29641 Discussions
No variables showing when debugging using visual studio 2022
JS_Clausen
Dear Forum
I am sorry if this post is too much a repetition of earlier posts.
My software:
  • Windows 10
  • Intel oneAPI Base Tookit 2023.2
  • Intel oneAPI HPC Toolkit 2023.2
  • Visual Studio 2022 Version 17.7.4
My problem: I cannot see variables values when debugging. The watch window is simply empty. If I run without debugging the program runs to completion as expected.
Here is a screenshot demonstrating the problem:
As you can see, the variables window is simply empty.
As far as I can tell (Engineer, not software expert :-), the compiler directives are set for debugging:
/nologo /debug:full /Od /warn:interfaces /module:"x64\Debug\\" /object:"x64\Debug\\" /Fd"x64\Debug\vc170.pdb" /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c
After reading other posts I have tried to uninstall and reinstall oneAPI af few times to no avail.
I fear that I am simply missing a small detail or setting somewhere. I would greatly appreciate any ideas for making it possible to see variable values when debugging.
Best regards
JS_Clausen
JS_Clausen
Dear Steve
The proposed solution worked like a charm. Greatly appreciated.
I must say, that it is now very easy to obtain Intel Fortran these days. And free too. I have been using the compiler (within academia) on/off since the Compaq Visual Fortran days. Always a hassle to find a vendor and secure licenses in order for students to also be able to use the code (mainly UMATs in Abaqus). Now I can just instruct students to download from the Intel web page. Thank you for that and for the swift support in this forum.
Best regards
JS_Clausen
