I get an error when trying to check the association status of a procedure pointer, that is a member of a derived type. When the procedure pointer is not declared inside a derived type, there is no error.
TL;DR
associated(mytype%ptr, target=func1) ! error #6423
associated(ptr, target=func1) ! no error
Here is a MWE of the working version:
module routines
implicit none
abstract interface
real function if() result(y)
implicit none
end function
end interface
contains
! def two functions with interface `if`
real function func1() result(y)
implicit none
y=1.
end function
real function func2() result(y)
implicit none
y=2.
end function
end module routines
program main
use routines
implicit none
procedure(if), pointer :: ptr
print *, 'set ptr to func1'
ptr => func1
print *, 'is ptr associated with func1', associated(ptr, target=func1)
print *, 'is ptr associated with func2', associated(ptr, target=func1)
print *, 'call ptr', ptr()
end program
The following code
module m_routines
implicit none
abstract interface
implicit none
end function
end interface
type wrap_ptr
procedure(if), nopass, pointer :: ptr => null()
end type
contains
subroutine m_routines_select_ptr(this, i)
implicit none
class(wrap_ptr), intent(inout) :: this
integer, intent(in) :: i
if(i==1) this%ptr => func1
if(i==2) this%ptr => func2
end subroutine
implicit none
y=1.
end function
implicit none
y=2.
end function
end module m_routines
program main
use m_routines
implicit none
type(wrap_ptr) foo
foo%ptr => func1
print *, 'is ptr associated with func1', associated(foo%ptr, target=func1) ! error #6423
print *, 'is ptr associated with func2', associated(foo%ptr, target=func2) ! error #6423
print *, 'call ptr', foo%ptr()
end program
compiles with this error
assoc_in_type.f90(42): error #6423: This name has already been used as an external function name. [FUNC1]
using ifort, but compiles well with gfortran.
My newest available version of ifort is `19.1.2.254 20200623`.
My gfortran version is `gcc version 7.5.0 (SUSE Linux)`
The only reference I found was a comment of @SteveLionel here.
Is this a compiler bug or a subtlety of the standard?
Looks like a bug to me. The standard says, for ASSOCIATED: "TARGET (optional) shall be allowable as the data-target or proc-target in a pointer assignment statement (10.2.2) in which POINTER is data-pointer-object or proc-pointer-object. If TARGET is a pointer then its pointer association status shall not be undefined."
Clearly foo%ptr is "allowable as a proc-target in a pointer assignment statement" - indeed, you did that on the previous line. I know of no reason why a pointer component would be disallowed but a pointer variable allowed.
@AAK ,
For whatever it's worth, your code looks conformant to me. Submitting a support request at Intel OSC or expecting Intel staff to pick it from here makes sense.
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
