error #6227: This symbol has multiple POINTER statement/attribute declarations which is not allowed
Andrew_Smith
Valued Contributor I
This used to coumple but XE2017 update 2 breaks it. I cannot find a workaround.
Simplest example. The submodule would normally be in a sepeeate file but it makes no difference to the bug:
module A
   implicit none
   interface
      module function getItem(id)
         integer, intent(in) :: id
         real, pointer :: getItem
      end
   end interface
   real, target :: items(10)
end module
submodule(A) A1
   implicit none
contains
      getItem => items(id)
   end
end submodule
Andrew_Smith
I found a workaround if I make the interface declaration and and implementer use a "result" type of return.
I had re-written most of my functions similar to this already because of similar bugs in earlier compiler handling of submodule functions.
module function getItem(id) result(foo)
   real, pointer :: foo
Devorah_H_Intel
Hi Andrew,
Thank you for the report, I will escalate this to our Fortran Engineering team. There shouldn't be an error.
