VS 2003 to VS 2008
lklawrie
I'm switching from VS 2003 to VS 2008.
Should I reinstall IVF fortran to get it to appear under VS2008 or is there another way?
Linda
Steven_L_Intel1
A Modify should do it - you will be able to select VS2008 as an integration option.
Do you see an Intel Fortran folder under the Microsoft Visual Studio 9 folder? If so, try running the program attached and see if that does the trick.
TimP
Quoting - lklawrie
You could go into the download directory under Program Filesintel and start the setup icon to try a repair/modify, if it shows that option. The same effect could be achieved on the Add/Remove Programs menu.
lklawrie
Quoting - tim18
It looks like it does it -- gives me that option but it doesn't integrate into VS 2008. (new project does not have Fortran as an option, etc).
I'm trying a reboot, but I don't think that's going to help.
Linda
Steven_L_Intel1
lklawrie
That (running the small app) appears to have done the trick, Steve. Thanks!
You may not remember but you solved a similar problem for me before -- back in the 8.1 days or so. (different machine though).
Linda
