ifort: error #10052: could not checkout FLEXlm license
tulika_b_
初学者
3,222 次查看
I am unable to compile my Fortran subroutine sin Abaqus. I always get this occur. This has been the problem for the last few days.
Analysis initiated from SIMULIA established products
Abaqus JOB static_baseprop_2
Abaqus 3DEXPERIENCE R2017x
Abaqus License Manager checked out the following licenses:
Abaqus/Standard checked out 13 tokens from Flexnet server byg-cls01.win.dtu.dk.
<167 out of 205 licenses remain available>.
Begin Compiling Abaqus/Standard User Subroutines
3/8/2018 9:08:11 AM
Error: A license for FCompW is not available (-9,57).
License file(s) used were (in this order):
    1.  Trusted Storage
    2.  C:\Program Files (x86)\Common Files\Intel\Licenses\w_22911_FVJ2ZJHV.lic
    3.  C:\Program Files (x86)\Common Files\Intel\Licenses\w_FVJ2ZJHV.lic
    4.  C:\Program Files\Common Files\Intel\Licenses
    5.  C:\PROGRA~2\Intel\COMPOS~1\bin\intel64\*.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
Abaqus Error: Problem during compilation - field.for
Begin MFS->SFS and SIM cleanup
3/8/2018 9:08:13 AM
Run SMASimUtility.exe
3/8/2018 9:08:14 AM
End MFS->SFS and SIM cleanup
Abaqus/Analysis exited with errors
Please help.
Warm regards,
Tulika
0 项奖励
3 回复数
mecej4
名誉分销商 III
3,222 次查看
Posting serial numbers in a public forum is likely to cause you trouble. Please remove the serial numbers from your post. If the moderators or other Intel personnel need your serial number, send them the number privately.
0 项奖励
Johannes_Rieke
新分销商 III
3,222 次查看
Hi Tulika, I agree strongly to the advise from previous poster. Further the license server name for Abaqus/Simulia might not be wished to provided in publicity.
Nevertheless, try to launch ifort from command prompt (intel command prompt or after running compilervars.bat) or IDE (VS) to see whether this works. Run something like this:
ifort my_file.f90
Sometimes it works not so good for multiple license files (C:\Program Files (x86)\Common Files\Intel\Licenses\*.lic). If you have a license server, be sure that port and server name are correct e.g.
SERVER my_lic_server_name.com ANY PORT
USE_SERVER
Where my_lic_server_name.com is your server name and PORT is the port number of the license manager. Can you ping your license server? If you have installed a new compiler version, you (or your administrator) might need to download an updated license file.
0 项奖励
Steve_Lionel
名誉分销商 III
3,222 次查看
For licensing questions see: https://software.intel.com/en-us/support
0 项奖励
回复
