Visual Studio IDE issue: blank members drop-down for a module with parameterized derived type and a type with a bound procedure.
FortranFan
With Visual Studio 2013 and Intel Fortran integration using compiler 2015, update 2, the members drop-down for the source window in the IDE shows up empty for the simple module code shown below.  Hopefully the problem is reproducible and it can be directed for a resolution.
module m
   implicit none
   type :: t(n)
      integer, len :: n
      real :: x(n)
   end type
   type, public :: foo
      private
      real, allocatable :: m_x(:)
      type(t(:)), allocatable :: m_t
   contains
      private
      procedure, pass(this), public :: init
   end type foo
contains
   pure subroutine init(this, x, irc)
      !.. Argument list
      class(foo), intent(inout) :: this
      real, intent(in)          :: x(:)
      integer, intent(inout)    :: irc
      !.. Local variables
      integer :: size_x
      irc = 0
      size_x = size(x)
      if (size_x > 0) then
         allocate( t(size_x) :: this%m_t, stat=irc )
         if (irc /= 0) return
         this%m_t%x = sqrt(x)
         this%m_x = x
      else
         irc = 1
      end if
      return
   end subroutine init
end module m
FortranFan
Here' a screen image of the source window in the IDE that shows the empty list:
Steven_L_Intel1
Thanks - I've seen issues like this before and will let the developers know.
FortranFan
FWIW, line 13 (where a PDT is a component of a derived type) seems to be the issue; commenting that line out immediately adds init to the members drop-down list.
Steven_L_Intel1
Escalated as issue DPD200366573.
