29376 Discussions
Usage of -L flag wih mpiifx command
Engineer99
I am trying to compile a Fortran code using mpiifx command. The code needs to acces .mod files in a library with ".a" extension. I tried to use "-L" and "-l" flags but I get the following error. Could you please help me about it ? My command and following error is;
mpiifx -fpp -free -O3 amrvac.o mod_usr.o -o amrvac -L"C:/Users/kadir/OneDrive/Belgeler/amrvac-master/lib/1d_intel" -lamrvac
ifx: command line warning #10006: ignoring unknown option '/LC:/Users/kadir/OneDrive/Belgeler/amrvac-master/lib/1d_intel'
ifx: command line warning #10006: ignoring unknown option '/lamrvac'
link: unknown option -- s
Try 'link --help' for more information.
ERROR in the compiling/linking [1]
I am using Windows. Thank you in advance.
Shiquan_Su
Hi, there. This reads like a Windows env usage issue, not the compiler product issue. In Windows, there is no -L, the equivalent is /LIBPATH. You probably need to do something similar to the following:
mpiifx /LIBPATH:C:\path\to\library myprogram.f90 -lmylibrary
Shiquan_Su
