- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I'm running a numerical model that contains several class instances defined as modules. The code was validated using ifort17. However, on recently switching to ifort 19, I noticed--while using the -g flag--when a certain variable is initialized, unintended changes occur in other (independent) variables. It appears as if two variables share the same memory location. The following minimal example gives expected results when -O3 is used, but does not work when the -O0 and -g flags are used.
Minimal example:
main file:
program main use rotor_classdef type(rotor_class) :: rotor rotor%nx=2 rotor%ny=5 call rotor%init() end program main
module file:
module rotor_classdef integer, parameter :: dp = kind(1.d0) ! Double precision type rotor_class integer :: nx,ny contains procedure :: init end type rotor_class contains subroutine init(this) class(rotor_class) :: this real(dp), dimension(this%nx) :: xvec real(dp), dimension(this%ny) :: yvec xvec=1._dp print* print*,'Value of xvec BEFORE assigning yvec' print*,xvec yvec=3._dp ! ** This assignment appears to change the value of xvec ** print*,'Value of xvec AFTER assigning yvec' print*,xvec print* end subroutine init end module rotor_classdef
when compiled with -O0 and -g flags, produces the output
Value of xvec BEFORE assigning yvec 1.00000000000000 1.00000000000000 Value of xvec AFTER assigning yvec 3.00000000000000 3.00000000000000
instead of
Value of xvec BEFORE assigning yvec 1.00000000000000 1.00000000000000 Value of xvec AFTER assigning yvec 1.00000000000000 1.00000000000000
Additional Details:
OS: Ubuntu 16.04
[new] ifort version: 19.0.0.117
[old/working] ifort version: 17.0.0
Any help in figuring out why this occurs is gratefully appreciated!
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Indeed, with the files attached I can reproduce your findings. Using the -module flag does not have any impact, the issue happens also with the standard setting here. The -O0 flag is irrelevant, it is the -g flag that causes the issue. -O0 alone works. This really looks like an Intel bug. I would file a bug report.
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I cannot reproduce your findings. Using Ubuntu 16.04 with the same build of ifort v19 that you use, I get two times 1.000 1.000.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I think the modules defined before this one have some sort of dependency although not in code. I still keep getting the discrepancy. Could you try using the files attached? There are a few modules that contain one or two variables each that seem to make a difference.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Thanks Juergen for the prompt response!
Could you confirm that -O0 flag is irrelevant. I seem to come across the same discrepancy with only the -g flag. This happens after clearing the .obj and .mod files. And just to clarify, the make command I used when this occurred was 'make run_dbg' or 'make'.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Dear Joseph, look above, I wrote that -O0 is irrelevant, and -g is the important flag. I ran your Makefile and also compiled it by hand. Same result. Using a specified object path doesn't matter. I compiled with gfortran, PGI and nagfor (with full debug flags and default flags). All compilers show the expected results.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Apologies for my confusion. You're right, -O0 is irrelevant. -g is the culprit.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
We might have run into the same bug using ifort 19u1 under ubuntu 18.
Is there a bug report open yet?
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
For the record, this bug has been fixed in Intel Fortran 2020.
