error LNK2019: unresolved external symbol' emerge when calling IMSL lib
lu_z_
   Hi, I got a linking error when I tried to call IMSL function (parallel studio xe 2015 + IMSL6.0), which read like
1>imsl.lib(r1int.obj) : error LNK2001: unresolved external symbol  ___kmpc_threadprivate_cached
1>imsls_err.lib(flexlm.obj) : error LNK2001: unresolved external symbol  ___kmpc_critical
1>imsls_err.lib(e1lock.obj) : error LNK2001: unresolved external symbol  ___kmpc_end_critical
  and a lot of similar error message
From https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/285970  I have known that it was likely due to incorrect setting of lib path. However, even I have added the imsl.lib and imsls_err.lib to project>>properties>>linker>>input>>Additional Dependencies. The problem remains. can someone help me to fix this problem
Following is a snippet of problematic code
subroutine sub_tauchen(y,pi,picum,rho,sigma,n,cover_tauchen)
    INCLUDE 'link_fnl_static.h'
	!use msimsl  ! need ISML lib already be installed
	use mod_types
    use ANORDF_INT
    !USE NUMERICAL_LIBRARIES
	implicit none
	integer, intent(in) :: n
	real(dp), intent(in) :: rho, sigma, cover_tauchen
	real(dp), dimension (n,n), intent(out) :: pi , picum
	real(dp), dimension (n), intent(out) :: y
	integer :: yc, tc, tcc
	real(dp) :: sigy, mu, upp, low
	! Define the discrete states of the Markov chain
	sigy = sigma/sqrt(1.0-rho**2)
	y(n) = cover_tauchen*sigy !%(sqrt(n)/sqrt(2.0))*sigy ! good for 0.007, increase later
	y(1) = -y(n)
	do yc = 2, n-1
		y(yc) = y(1)+(y(n)-y(1))*(yc-1.0)/(n-1.0)
	end do
	! Compute the transition matrix
	do tc = 1,n
		mu = rho*y(tc)
		upp = (y(2)+y(1))/2.0
		upp = (upp-mu)/sigma
		pi(tc,1) = ANORDF(upp)
		low = (y(n)+y(n-1))/2.0
		low = (low-mu)/sigma
		pi(tc,n) = 1.0-ANORDF(low)
		do tcc = 2, n-1
			low = (y(tcc-1)+y(tcc))/2.0
			upp = (y(tcc+1)+y(tcc))/2.0
			pi(tc,tcc) = ANORDF(upp)-ANORDF(low)
		end do
	end do
	! Compute the CDF of the transition matrix.
	picum(:,1)=pi(:,1)
	do tc = 2,n
		picum(:,tc)=picum(:,tc-1)+pi(:,tc)
	enddo
	open(unit=98,file='Tauchen.txt')
	write(98,*) 'rho, sigma, n'
	write(98,*) rho, sigma, n
	write(98,*) 'Income States'
	write(98,*) y(1:n)
	write(98,*) 'Transition Matrix'
	do tc=1,n
		write(98,*) pi(tc,:)
	end do
	write(98,*) 'Transition Matrix CDF'
	do tc=1,n
		write(98,*) picum(tc,:)
	end do
	close(98)
	open(unit=16,	file='transition.txt', status = 'replace')
	write (16, '(41f20.10)') (pi(i1, :), i1 = 1,n)
	close(16)
end subroutine sub_tauchen
Steve_Lionel
Do one (not both!) of these:
  1. Replace 'link_fnl_static.h' with 'link_fnl_shared.h' (my recommendation)
  2. After that INCLUDE line, add:
    !DEC$ OBJCOMMENT LIB:"libiomp5md.lib"
lu_z_
Thank you for your helpful reply, steve. I added  !DEC$ OBJCOMMENT LIB:"libiomp5md.lib" statement. However, there were some new errors emerged
msvcrt.lib(MSVCR120.dll) : error LNK2005: __time32 already defined in LIBCMT.lib(time.obj)
LIBCMT.lib(crt0init.obj) : warning LNK4098: defaultlib msvcrt.lib conflicts with use of other libs/NODEFAULTLIB:library
Debug\EGM.exe : fatal error LNK1169 one or more multiply defined symbols found
Moreover, if I change INCLUDE 'link_fnl_static.h' to INCLUDE 'link_fnl_shared.h', there were a lot of Error LNK2019"unresolved external symbol 'symbol' referenced in function" error emerged.
mecej4
There are too many cooks in the kitchen: if you add "include 'link_fnl_shared.h'" in your source code, and you also specified imsl.lib in the build configuration, you introduced an inconsistency, since imsl.lib is a static library, whose shared library counterpart is imsl_dll.lib.
Follow the instructions at https://software.intel.com/en-us/articles/installing-and-using-the-imsl-libraries .
Steve_Lionel
Can you show those errors?
For the first issue, you have "mixed C library syndrome". Let's see if we can work out the issues with using link_fnl_shared.h.
lu_z_
Since I use the Chinese version of Visual studio, the error message is mixed up with Chinese characters, but the meaning was clear
1>sub_tauchen.obj : error LNK2019: unsolved external symbol  @_RTC_CheckStackVars@8,该符号在函数 _SUB_TAUCHEN 中被引用
1>sub_myinterp1.obj : error LNK2001: unsolved external symbol  @_RTC_CheckStackVars@8
1>sub_value.obj : error LNK2001: unsolved external symbol  @_RTC_CheckStackVars@8
1>main.obj : error LNK2001: unsolved external symbol  @_RTC_CheckStackVars@8
1>sub_eulerequationerror.obj : error LNK2001: unsolved external symbol  @_RTC_CheckStackVars@8
1>sub_kendogenousnewton.obj : error LNK2001: unsolved external symbol  @_RTC_CheckStackVars@8
1>sub_myinterp.obj : error LNK2001: unsolved external symbol  @_RTC_CheckStackVars@8
1>mod_types.obj : error LNK2001: unsolved external symbol  @_RTC_CheckStackVars@8
1>mod_common_var.obj : error LNK2001: unsolved external symbol  @_RTC_CheckStackVars@8
1>sub_simul.obj : error LNK2001: unsolved external symbol  @_RTC_CheckStackVars@8
1>sub_grid_generation.obj : error LNK2001: unsolved external symbol  @_RTC_CheckStackVars@8
1>sub_myinterp.obj : error LNK2001: unsolved external symbol  __RTC_CheckEsp
1>sub_myinterp1.obj : error LNK2001: unsolved external symbol  __RTC_CheckEsp
1>mod_types.obj : error LNK2019: unsolved external symbol  __RTC_CheckEsp,该符号在函数 _MOD_TYPES. 中被引用
1>mod_common_var.obj : error LNK2001: unsolved external symbol  __RTC_CheckEsp
1>sub_grid_generation.obj : error LNK2001: unsolved external symbol  __RTC_CheckEsp
1>sub_kendogenousnewton.obj : error LNK2001: unsolved external symbol  __RTC_CheckEsp
1>sub_value.obj : error LNK2019: unsolved external symbol  __alloca_probe,该符号在函数 _SUB_VALUE 中被引用
1>sub_simul.obj : error LNK2001: unsolved external symbol  __alloca_probe
1>main.obj : error LNK2001: unsolved external symbol  __alloca_probe
1>sub_eulerequationerror.obj : error LNK2001: unsolved external symbol  __alloca_probe
1>sub_tauchen.obj : error LNK2001: unsolved external symbol  __alloca_probe
1>sub_value.obj : error LNK2001: unsolved external symbol  __fltused
1>sub_kendogenousnewton.obj : error LNK2001: unsolved external symbol  __fltused
1>sub_myinterp.obj : error LNK2001: unsolved external symbol  __fltused
1>sub_tauchen.obj : error LNK2001: unsolved external symbol  __fltused
1>sub_myinterp1.obj : error LNK2001: unsolved external symbol  __fltused
1>sub_simul.obj : error LNK2001: unsolved external symbol  __fltused
1>sub_grid_generation.obj : error LNK2001: unsolved external symbol  __fltused
1>main.obj : error LNK2019: unsolved external symbol  __fltused,该符号在函数 _MAIN__ 中被引用
1>sub_eulerequationerror.obj : error LNK2001: unsolved external symbol  __fltused
1>LINK : error LNK2001: unsolved external symbol  _mainCRTStartup
1>Debug\EGM.exe : fatal error LNK1120: 5 个无法解析的外部命令
Steve_Lionel
I wonder if you have somehow disabled linking to the Microsoft C++ libraries. Would you please attach a ZIP of the .vfproj and .vcxproj files in your application's Visual Studio solution?
lu_z_
Of course
Steve_Lionel
Thanks. In your Fortran project properties, go to Linker > Input. Clear the entry you have for "Ignore specific library". You have this set only in the Debug configuration. You have it set to ignore MSVCRTD.lib, which prevents the linker from seeing the MSVC library entries listed in the error messages.
lu_z_
  Great, it works, thank you @steve and @mecej4 for your patience and help
