Strange OpenMP behavior with OMP_SET_NUM_THREADS
Jon_D
New Contributor II
I have a large program which I am trying to speed up with OpenMP constructs. When I do not specify the number of threads using the OMP_SET_NUM_THREADS library routine, 5 threads are created (according to Resource Monitor in Win 7) and I can see that CPU usage is around 100%. However, when I try to explicitly set the number of threads, I see that as many threads as I asked for are indeed created but the CPU usage hovers around 25% regardless of the number of threads. When I try to replicate the same behavior using a simple test code, I don't see this strange behavior. Has anybody run into this problem? Is this a likely compiler bug or do I need to set some environment variables to get the OMP_SET_NUM_THREADS routine work properly? Any help will be greatly appreciated. Thanks, Jon
Jon_D
New Contributor II
I forgot to mention in my original post. I am using IVF 2013.3.171 under Win 7 Enterprise.
Jon
Steven_L_Intel1
5 threads is an unsuual number - do you have 5 cores or processors on your system? By default it uses the number of "logical processors". What model of processor is in your system and how many? Maybe your program has too much overhead for more (I assume) threads?
Jon_D
New Contributor II
Intel Xeon E5606 with 4 cores. INtel Amplifier shows 4 threads (including the master) but REsource Monitor lists 5.
jimdempseyatthecove
OpenMP may add a watchdog thread (depending on the version of OpenMP). Set break point inside of parallel region, then use debugger threads window. If one of the threads is inside a routine ...watchdog... then this is the case and you can ignore the 5-thread issue (as 4 are worker threads).
Jim Dempsey
Roman1
Can you also try adding the following line to your code:
write(*,*)  "Number of threads = ",  OMP_GET_MAX_THREADS()
Jon_D
New Contributor II
I get
Number of threads = 4.
Steven_L_Intel1
So what are you specifying in the OMP_SET_NUM_THREADS call?
Jon_D
New Contributor II
When I use OMP_SET_NUM_THREADS(3) I get 75% CPU usage as expected. When I try something like
integer :: nt
nt = OMP_GET_MAX_THREADS()
CALL OMP_SET_NUM_THREADS(nt-1)
then CPU usage goes down to 25%. If I set it to a number larger than the number of cores I have (say 12) I still get only 25% CPU usage.
Roman1
I'm a bit confused.  Is this what you are seeing?
CALL OMP_SET_NUM_THREADS(4)   ! results in 100% CPU usage
CALL OMP_SET_NUM_THREADS(3 )  ! results in 75% CPU usage
CALL OMP_SET_NUM_THREADS(12 )  ! results in 25% CPU usage
Just before the code enters the parallel region, can you put the write statement I suggested earlier.  This is to make sure the the number of threads running is what you expect.
Roman
Steven_L_Intel1
Since you have four cores, you are "oversubscribing" which will make execution less efficient.
Jon_D
New Contributor II
Roman, thanks for suggesting to print the number of threads again. It allowed me to figure out what was happening and solve the problem. I have the paralellization in a module compiled as a static library. The calls to set the maximum number of threads are made in a subroutine.  So everytime I call the subroutine I was setting the number of threads to the maximum number of threads less 1. So in 4 calls to the subroutine I was going from 4 threads to 1 thread.I simply needed to set the number of threads once in the main program.
Thanks for the help.
Jon
