There appears to be a problem with the latest fortran compiler or visual studio when executing read and pause statements that wait for input from the keyboard.
I am using
Intel Fortran Compiler Classic for apps running on IA-32, ver. 2021.5.0, Package ID: w_oneAPI_2022.0.0.3663
with
MS Visual Studio Community 2022(64bits), ver. 17.0.4
I compiled in debug a short standard graphics program which includes the following two statements:
read(5,'(i1)'),i
pause
The failure for the read(5,'(i1)'),i statement is:
Microsoft Visual C++ Runtime Library
Debug Assertion Failed
Program:...pgms\Ftn Std Graphics pgm\Debug\FtnStd Graphics project.exe
File:
minkernel\crts\ucrt\corecrt_internal_string_templates.h
Line: 218
Expression: (L"Buffer is too small" && 0)
If I press [ignore] studio returns to the fortran code with a breakpoint after the read statment with the following message:
Exception Unhandled
Unhandled exception at 0x004E94B6 in Ftn Std Graphics project.exe:
An invalid parameter was passed to a function that considers invalid parameters fatal.
If I comment out the read statement, I get the same failure for the pause statement, except for the following lines:
Line: 179
Expression: ((destination)) != NULL && ((size_in_elements)) > 0
and
Unhandled exception at 0x00D94186 in Ftn Std Graphics project.exe:
These failures DO NOT OCCUR when using
Intel Fortran Compiler Classic for apps running on IA-32, ver. 2021.3.0, Package ID: w_oneAPI_2021.3.0.3372
with
MS Visual Studio Community 2019, ver. 16.10.4
Note that the Intel Fortran Compiler Classic and Intel Fortran Compiler (Beta) Developer Guide and Reference states that "The PAUSE statement is a deleted feature in the Fortran Standard. Intel® Fortran fully supports features deleted in the Fortran Standard."
Is there something wrong with the way VS 2022 implements the C++ runtime library?
Is there a compiler/debug setting that can alleviate this problem?
Thank you
Ron
链接已复制
Thank you for your reply. I will try the link in the thread you mentioned.
I have tried additional I/O statements using VS Community 2022/w_oneAPI_2022.0.0.3663 with the following results.
Reading from a file: read(1,'(a20)') and read(1,*) and read(1,'(f4.2)') all yield the following error.
Intel Visual Fortran run-time error
end-of-file during read,unit 1
Exception thrown
Getting characters from the keyboard: result_i4=getc(char) and result_i4=getstrqq(buffer_c80) both yield the following error
Expression: (L "Buffer is too small" &&0)
Exception Unhandled
The statement result_c1=getcharqq( ) DOES work.
With one exception, these statements WORK on VS Community 2019 with w_oneAPI_2021.3.0.3372. The exception is result_i4=getsrtqq(buffer_c80). Though this statement DOES NOT create an error, it DOES NOT do anything.
Next I will try loading the w_oneAPI_2021.3 into MS Community 2022 using the link mentioned in the other thread.
Thanks again
Ron
