Please try adding DECORATE to your DLLIMPORT macro as well.
--Lorri
--Lorri
Dear Lorri:
Thansk a lot!
I've tried that, but the compiler says the DECORATE is conflict with DLLIMPORT.
Finally, I found the problem is caused by that I changed the target from win32 to x64, but I did not change the *.lib file the linker used... the path to the new *.lib is ./x64/Release rather than ./Release.
I should use less fixed path strings.
-Di.C.
--Lorri
Dear Lorri:
Thansk a lot!
-Di.C.
--Lorri
Dear Lorri:
Thansk a lot!
-Di.C.
:-) I'm glad to hear you've resolved the problem!
--Lorri
