This used to coumple but XE2017 update 2 breaks it. I cannot find a workaround.
Simplest example. The submodule would normally be in a sepeeate file but it makes no difference to the bug:
module A
implicit none
interface
module function getItem(id)
integer, intent(in) :: id
real, pointer :: getItem
end
end interface
real, target :: items(10)
end module
submodule(A) A1
implicit none
contains
getItem => items(id)
end
end submodule
I found a workaround if I make the interface declaration and and implementer use a "result" type of return.
I had re-written most of my functions similar to this already because of similar bugs in earlier compiler handling of submodule functions.
module function getItem(id) result(foo) real, pointer :: foo
Hi Andrew,
Thank you for the report, I will escalate this to our Fortran Engineering team. There shouldn't be an error.
