      DO 120 L=1,NELEMS
!     FORM MATRIX OF ELEMENT JOINT DISPLACEMENTS
      WRITE(4,2010)L
      I=NODI(L)
      J=NODJ(L)
      EJDIS(1)=TLOAD(3*I-2)
      EJDIS(2)=TLOAD(3*I-1)
      EJDIS(3)=TLOAD(3*I)
      EJDIS(4)=TLOAD(3*J-2)
      EJDIS(5)=TLOAD(3*J-1)
      EJDIS(6)=TLOAD(3*J)
!     FIND MID-SIDE DISPLACEMENT
      EJDIS(7)=0.0
      DO 105 M=1,6
      N=6*L+M-6
  105 EJDIS(7)=EJDIS(7)+STATIC(N)*EJDIS(M)
!     CONSTANT TERMS FOR ELEMENT STRESS MATRIX
      S(1)=0.0
      S(2)=0.5
      S(3)=1.0
      DR=R(J)-R(I)
      DZ=Z(J)-Z(I)
      COSA=DR/DL
      SINA=DZ/DL
      M1=2
      M2=2
      IF(NFORM.GE.1)M1=1
      IF(NFORM.GE.1)M2=3
      DO 110 K=M1,M2
      X=S(K)
      RAD=R(I)+DL*COSA*X
      B1=(-3.0+4.0*X)/DL
      B2=(-1.0+4.0*X)/DL
      B10=(-4.0+6.0*X)/DL
      B11=-B9
      B12=(-2.0+6.0*X)/DL
      B15=-B13
      B17=(4.0-8.0*X)/DL
!     EVALUATE STRESS MATRIX AT POINT S
      STRES(1,1)=SINA*B1*C11+(SINA*B3-COSA*B4)*C12
      STRES(1,2)=COSA*B1*C11+(COSA*B3+SINA*B4)*C12
      STRES(1,3)=-B5*C12
      STRES(1,4)=SINA*B2*C11+(SINA*B6-COSA*B7)*C12
      STRES(1,5)=COSA*B2*C11+(COSA*B6+SINA*B7)*C12
      STRES(1,6)=-B8*C12
      STRES(1,7)=B17*C11+B18*C12
      STRES(2,1)=SINA*B1*C12+(SINA*B3-COSA*B4)*C22
      STRES(2,2)=COSA*B1*C12+(COSA*B3+SINA*B4)*C22
      STRES(2,3)=-B5*C22
      STRES(2,4)=SINA*B2*C12+(SINA*B6-COSA*B7)*C22
      STRES(2,5)=COSA*B2*C12+(COSA*B6+SINA*B7)*C22
      STRES(2,6)=-B8*C22
      STRES(2,7)=B17*C12+B18*C22
      STRES(3,1)=-COSA*(B9*C33+B13*C34)
      STRES(3,2)=SINA*(B9*C33+B13*C34)
      STRES(3,3)=-B10*C33-B14*C34
      STRES(3,4)=-COSA*(B11*C33+B15*C34)
      STRES(3,5)=SINA*(B11*C33+B15*C34)
      STRES(3,6)=-B12*C33-B16*C34
      STRES(3,7)=0.0
      STRES(4,1)=-COSA*(B9*C34+B13*C44)
      STRES(4,2)=SINA*(B9*C34+B13*C44)
      STRES(4,3)=-B10*C34-B14*C44
      STRES(4,4)=-COSA*(B11*C34+B15*C44)
      STRES(4,5)=SINA*(B11*C34+B15*C44)
      STRES(4,6)=-B12*C34-B16*C44
      STRES(4,7)=0.0
!     MULTIPLY ELEMENT STRESS MATRIX AND JOINT DISPLACEMENT MATRIX
      DO 100 M=1,4
      SIGMA(M)=0.0
      DO 100 N=1,7
  100 SIGMA(M)=SIGMA(M)+STRES(M,N)*EJDIS(N)
!     PRINT ELEMENT STRESSES AT POINT S
      DX=X*DL
      WRITE(4,2020)DX,(SIGMA(M),M=1,4)
  110 CONTINUE
  120 CONTINUE
!     EDGE BEAM FORCES
      IF(NBEAMS.LT.1) GOTO 140
      WRITE(4,2030)LOAD
      DO 130 K=1,NBEAMS
      L=LOCC(K)
      FXX=BSTRES(3*K-2)*TLOAD(3*L-1)
      ZZM=BSTRES(3*K-1)*TLOAD(3*L)
      YYM=BSTRES(3*K)*TLOAD(3*L)
  130 WRITE(4,2040)K,FXX,YYM,ZZM
  140 CONTINUE
      WRITE(*,141)
141   FORMAT(//2X,'ANALYSIS COMPLETED.'//)
      RETURN
 2000 FORMAT( 'ELEMENT STRESS RESULTANTS FOR LOADING CASE NUMBER :',I4////15X,8HLOCATION,4X,27H****** NORMAL FORCES ******,3X,27H***** BENDING MOMENTS *****//27X,27HMERIDIONAL  CIRCUMFERENTIAL,3X,27HMERIDIONAL  CIRCUMFERENTIAL/)
 2010 FORMAT(8H ELEMENT,I3)
 2020 FORMAT(15X,F6.2,6X,1PE10.3,4X,E10.3,6X,E10.3,4X,E10.3)
 2030 FORMAT(1H1,40HEDGE BEAM FORCES FOR LOADING CASE NUMBER,I3///10H EDGE BEAM,5X,11HAXIAL FORCE,8X,15HBENDING MOMENTS/18X,5H(FXX),10X,5H(MYY),7X,5H(MZZ)/)
 2040 FORMAT(3X,I3,9X,1PE10.3,5X,E10.3,3X,E10.3)
      END
  Input File : sample.in
 Output File : s.out
   Version        : 1.1
This is a Sample input file.
 NUMBER OF NODAL POINTS ----------  11
 NUMBER OF ELEMENTS --------------  10
 NUMBER OF LOADING CONDITIONS ----   1
 NUMBER OF EDGE BEAMS ------------   2
 Stress Condition Output----------   1
 JOINT DATA
 NODE     RADIUS     ORDINATE     CODE      ********** JOINT SPRINGS **********
   1        1.00        1.00        0       0.000E+00    0.000E+00    0.000E+00
   2        1.00        0.95        0       0.000E+00    0.000E+00    0.000E+00
   3        1.00        0.90        0       0.000E+00    0.000E+00    0.000E+00
   4        1.00        0.85        0       0.000E+00    0.000E+00    0.000E+00
   5        1.00        0.80        0       0.000E+00    0.000E+00    0.000E+00
   6        1.00        0.75        0       0.000E+00    0.000E+00    0.000E+00
   7        1.00        0.70        0       0.000E+00    0.000E+00    0.000E+00
   8        1.00        0.65        0       0.000E+00    0.000E+00    0.000E+00
   9        1.00        0.60        0       0.000E+00    0.000E+00    0.000E+00
  10        1.00        0.55        0       0.000E+00    0.000E+00    0.000E+00
  11        1.00        0.50      111       0.000E+00    0.000E+00    0.000E+00
ELEMENT DATA
0ELEMENT  NODE     ************* MEMBRANE PROPERTIES *************     ************** BENDING PROPERTIES *************
                   THICKNESS      YOUNGS MODULUS    POISSONS RATIO     THICKNESS      YOUNGS MODULUS    POISSONS RATIO
                                 (ONE)       (TWO)     (ONE-TWO)                     (ONE)       (TWO)     (ONE-TWO)
    1       1        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
            2        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
    2       2        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
            3        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
    3       3        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
            4        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
    4       4        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
            5        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
    5       5        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
            6        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
    6       6        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
            7        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
    7       7        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
            8        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
    8       8        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
            9        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
    9       9        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
           10        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
   10      10        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
           11        0.2000    1.000E+01   1.000E+01      0.200           0.1000    1.100E+01   1.100E+01      0.200
 EDGE BEAM DATA
 EDGE BEAM    JOINT INDICES    YOUNGS MODULUS     AREA          MOMENT OF INERTIA     PRINCIPAL AXIS   LARGEST DIMENSION
             CENTROID  NODES                                    (IYY)       (IZZ)
      1          3       0        2.000E+01     2.000E-01     1.200E+01   1.200E+01      0.000E+00         3.000E+00
      2          5       0        2.000E+01     2.000E-01     1.200E+01   1.200E+01      0.000E+00         3.000E+00
LOADING CASE NUMBER  1 FOR
     pB
0APPLIED NODAL LOADS
 NODE      VERTICAL    HORIZONTAL   ROTATIONAL
   4       0.000E+00    2.000E+00    0.000E+00
1JOINT DISPLACEMENTS FOR LOADING CASE NUMBER  1
   1       4.585E-02   -4.966E-01    6.330E-02
   2       4.090E-02   -4.946E-01    2.831E-02
   3       3.595E-02   -4.947E-01   -1.200E-03
   4       3.055E-02   -6.204E-01   -4.107E+00
   5       2.343E-02   -7.686E-01   -2.099E-03
   6       1.537E-02   -8.404E-01    3.232E-01
   7       7.175E-03   -7.470E-01    6.639E+00
   8       1.286E-03   -3.977E-01    1.059E+01
   9      -7.543E-04   -4.065E-02    6.966E+00
  10      -3.590E-04    6.672E-02    6.097E-01
ELEMENT STRESS RESULTANTS FOR LOADING CASE NUMBER :   1
               LOCATION    ****** NORMAL FORCES ******   ***** BENDING MOMENTS *****
                           MERIDIONAL  CIRCUMFERENTIAL   MERIDIONAL  CIRCUMFERENTIAL
 ELEMENT  1
                 0.00      -7.248E-05    -9.933E-01       1.288E-03    -2.576E-04
                 0.03       2.987E-05    -9.908E-01       6.682E-04    -1.336E-04
                 0.05      -5.007E-05    -9.892E-01       4.840E-05    -9.683E-06
 ELEMENT  2
                 0.00      -8.583E-05    -9.892E-01       2.420E-03    -4.840E-04
                 0.03       2.458E-05    -9.890E-01       5.636E-04    -1.127E-04
                 0.05      -1.907E-05    -9.895E-01      -1.293E-03     2.586E-04
 ELEMENT  3
                 0.00      -8.086E-03    -9.911E-01       1.310E-01    -2.620E-02
                 0.02       3.563E-03    -1.063E+00       7.841E-02    -1.568E-02
                 0.05      -6.173E-03    -1.242E+00       2.582E-02    -5.164E-03
 ELEMENT  4
                 0.00       5.231E-03    -1.240E+00       2.576E-02    -5.151E-03
                 0.03      -3.565E-03    -1.441E+00      -7.839E-02     1.568E-02
                 0.05       9.019E-03    -1.535E+00      -1.825E-01     3.651E-02
 ELEMENT  5
                 0.00      -2.763E-03    -1.538E+00       1.767E-01    -3.534E-02
                 0.03      -2.841E-04    -1.613E+00      -6.212E-03     1.242E-03
                 0.05       3.889E-03    -1.680E+00      -1.891E-01     3.783E-02
 ELEMENT  6
                 0.00       7.600E-03    -1.679E+00       6.437E-02    -1.287E-02
                 0.03      -5.485E-03    -1.667E+00      -1.206E-01     2.412E-02
                 0.05       1.433E-02    -1.491E+00      -3.056E-01     6.112E-02
 ELEMENT  7
                 0.00       3.468E-03    -1.493E+00       1.113E-01    -2.226E-02
                 0.03      -3.436E-03    -1.195E+00      -7.554E-02     1.511E-02
                 0.05       1.026E-02    -7.934E-01      -2.624E-01     5.247E-02
 ELEMENT  8
                 0.00      -9.718E-03    -7.973E-01       2.571E-01    -5.142E-02
                 0.02       3.148E-03    -3.924E-01       6.931E-02    -1.386E-02
                 0.05      -2.888E-03    -8.187E-02      -1.185E-01     2.370E-02
 ELEMENT  9
                 0.00      -1.445E-02    -8.419E-02       3.093E-01    -6.187E-02
                 0.03       5.515E-03     1.066E-01       1.214E-01    -2.428E-02
                 0.05      -7.619E-03     1.319E-01      -6.658E-02     1.332E-02
 ELEMENT 10
                 0.00      -4.475E-03     1.325E-01       1.995E-01    -3.989E-02
                 0.03       5.270E-04     7.444E-02       1.164E-02    -2.329E-03
                 0.05       2.354E-03     4.709E-04      -1.762E-01     3.524E-02
 EDGE BEAM     AXIAL FORCE        BENDING MOMENTS
                  (FXX)          (MYY)       (MZZ)
     1         -1.979E+00      2.881E-01    0.000E+00
     2         -3.074E+00      5.037E-01    0.000E+00
John_Campbell
New Contributor II
John,
Thanks for the example. This is a very early version of code from Graham Powell as he published a banded solver by 1974. Is this an axisymmetric shell element ? I have not used this analysis. If it is axisymmetric, then it would be a challenge to exceed the memory requirement of even 32-bit.
Do you recall the real and integer precision and computer that was used when this code was developed ?
You will notice that this code was developed before virtual memory was a consideration, as it would now run faster if
      DIMENSION A(NN,MM),B(1)    !   A(neq,mband)
was changed to
      DIMENSION A(MM,NN),B(1)    !   A(mband,neq)
I have changed the program you have provided to:
  1. Declare variables as either integer*4 or real*8, to cope with the expected precision,
  2. include parameters for key dimensions
  3. Introduced some fortran 90 syntax for the do loops in SYMSOL
  4. Changed the subscript order in TSTIFF
I guessed the sample data file and produced similar results. Hopefully I have included minimal bugs.
