What language would they have used
JohnNichols
Valued Contributor III
I stumbled across this little gem, it is correct - checked it with excel -- did they likely do it in Fortran and what algorithm do you think they used?
https://www.ams.org/journals/mcom/1967-21-099/S0025-5718-1967-0222008-0/S0025-5718-1967-0222008-0.pdf
This paper sets out some of the findings as well from 1967,  this is a big search and overflow would be a real issue
The two are from the aerospace co - why would they be interested in this pure math --
JohnNichols
How do I make it threaded to speed up the analysis
!  Console100.f90
!  FUNCTIONS:
!  Console100 - Entry point of console application.
!  PROGRAM: Console100
!  PURPOSE:  Entry point for the console application.
    program Console100
    implicit none
    double precision a(1000), b(1000), count, sum
    integer i,j,k,l,g,h
    ! Variables
    ! Body of Console100
    print *, 'Hello World'
    open(1,file="f.out",status="unknown")
    count = 1.0
    h = 144
    do 100 i = 1,h
        a(i) = count*count*count*count*count
        b(i) = a(i)
        write(2,*)i, a(i)
        count = count + 1.0
100 end do
    do 200 i = 1, h
        write(1,*)i
        do 300 j = 1, h
            do 400 k = 1, h
               !   write(*,*)i,j,k
                do 500 l = 1,h
                    sum = a(i) + a(j) + a(k) + a(L)
                    write(1,*)(sum**0.2)
                    do 600 g = 1, h
                        if(sum .eq. b(g)) then
                         write(1,*)">>>>>>>>>>>>>>>>>>>>>>",g, sum
                         end if
600                 end do
500             end do
400         end do
300     end do
200 end do
    end program Console100
 - this i brute force - we should be able to speed it up - optimize operations
mecej4
Curiously, the same right hand value, i.e., 144^5, can be expressed as the sum of the 5th powers of 5 integers:
      a^5 + b^5 + c^5 + d^5 + f^5 = n^5 = p^5 + q^5 + r^5 + s^5
for a = 38, b = 86, c = 92, d = 94, f=134, and n = 144. As stated in the paper, p = 27, q = 84, r = 110, s = 133.
Furthermore, all the numbers a, b, c, d, f and n are even.
A related curious fact: The fifth power of any integer has the same last digit as the number itself does. This property can be used when testing if a given integer is the fifth power of an integer.
Wikipedia has an article on the conjecture, see https://en.wikipedia.org/wiki/Euler%27s_sum_of_powers_conjecture .
According to the article, the truth of the conjecture remains an open question when the exponent k > 5.
P.S. (3 Aug 2020):
Some additional information follows. The paper that JMN attached is one of the shortest published journal articles in existence (it consists of two sentences). A more detailed paper, of which Lander is also an author, is https://www.ams.org/journals/mcom/1967-21-099/S0025-5718-1967-0222008-0/S0025-5718-1967-0222008-0.pdf . In the notation introduced in that paper, the 2-sentence paper announces a (5. 1. 4)<sub>1</sub> "primitive" solution.
The solution that I gave above is a (5. 1. 5) solution, which I obtained from a program in which I started with n = 144 and searched for a few smaller values of n, but it is not primitive, and therefore is not to be found in Table III of the longer AMS paper. If we divide each of the numbers in the equality by 2, the result is the first entry, which IS primitive:
a = 19, b = 43, c = 46, d = 47,  f = 67 and n = 72
A distributed computing project targeting sums of sixth powers is described at http://euler.free.fr .
JohnNichols
I am of the opinion that the Lander solution actually should include 0 to the 5th paper, it is just the zero on the function can be represented with 4 integers > 0, it is really a zero, was one thought .
So I am not sure Euler was theoretically wrong, just a way of expressing the answer.
It is very slow for even 144.
JohnNichols
 It is unknown whether the conjecture fails or holds for any value k ≥ 6.
We can show it fails, but I doubt we can prove it is true,  we cannot represent all the numbers in a computer accurately in a time that can be managed - is a suggestion -- proving it by pure math - not sure.
JohnNichols
Actually for k> 6 we should work out an algorithm that finds each zero quickly
JohnNichols
And the brute force solution finds 24 solutions for the set 0 -144 run 4 times
in about 10 minutes on a core i5
andrew_4619
I would guess looking at number theory will yield some smarter method. But why not to your example with I8  rather that real. Also as a<b<c<d why not have the finding loop i+1, h   and j+1, h etc at least then you look at less combos.
Also have found an answer you can exit the test  loop rather than continue
JohnNichols
1. which is the bigger potential number the i8 or the double precision
2. Yes, lying in bed last night, I was doing the loops in my head, if I follow your idea I will reduce the loop count by the factorial of k-1.
3. I have a spare NUC I can turn the problem loose on or I can use a supercomputer
4. I was then going to turn the problem loose on 6.
JohnNichols
I wanted to test it all the way through - so yes I will put a stop in it.
JohnNichols
Is there anything I can do to optimize the 4 do loops
 !  Console100.f90
    !  FUNCTIONS:
    program Console100
    implicit none
    integer i,j,k,l,g,h,m,n,p
    ! Variables
    open(1,file="f.csv",status="unknown")
    count = 1.0
    h = 4
    m = 1
    n = 1
    p = 1
    k = 0
    l = 0
    j = 0
    sum = 0.0
    do 100 i = 1,h
        b(i) = a(i)
        !write(2,*)i, a(i)
        count = count + 1.0
100 end do
    i = 0
    do 200 i = 1, h
        if(i .gt. 1) then
            p = i
        end if
        do 300 j = p,h
            if(j .gt. 1) then
                m = j
            end if
            do 400 k = m,h
                if(k .gt. 1) then
                n = k
            end if
                do 500 l = n,h
                !sum = a(i) + a(j) + a(k) + a(l)
                write(1,1000)i,j,k,l, sum
                write(*,1001)i,j,k,l
1000            Format(i5,',',i5,',',i5,',',i5,',' f15.1)
1001            Format(i5,'  ',i5,'  ',i5,'  ',i5)
500   end do
400         end do
300     end do
        write(*,*)'  '
200 end do
JohnNichols
    do 200 i = 1, h
       ! if(i .gt. 1) then
       !     p = i
      !  end if
        do 300 j = i,h
       !     if(j .gt. 1) then
       !         m = j
       !     end if
            do 400 k = j,h
       !         if(k .gt. 1) then
       !!         n = k
       !     end if
                do 500 l = k,h
500   end do
400         end do
300     end do
        write(*,*)'  '
200 end do
JohnNichols
That is like the old code from the 1960s - you were lucky to understand it at all
JohnNichols
It is just a random fluke of nature that the odd one works
The addition of four fifth order functions equated to a single fifth order function is an exercise, see picture in one function almost following the other -- there is an error between them -- I would guess likely Gaussian or log Gaussian and at one point the error = 0
For some reason I could not insert a picture -- the grey is the fifth order function and the two dots are the first two sets of the four additions.
JohnNichols
Hp Envy Corei5 65 seconds of cpu time - I wonder how long on the CDC 6600
JohnNichols
Found second one - after 4 hours -- 54 168 220 266 - it is the double of the first one,
so next one is likely 108 336 440 532   = 576
next one 216 672 880 1064 =  1152
JohnNichols
1. I am of the opinion that lander did not have enough computing time to find the second one-- it took forever,
2. can I represent this number as an integer.
6.34034E+13
GVautier
New Contributor III
I implemented unlimited length integer computation (add, sub, mul and div). Not very efficient in term of speed but it works.
JohnNichols
I was wrong, there are more, they are not common about 1 in a million combinations to the first 1000, after 12 hours I am 135 - not even cracked the
it appears so far on second glance they are all integer multiples of the first one - or
27 54 81 108 135
27 = 3*3*3
54 = 3*3*3*2
81 = 3*3*3*3
135 = 3*3*3*5
81 252 330 339  - this is the addtion of the first two -
135 420 550 665   - 135 seems weird - it is still going --  at the moment I have it searching to the first 1000 -- I can probbaly do to about 6000 on the rhs before we have an integer fail.
Speed is not a problem - I have spare computers all over the place - some faster than this one --
I want to try 6 next.
I would appreciate the unlimited integer math
There is a pattern to the numbers all based on 3.  let us see if we find more
JohnNichols
162 504 660 798  just popped up
next one is
189 588 770 931 - should find it in about an hour
JohnNichols
144 = 3*3*2*2*2
There is a simple beauty to them ==
Trick is -- are there any others
Guys:
Can you take a look at the code and show me how to thread it or OMP --
