Update to Microsoft Visual Studio Community Version 16.6.2 causes IVF 2019.6.324 to fail
avinashs
I updated to Microsoft Visual Studio Community Version 16.6.2 and the integration of IVF 19.6.324 appears to have failed. When compiling, I get the following errors for every file:
1>error #31000: corrupt PDB file Debug\vc160.pdb; delete and rebuild; if problem persists, delete and try /Z7 instead
1>error code 3 ( can't write file, out of disk, etc.) opening pdb Debug\vc160.pdb
1>compilation aborted for abc.f90 (code 1)
I want to avoid having to reinstall IVF. Is this a known issue?
I will add that IVF is working correctly from the command line.
avinashs
When the .pdb file is deleted and the program rebuilt after a clean, the error still persists. After cleaning again and adding the compiler option /Z7, certain subroutines, previously with no error condition, are now generating the following error:
Severity	        Code	     Description	Project
Error		error #5279: Error in opening directory for generated module interfaces: Debug
The release version of the same program does not generate errors.
andrew_4619
seems to me that the file location structure for the project does not match the actual file locations. If you posted the full buildlog.html things might be clearer.
avinashs
@andrew_4619: Thanks for your suggestion. I checked the build log and the .pdb file. It had a size of 0 kb and a weird date of 06/11/2043! When I tried to copy the solution folder to a backup drive, Windows complained there were file system errors. So I finally deleted the folder and recovered a backup from yesterday. It now works as before! So somehow, the act of updating MSVS corrupted the solution folder on my drive. Now I am running normally. Checking the forum posts, it seems such a problem was encountered back in 2013.
