advance = 'no'. Error: A non-advancing READ immediately following a non-advancing WRITE
riad_h_1
新手
1,917 檢視
Dear all,
since the last update of ifort, I get the runtime error: "A non-advancing READ immediately following a non-advancing WRITE on the same unit number is not allowed, unit 5".
I show below a simplified version of the part where the error is produced (this sample works well with gfortran and nagfor). I need to use advance='no' in the read statement since the length of the record is not known.
The error message is somewhat ambiguous and surprising since the units are not the same.
In this example, the error is reported at the 2nd iteration.
  use, intrinsic :: iso_fortran_env, only:  uin=>input_unit, uout=>output_unit, uerr=>error_unit, iostat_eor
  implicit none
  integer, parameter               :: lstr = 1000, mstr = 100
  integer                          :: iostat, size, i
  character(len=lstr)              :: iomsg
  character(len=mstr)              :: buf
  character(len=:   ), allocatable :: line
  do i = 1, 10
     ! print the prompt:
     write(uout, '(a)', advance='no') "--> "
     ! read until end-of-record:
     line = ''
     do
        read(uin, '(a)', advance='no', iostat=iostat, iomsg=iomsg, size=size) buf
        if (iostat > 0 .or. (iostat < 0 .and. iostat /= iostat_eor)) then
           write(uerr, '(a)') trim(iomsg)
           stop
        end if
        line = line // buf(:size)
        if (iostat == iostat_eor) exit
     end do
     write(uout,'(a)')'line = '//trim(line)
  end do
end
5 回應
riad_h_1
新手
1,917 檢視
Hi  Ferdinand and thank you for your comment and example.
Yes, I indeed forgot  to put the flush statement in the sample but is well present in my real code. Unfortunately (and even with your example) it crashes with the aforementioned message when compiling with ifort 19.1 (for mac) but it doesn't when compiling with the previous version (19.05).
Best regards
Ferdinand_T_
新貢獻者 II
1,917 檢視
Maybe this issue is caused by changes in how the fortran runtime interacts with buffered terminal in/output?
Consider this (which crashes on the same error):
read(5, *)
write(6, '(a)', advance='no') 'x'  !; flush(6)
read(5, '(a)', advance='no')
end
But if you comment in the flush statement, it works.
So as a workaround, you could try to flush(uout) in line 14.
EDIT (in response to #3) ---------------------------------------------
Results for the above (short) example, generated on Red Hat Enterprise Linux Server release 7:
VERSION     NO FLUSH  WITH FLUSH
19.0.3.199  crash     ok
18.0.5.274  crash     ok
17.0.6.256  crash     crash
16.0.4.258  ok        ok
Ferdinand_T_
新貢獻者 II
1,917 檢視
Hi Riad,
I had tested on linux, see my updated post (#2).
Alternatively, would if work if you simply ignored the error? On my setup I got iostat=126, so how about adding line 19 as follows:
if (iostat == 126) cycle
Of course, this does neither fix nor explain the origin of the error...
Best, Ferdinand
riad_h_1
新手
1,917 檢視
I will adopt your solution (but IOSTAT values are certainly not standard, most likely compiler dependent) and, in the meantime, I will report the problem to the Online Service Center.
Thanks Ferdinand
Riad
andrew_4619
榮譽貢獻者 III
1,917 檢視
If you use ISO_FORTRAN_ENV Module then you have  constants such as IOSTAT_END or IOSTAT_EOR which is standard Fortran
回覆
