Overwriting of variables in ifort 19 (19.0.0.117) when using -g flag
Cibin_Joseph
I'm running a numerical model that contains several class instances defined as modules. The code was validated using ifort17. However, on recently switching to ifort 19, I noticed--while using the -g flag--when a certain variable is initialized, unintended changes occur in other (independent) variables. It appears as if two variables share the same memory location. The following minimal example gives expected results when -O3 is used, but does not work when the -O0 and -g flags are used.
Minimal example:
main file:
program main
  use rotor_classdef
  type(rotor_class) :: rotor
  rotor%nx=2
  rotor%ny=5
  call rotor%init()
end program main
module file:
module rotor_classdef
  integer, parameter :: dp = kind(1.d0)    ! Double precision
  type rotor_class
    integer :: nx,ny
  contains
    procedure :: init
  end type rotor_class
contains
  subroutine init(this)
  class(rotor_class) :: this
    real(dp), dimension(this%nx) :: xvec
    real(dp), dimension(this%ny) :: yvec
    xvec=1._dp
    print*
    print*,'Value of xvec BEFORE assigning yvec'
    print*,xvec
    yvec=3._dp    ! ** This assignment appears to change the value of xvec **
    print*,'Value of xvec AFTER  assigning yvec'
    print*,xvec
    print*
  end subroutine init
end module rotor_classdef
when compiled with -O0 and -g flags, produces the output
   1.00000000000000        1.00000000000000
   3.00000000000000        3.00000000000000
instead of
Additional Details:
OS: Ubuntu 16.04
[new] ifort version: 19.0.0.117
[old/working] ifort version: 17.0.0
Any help in figuring out why this occurs is gratefully appreciated!
Juergen_R_R
Valued Contributor II
Indeed, with the files attached I can reproduce your findings. Using the -module flag does not have any impact, the issue happens also with the standard setting here. The -O0 flag is irrelevant, it is the -g flag that causes the issue. -O0 alone works. This really looks like an Intel bug. I would file a bug report.
Juergen_R_R
I cannot reproduce your findings. Using Ubuntu 16.04 with the same build of ifort v19 that you use, I get two times 1.000 1.000.
Cibin_Joseph
I think the modules defined before this one have some sort of dependency although not in code. I still keep getting the discrepancy. Could you try using the files attached? There are a few modules that contain one or two variables each that seem to make a difference.
Juergen_R_R
Cibin_Joseph
Thanks Juergen for the prompt response!
Could you confirm that -O0 flag is irrelevant. I seem to come across the same discrepancy with only the -g flag. This happens after clearing the .obj and .mod files. And just to clarify, the make command I used when this occurred was 'make run_dbg' or 'make'.
Juergen_R_R
Dear Joseph, look above, I wrote that -O0 is irrelevant, and -g is the important flag. I ran your Makefile and also compiled it by hand. Same result. Using a specified object path doesn't matter. I compiled with gfortran, PGI and nagfor (with full debug flags and default flags). All compilers show the expected results.
Cibin_Joseph
Apologies for my confusion. You're right, -O0 is irrelevant. -g is the culprit.
Hachenberg__Fabian
We might have run into the same bug using ifort 19u1 under ubuntu 18.
Is there a bug report open yet?
Cibin_Joseph
For the record, this bug has been fixed in Intel Fortran 2020.
