29235 Discussions
Will be Library built in Cygwin work in Intel Fortran?
julia_mel
I have a problem when build the project in Intel Fortran, previously built in CVF.
fatal error LNK1104: cannot open file 'dfor.lib' LINK
But as I know, two .lib files were built not in CVF, but in CYGWIN.
Should I have these two .lib files rebuilt in Intel Fortran?
Best wishes, Julia
TimP
Quoting - julia_mel
That reference to dfor.lib shows that an objectwas built by CVF, so you should rebuild it. It doesn't matter whether the object was built under a cygwin shell, what matters is the different run-time libraries required by each compiler.
julia_mel
Quoting - tim18
Thank you very much)
