29274 Discussions
error #6689: An assumed-shape array must be declared as a dummy argument.
rostislavhrtus
Hello, Im trying to improve SW by modules. However, there are some issues which I dont understand well.
It says an error like in the topic.
Question: is it really necessary to define inside a module an interface while using assumed shape arrays (passing as an argument into subroutine/function)?
the code (there are some errors, but here is important just that arrays passing and solving is also substituted just by copying):
program main
use variables
use routines
implicit none
integer :: tellme, input
input= 2
allocate(A(input,input),x(input),b(input))
A= fillMatrixA(input)
b= fillVectorb(input)
tellme= solveLinSystem(input)
write(*,*) 'tellme ',tellme
end program main
module routines
use variables
implicit none
contains
c Function for filling matrix A
function fillMatrixA(n)
integer (kind=4) n, i, j
real (kind=8) fillMatrixA(:,:)
allocate(fillMatrixA(n,n))
do i=1,n
do j=1,n
if (i.eq.j) then
fillMatrixA(i,j)=1.d0
else
fillMatrixA(i,j)=0.d0
endif
end do
end do
end function fillMatrixA
c Function for filling vector b
function fillVectorb(n)
real (kind=8) fillVectorb(:)
do i=1,n
fillVectorb(i)=1.d0
end do
end function fillVectorb
c Function for solving linear system of equations
function solveLinSystem(A,b,n)
real (kind=8) :: A(:,:), b(:)
integer (kind=4) n
real (kind=8), allocatable :: solveLinSystem(:)
allocate(solveLinSystem(n))
solveLinSystem= b
end function solveLinSystem
end module routines
And to finish this - error from compiler:
-bash-4.1$ make -f run.mk newrun
ifort -c variables.for
ifort -c routines.for
routines.for(12): error #6689: An assumed-shape array must be declared as a dummy argument. [FILLMATRIXA]
routines.for(33): error #6689: An assumed-shape array must be declared as a dummy argument. [FILLVECTORB]
routines.for(14): error #6724: An allocate/deallocate object must have the ALLOCATABLE or POINTER attribute. [FILLMATRIXA]
routines.for(10): error #6688: The array-spec for a function name with no POINTER attribute must be an explicit shape array (R505.9). [FILLMATRIXA]
routines.for(35): error #6423: This name has already been used as an external function name. [FILLMATRIXA]
routines.for(31): error #6688: The array-spec for a function name with no POINTER attribute must be an explicit shape array (R505.9). [FILLVECTORB]
compilation aborted for routines.for (code 1)
mecej4
Formal arguments of subroutines and function return variables that are allocatable should be declared with the ALLOCATABLE attribute, even if allocation is accomplished without explicit ALLOCATE statements.
For example, replace
[fortran]real (kind=8) fillMatrixA(:,:) [/fortran] by
[bash]real (kind=8), allocatable :: fillMatrixA(:,:) [/bash]
