VS 2012 mixed c++ and fortran static library
mifalck
Today we are developing our software using scons as build tool. Which works fine, but is far away from in an integrated solution. Below scons we use the Intel Composer 2013 suite. Which works fine too. For any reason whatsoever we have libraries that contain Fortran, C and C++ code. As said before it works fine with scons. No trying to migrate to the integrated VS solution, I can create a C++ static library or a Fortran static library, But I have no clue how to have both mixed into one one. Sure I can add my foreign element to that project, but it is not compiled there. For sure I can add a custom rule, but that is not the integrated solution.
Does anybody see a solution ?
mecej4
The task of building a library from multiple source languages at the command line using Scons seems to be straightforward. I had not heard of Scons until I saw this post, so I cannot respond to your question concerning the use of Scons in combination with Visual Studio. In Cygwin-32 under Windows 7-64, the following SConstruct script produced the object library libmylib.a from source files myc.c and myf.f:
env = Environment() env.Library(target = 'mylib.a', source = ["myc.c","myf.f"])
The build under Cygwin used gcc and gfortran as the compilers, so you would have to specify your choices of alternative compilers. If you have a native Windows installation of Python and SCons, or because you have been using SCons with the Intel compilers, you may already have scripts that choose those compilers.
mifalck
Again using scons from commandline and having mixed libraries is not an issue.We do this every day. The issue is, if you want to get rid of scons and use VisualStudio as the only toolchain, you will face the problem of mixed libraries.
Steven_L_Intel1
You need to do two things here. 1) Make the C library project a dependent of the Fortran library project. 2) In the Fortran project, set the property Librarian > General > Link Library Dependencies to "Yes". When the Fortran project builds, it will merge in the library from the C project. This won't work the other way around because the Microsoft C++ project system won't do anything with non-C++ dependent projects in VS2012 (and I think in VS2010.)
