how to use intel 11.1 for linux
milenko1976
I have downloaded and installed compiler,following the instructions but..The program mt3,I am trying to compile and debug is directory of 11 files,written in FORTRAN77.How to do it?
milenko@hp6830s:~$ source /opt/intel/Compiler/11.1/072/bin/ifortvars.sh intel64
milenko@hp6830s:~$ which fort
milenko@hp6830s:~$ which ifort
/opt/intel/Compiler/11.1/072/bin/intel64/ifort
How should I link comiler and mt3 program?
mecej4
The standard Unix/Linux way:
ifort a.f b.f c.f d.f e.f f.f g.f h.f i.f j.f k.f
./a.out
if the eleven files are a.f,..., k.f
milenko1976
Well besides that,I have 3 .dat files.How to invoke them?
TimP
OPEN is fortran 77 syntax. Any non-standard scheme for opening the files is up to you to discover. If you want help, you'll need to give us more detail.
milenko1976
I know for OPEN.What I thought is a makefile,analogy to gcc.Any links would be great to see examples.
milenko1976
I am giving one detail more form my makefile(gcc):
# Executables
mt1: mt1.o indat.o re2.o defpol12.o boufld.o koef3.o gaussr.o sflfld.o koef3rhs.o gaussrrhs.o surfce.o d2.dat fdat.dat fres.dat fun.dat
$(F77) $(FLAGS) -o mt1 mt1.o indat.o re2.o defpol12.o boufld.o koef3.o gaussr.o sflfld.o koef3rhs.o gaussrrhs.o surfce.o
How should I presnt this to Intel 11.1 compiler?
mecej4
In your makefile, insert this line near the top:
F77 = ifort
milenko1976
What about flags?Are they really important?
mecej4
At this stage, probably not, especially if the code was brought over from a different of machine/compiler combination. Look up the Intel users guide and choose flags suitable for debugging: -g and -traceback. Once you get the program working, record the results, raise the optimization level, and see if the new results are close enough.
milenko1976
Thanks mecej4.
I still have multiple main problem
indat.f:(.text+0x0): multiple definition of `MAIN__'
mt3.o:mt3.f:(.text+0x0): first defined here
Changed compiler flags but no results.
TimP
There isn't any compiler flag to ignore a second main program. If you mean for one of them to be ignored, you'll have to remove it in source code, e.g. by pre-processor conditional compilation directives.
mecej4
It appears that you did not use the makefile that you posted an extract from earlier. The line for mt1 does not show both indat.o and mt3.o.
A Fortran program may consist of (i) exactly one main program routine, plus (ii) zero or more subroutines plus (iii) zero or more function subprograms (setting aside (iv) BLOCKDATA, COMMON blocks, etc).
You are trying to use two main program routines in one program. If you don't mind the analogy, it is similar to having two bicycles. You can only ride one of them at one time.
You have to make the selection of the main program yourself. Compiler switches and makefiles will not do that selection for you.
You will probably benefit from reading introductory textbooks on programming.
milenko1976
But I know that only one main is allowed,it should be mt3.Actually I am calling subroutine indat from mt3(it should give me conductivity map).Look at my makefile:
INTEL_MKL = /opt/intel/Compiler/11.1/072/mkl
F77 = ifort
LD = ifort
CPPFLAGS = -C -traditional $(DFLAGS) -I$(INTEL_INC)
FCFLAGS = $(DFLAGS) -I$(INTEL_INC) -O2 -g -traceback
LDFLAGS = $(FCFLAGS)
LIBS = -L$(INTEL_LIB) -lmkl_intel_lp64
OBJECTS_ARCHITECTURE = machine_intel.o
# Executables
mt3: mt3.o indat.o iaa.o re2.o defpol12.o boufld.o koef3.o gaussr.o sflfld.o koef3rhs.o gaussrrhs.o surfce.o d2.dat fdat.dat fres.dat fun.dat
$(F77) $(FLAGS) -o mt3 mt3.o indat.o iaa.o re2.o defpol12.o boufld.o koef3.o gaussr.o sflfld.o koef3rhs.o gaussrrhs.o surfce.o
What is wrong?
milenko1976
Mangage to solve the problem.
Just get rid of one END!
