29234 Discussões
Unable to start program. Operation not supported. Unknown error 0x80070057
Dix_Carneiro__Rafael
Principiante
5.738 Visualizações
Hi all,
I had to reinstall Intel Fortran and Microsoft Visual Studio on my computer.
I have a set of codes that compile successfully. However, when I attempt to launch the program through Visual Studio, or debug it, I receive an error message "Unable to start program. Operation not supported. Unknown error 0x80070057".
I am using Microsoft Visual Studio 2019 with the Intel Fortran Compiler 2024.1. Please let me know if more details are needed.
Any help would be very much appreciated.
Many thanks,
Rafael
1 Solução
Steve_Lionel
Colaborador honorário III
5.254 Visualizações
Your PATH environment variable has been corrupted with the contents of some HTML document. I suggest you edit this and remove all the text between <! and </html>. This was done by something outside an Intel product.
Ver solução na publicação original
12 Respostas
jimdempseyatthecove
5.717 Visualizações
Does the default New Project/Solution (console executable) aka "Hello World" produce a running program? (select x64)
(Place debug break on end program such that window does not close)
Jim Dempsey
Principiante
5.707 Visualizações
Thank you for the response.
Same issue. See attached.
Principiante
5.675 Visualizações
Maybe this is helpful?
I tried to run the executable of the Hello World program directly. I am receiving the message in the attached screenshot: "libifcoremd.dll not found".
Devorah_H_Intel
Moderador
5.631 Visualizações
  Try to reinstall the HPC Toolkit in admin mode.
Principiante
5.552 Visualizações
I sequentially uninstalled Visual Studio, the fortran compiler and the MKL library. Then, I sequentially reinstalled them running as administrator. I still have the same issue. Please let me know if you need more information.
jimdempseyatthecove
5.470 Visualizações
Can you build a C++ "Hello World" sample application?
Jim Dempsey
Principiante
5.457 Visualizações
Yes, the C++ application compiles and runs successfully.
jimdempseyatthecove
5.428 Visualizações
In order to run a Fortran program from command line or from clicking on File Explorer the Paths to the Intel environment must be set up. The environment is (should be) set up from within MS VS  IDE environment.
.OR.
by launching the appropriate Intel oneAPI command prompt (x64) in this case
then running your app from the command prompt
.OR.
by modifying the system PATH (not advised) to include the Intel development environment or the Intel Fortran Runtime packages environment.
.OR.
by writing a Batch file that sets the PATH, then runs your program
Jim Dempseyh
Principiante
5.411 Visualizações
Just did that. See attached.
Any other suggestions?
jimdempseyatthecove
5.397 Visualizações
Launch oneAPI command prompt x64
issue
dir \libifcoremd.dll /s/b
see if it is found, and where it is found
If not found, then I suspect an installation issue.
if found issue
cd \temp
set path>path.txt
notepad path.txt
Then look to see if the path to the dll is in path.
On my system, dir \libifcoremd.dll /s/b yields:
C:\Program Files (x86)\Intel\oneAPI\2024.0\bin\libifcoremd.dll
C:\Program Files (x86)\Intel\oneAPI\2024.0\bin32\libifcoremd.dll
C:\Program Files (x86)\Intel\oneAPI\compiler\2024.0\bin\libifcoremd.dll
C:\Program Files (x86)\Intel\oneAPI\compiler\2024.0\bin32\libifcoremd.dll
C:\Program Files (x86)\Intel\oneAPI\compiler\latest\bin\libifcoremd.dll
C:\Program Files (x86)\Intel\oneAPI\compiler\latest\bin32\libifcoremd.dll
C:\Program Files (x86)\Intel\oneAPI\toolkit_linking_tool\.envs\2024.0\basekit\compiler\bin\libifcoremd.dll
C:\Program Files (x86)\Intel\oneAPI\toolkit_linking_tool\.envs\2024.0\basekit\compiler\bin32\libifcoremd.dll
C:\Program Files (x86)\Intel\oneAPI\toolkit_linking_tool\.envs\2024.0\hpckit\compiler\bin\libifcoremd.dll
C:\Program Files (x86)\Intel\oneAPI\toolkit_linking_tool\.envs\2024.0\hpckit\compiler\bin32\libifcoremd.dll
And the path.txt file contains:
...;C:\Program Files (x86)\Intel\oneAPI\compiler\latest\bin;...
Jim Dempsey
In particular, see if
Principiante
5.332 Visualizações
Thank you, Jim. I am afraid I will need a bit more guidance, if you don't mind.
dir \libifcoremd.dll /s/b indeed returns a list of file locations.
Then, sequentially I do:
cd \temp -- "The system cannot find the path specified."
set path>path.txt -- "Access is denied."
But if I just do "set path" I get the screenshot attached.
Am I looking at the right place?
Many thanks,
Rafael
Steve_Lionel
5.255 Visualizações
Responder
