Using INTEGER(8) in an INTEGER(4) interface
Jens_E_
新分销商 I
2,186 次查看
I have a question regarding the use of integers of different kind. I am using a library (Intel MKL) which requires INTEGER(4). However, calling this library with variables of kind INTEGER(8) produces identical results.
I have also tested this myself by calling my own method taking an INTEGER(4) with an INTEGER(8).
However, the other way around does not work: calling a method taking an INTEGER(8) with an INTEGER(4).
Is this behavior guaranteed with Intel Fortran?
Jens
0 项奖励
3 回复数
Arjen_Markus
名誉分销商 II
2,186 次查看
Apparently the routine you are calling does not have an explicit interface (via a module for instance), otherwise I would have expected the compiler to complain about the mismatch. The problem with passing an INTEGER(8) variable where an INTEGER(4) variable is expected is that this works by coincidence only. It would go wrong if you were to pass an array: the four extra bytes in the INTEGER(8) variable are now interpreted as the second element of the INTEGER(4) array.
So: do not do that!
0 项奖励
Jens_E_
新分销商 I
2,186 次查看
Yes, in this case there is no explicit interface.
I was just looking for a logical explanation to why I see this behavior - thanks.
Jens
0 项奖励
jimdempseyatthecove
名誉分销商 III
2,186 次查看
If the argument was INTENT(IN) .AND. the value was less than (+/-) 2G, then it may work... but fix your code, and use the MKL module defined interfaces.
If the argument was INTENT(OUT) .OR. INTENT(INOUT), then for the IN portion of the call see above, but for the out portion of the call the 4 bytes of the most significant bytes of your supplied arguments would remain unchanged. Example, if you pass in an argument of less than +2G,  you would not be able to receive a result of -nn.
Jim Dempsey
0 项奖励
回复
