29271 Discussions
Possible issue with ifx 2025.2.0 for deferred/overriding procedures
OP1
New Contributor III
In the following code, the abstract derived type T features a procedure binding TP for a deferred procedure T_P which has the RECURSIVE attribute.
TT is a concrete extension of T which associates the TP binding with the type-bound procedure TT_P which has the NON_RECURSIVE attribute.
The compiler does not emit an error for this discrepancy (it does if you try the pair of mismatched attributes PURE/IMPURE). Is this a compiler bug?
MODULE M
IMPLICIT NONE
TYPE, ABSTRACT :: T
    CONTAINS
        PROCEDURE(T_P), DEFERRED, PRIVATE :: TP
END TYPE T
ABSTRACT INTERFACE
    RECURSIVE SUBROUTINE T_P(SELF)
    IMPORT, ALL
    IMPLICIT NONE
    CLASS(T), INTENT(IN) :: SELF
    END SUBROUTINE T_P
END INTERFACE
TYPE, EXTENDS(T) :: TT
    CONTAINS
        PROCEDURE, PUBLIC :: TP => TT_P
END TYPE TT
CONTAINS
    NON_RECURSIVE SUBROUTINE TT_P(SELF)
    IMPLICIT NONE
    CLASS(TT), INTENT(IN) :: SELF
    END SUBROUTINE TT_P
END MODULE M
Ron_Green
It is a bug. Bug ID is CMPLRLLVM-69417
