Redistributable requirements for coarray Fortran programs
IanH
For ifort 19.0.1.144 (2019 update 1), what are the re-distributables (dlls and any helper exe's) required for coarray programs, beyond those required for non-coarray programs?
Is it expected that the necessary redisdtributables for coarray programs be provided by the redistributable msi that can be downloaded from https://software.intel.com/en-us/articles/redistributable-libraries-for-intel-c-and-fortran-2019-compilers-for-windows?
If yes... my coarray (/Qcoarray:shared) programs compiled in a release configuration ultimately depend on impi.dll, which doesn't appear to be in the redistributables - any ideas why?  This dependency is picked up via libicaf.dll, which is the redistributables (in C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\compiler).
I do see a similary named impimt.dll in the x64 redistributable dlls, which is odd because it only appears in the ia32 directories of the directory structure on a development machine.
Steve_Lionel
impi.dll should be in the compiler redistributables. It is an oversight if not. I suggest filing a support ticket on that.
IanH
I have had a look at the redistributable msi with orca, and it too only has impimt.dll, not impi.dll (consistent with what actually has been installed here).  I will file a ticket.
I am rather suspicious of other aspects of the redistributable installer too - I think some file versions in the installer that deals with files under the mpirt directory have not been set and/or incremented correctly, such that the installer is not updating some of the files that already existed from previous redistributable installations.
If someone has installed 2019 update one on a new machine (one that has never had ifort or its redistributables installed), it would be handy to see a directory listing of the files under C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\mpirt.
mecej4
I have PS2019U1 in a different directory than the default location in c:\Program Files (x86). In the redist folder I have only 32-bit impi DLLs:
 Directory of c:\lang\PS19U1\compilers_and_libraries_2019.1.144\windows\redist\ia32\mpirt
03/14/2018  05:47 PM         3,743,032 impi.dll
03/14/2018  05:47 PM         3,879,736 impimt.dll
               2 File(s)      7,622,768 bytes
 Directory of c:\lang\PS19U1\compilers_and_libraries_2019.1.144\windows\redist\ia32_win\mpirt
The 64-bit DLLs are in a different place:
 Directory of c:\lang\PS19U1\compilers_and_libraries\windows\mpi\intel64\bin\debug
10/16/2018  11:34 AM        28,635,368 impi.dll
               1 File(s)     28,635,368 bytes
 Directory of c:\lang\PS19U1\compilers_and_libraries\windows\mpi\intel64\bin\release
10/16/2018  11:34 AM        12,367,080 impi.dll
               1 File(s)     12,367,080 bytes
I have not had reasons to build any MPI applications, so I do not know if any of these DLLs work correctly.
IanH
What do you see in C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\mpirt?  I have no impi.dll, and a mix of versions for some of the other files.
FortranFan
Here's a snip from a new machine where Parallel Studio 2018 Update 1 was recently installed and that's the only version installed on this computer:
mecej4
c:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\mpirt>dir *impi*
 Volume in drive C is Acer
 Volume Serial Number is 5E21-06A2
 Directory of c:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\mpirt
11/13/2018  08:42 PM    <SYMLINK>      impi.dll
10/16/2018  11:34 AM        12,367,080 impimt.dll
               2 File(s)     12,367,080 bytes
Thus, one is a symlink to the other; furthermore, this file is a copy of the file ...\compilers_and_libraries_2019.1.144\windows\mpi\intel64\bin\release\impi.dll
Jon_D
New Contributor II
I am running into the same issue described here with the latest Intel Fortran (2020.0.166). I just installed the 64bit redistributable package and my coarray program says it cannot find the impi.dll file. Is there any resolution to this issue? Any way around it?
Jon
Steve_Lionel
That file ought to be in C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\mpirt and that folder should be in the value of the PATH environment variable. Before going any further, log out and in again and try the program. I have found that sometimes PATH updates don't "take" immediately.
JohnNichols
Valued Contributor III
I just had a NUC go south and so I reinstalled Windows 10  - 18362, VS Preview 2019 and I put up 2019 Fortran Update 1
Here is the listing from the requested directory, everything was stock standard install
JohnNichols
I ran the compilervars - then rebooted and this is the path -- it appears to be there
Steve_Lionel
Hmm - on my system, that "impi" symlink is named impi.dll. Its target is impimt.dll. So one thing you could do is make a copy of impimt.dll in that folder and call it impi.dll.
This might be a bug in the redistributable installer.
Jon_D
New Contributor II
Copying and renaming impimt. dll as impi.dll worked.
This is for a program that will be distributed to folks that don't have Intel Fortran compiler installed. I have been working on this program on and off for some time now, and the last time Intel redistributables worked without this problem was with Intel Fortran 2017. All other versions since then had this issue. I will submit a problem ticket. Hopefully, it will get fixed one day :-(.
