公告
ifortvars.bat not found
Hich_C_
初学者
3,231 次查看
i install Intel Composer XE 2015 but i don´t find ifortvars.bat. Can someone Help to solve this problem?
0 项奖励
1 解答
mecej4
名誉分销商 III
3,231 次查看
The indications are that you installed only the C/C++ compiler. Do you see "Intel Fortran" in the Windows Start Menu or list of installed packages?
在原帖中查看解决方案
0 项奖励
5 回复数
mecej4
名誉分销商 III
3,232 次查看
0 项奖励
Hich_C_
初学者
3,231 次查看
no i don´t find intel fortran in the windows start Menu!!!!!! which programm i have to download Professional Edition for Fortran and C++ Windows or omposer Edition for Fortran Windows .................... i nedd it for ANSYS 14.5 CFX User Fortran. Thank you very much
0 项奖励
mecej4
名誉分销商 III
3,231 次查看
Did you have a version of IFort previously installed?
So that we do not repeat the same incomplete installation as reported in #1, please post the name of the installer that you ran before posting #1. It will be a file with a name such as ...xe_2015_update4_setup.exe. If, in addition, you remember the on screen choices that you were offered and those that you selected, that information would also be helpful.
0 项奖励
Hich_C_
初学者
3,228 次查看
i have install w_ccompxe_online_2015.0.108
0 项奖励
Steven_L_Intel1
3,231 次查看
That's C++ only, as it says on the splash screen.  I see you have an evaluation license that supports installing both Fortran and C++. Go back to https://registrationcenter.intel.com/ and download either the Fortran-only installer or the one with both Fortran and C++.
0 项奖励
回复
