combined 2 strings in vb with fortran dll
Lu_Zhang
Hi, guys, I try to combine 2 strings using VB with fortran dll, but it does not work. How can I make it?  Thanks!
//vb code
Public Declare Sub DLL_ROUTSTR Lib "D:\Debug\Dll4.dll" _
    (ByVal A As String, ByVal B As String, ByRef C As String)
    Public Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Dim A As String
        Dim B As String
        Dim C As String
        A = TextBox1.Text
        B = TextBox2.Text
        Call DLL_ROUTSTR(A, B, C)
        TextBox3.Text = C
    End Sub
//fortran code
SUBROUTINE DLL_ROUTSTR (A, B, C)
IMPLICIT NONE
! Specify that DLL_ROUTSTR is exported to a DLL
! and that the external name is 'DLL_ROUTSTR'
!DEC$ ATTRIBUTES DLLEXPORT, STDCALL :: DLL_ROUTSTR
!DEC$ ATTRIBUTES ALIAS:'DLL_ROUTSTR' :: DLL_ROUTSTR
!DEC$ ATTRIBUTES REFERENCE :: A,B,C
CHARACTER(10), INTENT(IN) :: A, B
CHARACTER(10), INTENT(OUT) :: C
C = A // B
RETURN
END
Steve_Lionel
You can't do it this simply - strings in VB are a strange beast. The provided sample VB.NET-SafeArrays demonstrates the use of the BSTR library routines to convert Fortran strings and do concatenation.
I will Also comment that your Fortran code, as is, will simply assign A to C, ignoring B, because all 10 characters of A are used, leaving none left over for B. C=TRIM(A)//TRIM(B) might be more what you had in mind, but I doubt this will translate back to VB as it will have no idea what the new length is to be.
FortranFan
.. I try to combine 2 strings using VB with fortran dll, but it does not work. How can I make it?   ..
Same concept as your other thread: see Quote #7. https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/807421
But this time, use StringBuilder class instead of String in Microsoft .NET and explicitly pass object lengths to Fortran to be "safe".  On the Fortran side, interoperate with .NET using the C interoperability feature in standard Fortran (which is also explained in books such as this: https://books.google.com/books?id=sB1rDwAAQBAJ&source=gbs_similarbooks)
Fdll.f90:
module m
   use, intrinsic :: iso_c_binding, only : c_char, c_int, c_f_pointer, c_loc
   implicit none
contains
   subroutine DLL_ROUT(A, lenA, B, lenB, C, lenC) bind(C, name="DLL_ROUT")
   !DEC$ ATTRIBUTES DLLEXPORT::DLL_ROUT
      !.. Argument list
      character(kind=c_char,len=1), intent(in), target    :: A(*)
      integer(c_int), intent(in), value                   :: lenA
      character(kind=c_char,len=1), intent(in), target    :: B(*)
      integer(c_int), intent(in), value                   :: lenB
      character(kind=c_char,len=1), intent(inout), target :: C(*)
      integer(c_int), intent(in), value                   :: lenC
      block
         character(kind=c_char,len=lenA), pointer :: pA => null()
         character(kind=c_char,len=lenB), pointer :: pB => null()
         character(kind=c_char,len=lenC), pointer :: pC => null()
         call c_f_pointer( cptr=c_loc(A), fptr=pA )
         call c_f_pointer( cptr=c_loc(B), fptr=pB )
         call c_f_pointer( cptr=c_loc(C), fptr=pC )
         pC = pA // pB
         pA => null()
         pB => null()
         pC => null()
      end block
      return
   end subroutine DLL_ROUT
end module m
VB file:
Imports System.IO
Imports System.Text
Imports System.Runtime.InteropServices
Namespace Fortran
   Public Class Fdll
      <DllImport("c:\Debug\Fdll.dll", CallingConvention:=CallingConvention.Cdecl)> _
      Public Shared Sub DLL_ROUT (A As StringBuilder, lenA As Integer, B As StringBuilder, lenB as Integer, _
                                  C As StringBuilder, lenC As Integer)
      end Sub
   End Class
   NotInheritable Class Test
      Private Sub New()
      End Sub
      Public Shared Sub Main()
         Dim a As StringBuilder
         Dim b As StringBuilder
         Dim c As StringBuilder
         ' Write header
         Console.WriteLine("*** Test Fortran Interop using VB ***" + vbLf)
         Try
            a = New StringBuilder("Hello ")
            b = New StringBuilder("World!")
            c = New StringBuilder
            c.Length = a.Length + b.Length
            Fdll.DLL_ROUT(a, a.Length, b, b.Length, c, c.Length)
            Console.WriteLine("c = " + c.ToString())
         Catch ex As Exception
            Console.WriteLine(ex.Message)
         Finally
            Console.WriteLine("Press any key to continue..")
            Console.ReadKey()
         End Try
      End Sub
   End Class
End Namespace
C:\Debug>ifort /dll /libs:static Fdll.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.3.203 Build 20190206
Copyright (C) 1985-2019 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 14.16.27027.1
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:Fdll.dll
-dll
-implib:Fdll.lib
Fdll.obj
   Creating library Fdll.lib and object Fdll.exp
C:\Debug>vbc -platform:x64 test.vb
Microsoft (R) Visual Basic Compiler version 2.10.0.0 (b9fb1610)
C:\Debug>test.exe
c = Hello World!
C:\Debug>
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on IA-32, Version 19.0.3.203 Build 20190206
-out:Fdll.dll
-dll
-implib:Fdll.lib
Fdll.obj
C:\Debug>vbc -platform:x86 test.vb
C:\Debug>test.exe
c = Hello World!
C:\Debug>
Lu_Zhang
Thank you Steve.
Lu_Zhang
Thank you FortranFan. Did you run it in Visual Studio? I build a VB console project in VS15, and run the code below, it gives me some errors, see attached picture. Looks like it doesnot recognize NAMESPACE.
Module Module1
    Imports System.IO
    Imports System.Text
Namespace Fortran
    Public Class Fdll
        <DllImport("D:\Debug\Dll5.dll", CallingConvention:=CallingConvention.Cdecl)>
        Public Shared Sub DLL_ROUT(A As StringBuilder, lenA As Integer, B As StringBuilder, lenB As Integer, _
      End Sub
    End Class
        Private Sub New()
        End Sub
            ' Write header
            Try
            Finally
                Console.ReadKey()
            End Try
        End Sub
    End Class
End Namespace
End Module
FortranFan
Lu Zhang wrote:
Thank you FortranFan. Did you run it in Visual Studio? ..
See Quote #3 again, there are 2 {..}code paste sections in it showing exactly the steps that were followed from an appropriate command line where all the required configurations and paths have been set up.  You can try to mimic the same.
Please note this is a Fortran forum.  What you are asking in Quote #5 is how to setup a Visual Basic .NET console application solution and a project in Visual Studio - there are near INFINITE resources available, particularly online, as to how to accomplish this task, please refer to one or more of them - you can start with a web search.
Lu_Zhang
Got it. Thanks again for your big help.
