error #6416: This COMMON scalar or array is invalid in this context.
Vinod
i am trying to modify a very complex existing code. but I am getting this error. I am updating this to use dynamic memory allocation. I can not share the whole code. but I am attaching a dummy code made  in the same way as the things are being done origianally. during building process, I am getting the error #6416.
Operating syste: Win 7 (enterprise edition)
Interface: Visual Studio 2010
Compiler: Intel(R) Visual Fortran Composer XE 2011 Update 8
 Intel Form.zip contains the complete project.
Any help in this topic will be highly appreciated.
Thank you very much in advance.
Vinod
jimdempseyatthecove
You can use fixed form too, the following uses .f90 format:
[fortran]
! RXN.F90
module RXN
      INTEGER :: NCOMP
      CHARACTER*30, ALLOCATABLE:: COMPID(:)
      contains
      integer function AllocateCOMPID(n)
           integer :: n
           ALLOCATE(COMPID(NCOMP), STAT = AllocateCOMPID
           if(AllocateCOMPID .eq. 0) NCOMP = n
      end function AllocateCOMPID
end module RXN
! yourProgram.f90
      PROGRAM MAIN
      use RXN
      INTEGER NCOMP,I, iError
      OPEN (UNIT=5,  FILE="input.txt")
      READ (5,*) I
      iError = AllocateCOMPID(I)
      if(iError .ne. 0) STOP "Allocation Error"
      READ (5,*) (COMPID(I),I=1,NCOMP)
      CLOSE(5)
      CALL DISPLAY()
      END
      SUBROUTINE DISPLAY()
         use RXN
         WRITE(*,*)  (COMPID(I),I=1,NCOMP)
      END SUBROUTINE
 [/fortran]
Jim Dempsey
Steven_L_Intel1
You cannot put an allocatable array in COMMON. The typical solution to this would be to make COMPID a module variable in a module that was USEd by all the procedures that needed to reference it.
Vinod
! RXN.F90 module RXN       INTEGER :: NCOMP       CHARACTER*30, ALLOCATABLE:: COMPID(:)       contains       integer function AllocateCOMPID(n)            integer :: n            ALLOCATE(COMPID(NCOMP), STAT = AllocateCOMPID            if(AllocateCOMPID .eq. 0) NCOMP = n       end function AllocateCOMPID end module RXN ================================ ! yourProgram.f90       PROGRAM MAIN       use RXN       INTEGER NCOMP,I, iError       OPEN (UNIT=5,  FILE="input.txt")       READ (5,*) I       iError = AllocateCOMPID(I)       if(iError .ne. 0) STOP "Allocation Error"       READ (5,*) (COMPID(I),I=1,NCOMP)       CLOSE(5)       CALL DISPLAY()       END       SUBROUTINE DISPLAY()          use RXN          WRITE(*,*)  (COMPID(I),I=1,NCOMP)       END SUBROUTINE
Jim Dempsey
Dear Jim,
Thank you very much for your input. I tried the code sent by you. I could build the application successfully. But, now I am getting a run-time error, which is not clear to me. It allocated 5 array elements to COMPID (i assume this as there is no error display during the execution) as per the input file. now after the allocation, it should read 5 elements from the next row of input file. But it gives the following error:
forrt1: sever(408): fort(2): subscript #1 of the array COMPID has value 1 which is greater than the upper bound of 0.
I tried to see COMPID (1) in watch window, and it says "Compid(1) -  Subscript out of range".
This seems that the allocation was not successful. But I didnot get any error displayed on the screen. Could you please help me further, as I am new to this module thing.
Vinod
Jim Dempsey
Dear Jim,
Thank you very much for your time and valuable comment. I tried this code and I could build successfully. But this time I am getting a runtime error. While reading second line from the input file, it says:
forrt1: severe(408): fort: (2): subscript  #1 of the array COMPID has value 1 which is greater than the upper of 0.
I don't understand why the code is giving this error, as I did not get any allocation error.
Could you please help me out of this?
Thank you very much.
Vinod
Vinod
Dear Steve,
Thank you for your input. I am trying this. Hopefully the problem will be resolved soon.
Vinod
Vinod
Dear Jim & Steve,
The problem has been resolved. Thank you very much for your help.
With best regards,
Vinod
Vinod
Jim Dempsey
Dear Jim & Steve,
Thank you very much for your inputs. The problem has been resolved.
Vinod
