What is IMPLICIT UNDEFINED?
avinashs
I am reviewing some legacy Fortran code implementing a numerical algorithm and it contains the statement IMPLICIT UNDEFINED (A-H,O-Z). I have never come across such a statement before. Is it the same as IMPLICIT NONE? It should be fairly easy to comment out or replace.
mecej4
It is an old Sun Fortran extension. You can replace it by IMPLICIT NONE and move on.
mecej4
FortranFan
GVautier
New Contributor III
Take care that
will leave I-N implicitly defined
IMPLICIT NONE
will undefine all variables.
For me, if it is legal :
IMPLICIT NONE
IMPLICIT INTEGER (I-N)
will only be equivalent to
Steve_Lionel
It is legal to have multiple IMPLICIT statements as long as there is only one IMPLICIT NONE.
JAlexiou
The two statements are not equivalent. One defines I,J,K,L,M and N as INTEGER while the other doesn't.
GVautier
New Contributor III
Hi
I presumed that if the IMPLICIT UNDEFINED (A-H,O-Z) statement was used in this code it was because the compiler used to compile it always define implicit types (A-H,O-Z) as real and (I-N) as integer as old compilers used to. So the aim of this statement was to keep integer variables defined.
Otherwise, the IMPLICIT NONE statement would have been used.
