ifort v15.0.2 could not pass fortran_2003_iee_test
Juncheng_L_
Hi all,
I compiled this file with following commands:
ifort fortran_2003_ieee_test.F
And the error is:
fortran_2003_ieee_test.F(39): error #6503: This keyword is invalid for this intrinsic procedure reference.   [UNIT]
      CALL FLUSH (UNIT=6)
compilation aborted for fortran_2003_ieee_test.F (code 1)
Here's the code:
      PROGRAM fortran_2003_test
      USE , INTRINSIC :: IEEE_EXCEPTIONS
      IMPLICIT NONE
      TYPE bunch_of_stuff
         INTEGER,POINTER,DIMENSION(:) :: i
         REAL   ,POINTER,DIMENSION(:) :: x
         LOGICAL,POINTER,DIMENSION(:) :: l
      END TYPE bunch_of_stuff
      TYPE outer_wrapper
         TYPE(bunch_of_stuff), ALLOCATABLE, DIMENSION(:) :: ddt_things
      END TYPE outer_wrapper
      TYPE(outer_wrapper), DIMENSION(15) :: combo
      REAL :: x , y , z
      INTEGER :: return_code
      CHARACTER (LEN=256) :: my_shell
      x = 1.e+10
      y = 1.e-10
      z = x + y
      ALLOCATE(combo(1)%ddt_things(10))
      ALLOCATE(combo(2)%ddt_things(10))
      ALLOCATE(combo(3)%ddt_things(10))
      CALL IEEE_SET_FLAG ( IEEE_INEXACT , .false. )
      CALL GET_ENVIRONMENT_VARIABLE ( NAME="SHELL" , VALUE=my_shell ,   &
     &                                STATUS=return_code )
      PRINT *,'x,y,z = ',x,y,z
      PRINT *,'SHELL = ',TRIM(my_shell)
      CALL FLUSH (UNIT=6)
      STOP
      END PROGRAM fortran_2003_test
Any ideas to solve the problem? Thanks!
reinhold-bader
New Contributor II
I suspect the error happens because you are trying to use a  non-standard extension. In standard Fortran, FLUSH is not an intrinsic procedure, but a statement:
FLUSH(UNIT=6)
Cheers
Reinhold
