Setting linder ouput file prevents debugging in visual studio
Chris_H_3
TWIMC;
I have set the project properties in visual studio so the compiled program specified by Output File under Configuration Properties\Linker is not the standard place.  When I try to debug the project by running the error pops up, " Failed to load file ..." and points to the executable expected in the debug subdirectory of the solution.  How do I point the debugger at the Output File?
Any thoughts or advice will be appreciated.  Thank you.
Sincerely,
CHobbs
Chris_H_3
Figured it out!
Set the same path to the Output File in the Configuration Properties\Debugging\Command field.
That works.
