29285 Discussions
What on earth is this multi-threading stuff?
WSinc
I am trying to run a simple numerical integration program, and it is giving me a strange error I've never seen before.
It's getting into a "multi-thread locking routine" and generating an unhandled exception error. I don't have any intention of using multi-threading whatsoever.
When I remove the DO WHILE loop (just have it run thru the code once) the problem disappears.........
Anyway, there is no reason why I'd want to use multi-threading, and I don't see why it would force that on me.
There are only two executable statements in the loop, and this problem appears even after I do a CLEAN and rebuild.
So I don't think it's the subroutine interface.
Is there a way to PREVENT this?
subroutine testRK()
implicit none
parameter NVAR=4
real*16 y(NVAR),yd(NVAR),t,dt
print *,"t,dt="
read *,t,dt
do while (.true.) ! this causes the problem
call rkstep(y,yd,t,dt)
print 101,t,y,yd
101 format(5f20.12/20x,4f20.12)
end do
return
end
Steven_L_Intel1
Can you give more details about the error you're having? Which version of VS are you using? While you are not using multithreading, the run-time libraries are "thread-safe" and have code to protect themselves when threading is in use. An exception should not occur - perhaps you have an error in your code that is corrupting data somewhere.
WSinc
I think I've found the problem -
One of the variables in the subroutine I called was not REAL*16, it was REAL*4.
But what I don't understand is why the interface checking feature did not catch that.
I had both Warn-interface AND GEN-interface turned on, and did a CLEAN and REBUILD before I started execution.
The VS I'm using is 2008.
Yours; Bill
Steven_L_Intel1
Hard to say. If the order of compilation that VS chose didn't build the subroutine first, that could happen. Glad to hear you sorted it out. In the future, I suggest using module procedures so you'll always have an explicit interface.
