- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
OPEN (UNIT=7, FILE=BinFile, ACCESS='DIRECT', RECL=22000,
+ STATUS='OLD', FORM='UNFORMATTED')
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Just a comment. I am very concerned about the state of computer science and programming in todays educational system.
[IDSA needs to be abandoned, uninstalled and forgotten]
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
@AlHill said,"IDSA needs to be abandoned, uninstalled and forgotten".
Sure, but please remind us what you want us to uninstall and forget. I searched for "IDSA", and found "Infectious Diseases Society of America", which did not seem relevant to this thread.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Intel Driver & Support Assistant (IDSA) , not infectious diseases it would seem....
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
The only case where you can reasonably assume the files would have the same layout is if you use ACCESS='STREAM'. Most compilers don't add information visible in the data stream to ACCESS='DIRECT' files, but obviously at least one does. I know that direct access was often used as a way to get "raw" data, but here's a case where that doesn't work.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thank you. I am starting to see that now. As long as I can figure out the spec I think I can backward engineer it. Before this, most of the projects I took over were based on Intel IFORT. This is the first big project based on Lahey.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
So based on these findings am I to interpret this as a single header record of 22000 bytes long that is basically there just to store the record length? The first record is wasted in my case? 22000 byte record where one byte is a marker and then 4 bytes for record length leaving 21995 bytes unused ?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Yes It seems that the implementation of Lahey fortran wastes on record. May be the record length in the header is 8 bytes long. Integers are stored with least significant byte first so the first 4 bytes of a 8 bytes integer can be read as a valid integer(4).
You can easily write a small automatic conversion program that reads each record in a character variable of the record length and writes it one record before until the end of the file.
1 open the file with a 5 bytes record length
2 read the header and get the record length
3 close the file
4 reopen it and the output file with the correct record length
5 allocate an array of integer to match the record length
5 read each records in integer array starting from the second one and write them one record before in the output file.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
8-bytes would be a 64-bit integer and I think Lahey predates that particular type.
The documentation describes 1, 2, and 4-byte integers.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Ok I think I have a good handle on this now. The most critical part of this was understating the custom format of binary files created by the Lahey compiler. Assuming the system reading the BIN file is to stay the same but creation of the BIN file switches to IFORT then the changes are as follows:
Code for the Lahey compiler:
CHARACTER*3 STA
REAL LAT, LON, ELEV
CHARACTER * 255 TstFile
REAL RCNT
TstFile='C:\docs\TSTLF90.BIN'
OPEN (UNIT=8, FILE=TstFile, ACCESS='DIRECT', RECL=128, !1-byte units in Lahey
+ STATUS='REPLACE', FORM='UNFORMATTED')
RCNT=13419.
WRITE(8,REC=1)RCNT
STA='DFW'
LAT=3253.
LON=-9702.
ELEV=603.
WRITE(8,REC=2)STA,LAT,LON,ELEV
Code for the Intel compiler:
CHARACTER*3 STA
REAL LAT, LON, ELEV
REAL RCNT
INTEGER*1 MRKR
INTEGER*2 RECLEN
TstFile='C:\docs\TSTIFORT.BIN'
OPEN (UNIT=8, FILE=TstFile, ACCESS='DIRECT', RECL=32, !4-byte units in IFORT so 128/4 = 32
MRKR=247 !F7 marker byte
RECLEN=128
WRITE(8,REC=1)MRKR, RECLEN !LAHEY header record (record 'zero')
RCNT=13419.
WRITE(8,REC=2)RCNT !record one
STA='DFW'
LAT=3253.
LON=-9702.
ELEV=603.
WRITE(8,REC=3)STA,LAT,LON,ELEV !record two
Hex dump of the BIN files from both compilers shows the exact same output.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
The 32-bit IEEE floating point representation of 13419.0 is Z'4651AC00, which is what you have at offset 128 (Z'0080') in both your .BIN files.
Avoid using REAL variables to write integer values to an unformatted file.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Again "assume the systems using this BIN file will not change". The systems that read the BIN file are already coded to read it this way and that part is not going to change.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
One last bit of info i found while looking through the Lahey switches. This switch is ON by default and it can be turned off.
-[N]HED
Headers on Direct Files
Default: -hed
An LF90-generated direct file has a header to identify record length. See “Direct File Format”
on page 167. This header is read by the OPEN and INQUIRE statements. -hed creates
direct files with headers.
Specify -nhed to generate direct files without headers for compatibility with other vendors’
direct files.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
It looks like the issue is with the RECL value in your OPEN statement.
Lahey counts RECL in bytes, while Intel IFORT defaults to 4-byte units.
Try compiling with /assume:byterecl or adjust RECL accordingly.
That should give you the expected RCNT=13419.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
It looks like the problem comes from differences in how Lahey Fortran and Intel IFORT handle direct-access unformatted files, especially with record lengths and data types. Lahey counts RECL in bytes by default, while Intel Fortran may use a different unit (like 4-byte elements for REAL).
Also, the type of the variable you’re reading (REAL) may behave slightly differently in IFORT compared to Lahey. This can cause your value to read as 0 instead of the expected number.
A common solution is to adjust the compiler settings in IFORT to treat record lengths the same way Lahey does, without changing your code. This usually resolves the discrepancy when reading binary files.
Essentially, it’s not a bug in your code—it’s just a difference in how the two compilers interpret the binary file format.
