When I tried to install 2019 parallel (your newest), it does not give a check mark for the fortran compiler.
I was trying to integrate it with VS 2015, which I thought was a possible choice.
However, I was able to integrate it, but I cannot run a simple program (HELLO WORLD).
------ Build started: Project: Console2, Configuration: Debug|Win32 ------
Compiling with Intel(R) Visual Fortran Compiler 19.0.0.117 [IA-32]...
Console2.f90
warning #31001: The dll for reading and writing the pdb (for example, mspdb110.dll) could not be found on your path. This is usually a configuration error. Compilation will continue using /Z7 instead of /Zi, but expect a similar error when you link your program.
Build log written to "file://c:\users\administrator\documents\visual%20studio%202015\Projects\Console2\Console2\Debug\BuildLog.htm"
Console2 - 0 error(s), 1 warning(s)
---------------------- Done ----------------------
Is there a way around this ? Or does that have to fixed on your end ?
This has to be resolved before I can buy your product. so solly !
This has been discussed previously here https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/697197
Try using the search box on top of the forum ( search for mspdb110.dll )
Check that your Visual Studio is configured correctly as explained here:
https://software.intel.com/en-us/articles/installing-visual-studio-2015-for-use-with-intel-compilers ;
This is just a warning; your helloworld.exe should have been created. Did you try running, to see if it display "Hello"?
It's interesting that you said there was no option for the Fortran compiler, because the logo clearly shows that the 19.0 Fortran compiler was installed, so that's good news.
Finally, if you change your configuration to be "x64" instead of "win32", do you still get this link-time warning?
Well, I get build errors (10037) so it cant run it,
at least it can compile it - - - - Yippee !
Dead in the water, so to speak.
